Hp Probook 455 G3 DAX73AMB6E1 blinking charge light, not turning on
  • rccrasher65
    • Mar 2014
    • 595
    Re: Hp Probook 455 G3 DAX73AMB6E1 blinking charge light, not turning on
    Yes I definately want to continue I do believe I have sucessfully installed PU20. Im going to run the wires from the pins to where you said they go. I have done all that you said to do to open those files. Ive done exactly what you said to do and it keeps saying can not open file of this type. or file already exists , and doesn't give me an option to open. And if it does it says the same thing again, can not open file of this type. I also want to work on the one with voltages. working on my soldering of small components. my scope is hard to use, and my eyes are not good for small crap like let me know what we can do with the board with voltages next. I have to work on a few thing before I attempt cutting traces and such. I'm more of a visual learner. Thanks Blue Midnight for your continuous help and Patience!
    • rccrasher65
      • Mar 2014
      • 595
      BlueMidnight, I actually found another practice board for the cutting of traces. I need a week or so to practice cutting and soldering the traces before I attempt on my board. I would like to work on the board with voltages in the mean time. I'm also going to ask my daughter to show me how to open these files, even though they would be greek to me. In the next few days I will try repairing PU20 on the other board. My camera is limited, and the holder is small, so Its actually hard to do things, as this is only a hobby, that I enjoy the learning experience. Thanks again for your patience and help. I'll wait for your direction.
      • BlueMidnight
        • Jan 2015
        • 489
        I've been rather busy (fixing my car among other things). Here's a quick 7-Zip tutorial I threw together though.
        • rccrasher65
          • Mar 2014
          • 595
          Thank you, I'll give this a try. I'll be here when you have some time. Hope all goes well with those repairs.
          • rccrasher65
            • Mar 2014
            • 595
            Finally got it to open with boardviewer,bdv . My daughter opened it up, and showed me how. Just looking things over. Is there 2 sides to the board view? Look forward to your return, Hope things are going well with the car repairs.
            • rccrasher65
              • Mar 2014
              • 595
              Going to shoot for replacing PU20. We'll see what happens.
              • BlueMidnight
                • Jan 2015
                • 489
                There are "Top" and "Bottom" buttons in the toolbar that will switch between the 2 sides of the board. Also, occasionally a board will show up mirrored. So if you want to continue viewing the same side of the board, but the image of it is backwards, use the options at the bottom of the View menu to flip it.
                • rccrasher65
                  • Mar 2014
                  • 595
                  Thanks, just looking, don't really know what I'm looking at, but its interesting, Removed PU- 20 from a donor board, and removed from the board,I messed up the two pads. Going to try, and do this one instead of the other. when you have some time I would like to get back to the board with the voltages. I need one out of 3 to work, as this HP seems to shit the bed every 8 months, and boards are getting scarce. Hope those repairs are going well for you. Thanks again BlueMidnight for your help.
                  • rccrasher65
                    • Mar 2014
                    • 595
                    Well, I was playing around with cutting traces, and scraping back the mask didn't go over very well, just going to work on the one that has a chance with less severe work involved. I will continue to practice, but will not do anything to the board we were working on at this time. When you have some time, just let me know what next step is. Thanks BlueMidnight.
                    • rccrasher65
                      • Mar 2014
                      • 595
                      Have a great holiday weekend!
                      • BlueMidnight
                        • Jan 2015
                        • 489
                        Thanks. You too.
                        For the board with voltages, let's see where we're at.
                        Per this post, I take it that the board has the following:
                        +VIN (19.5V)
                        +3V_PCU (3.3V) @ PL12
                        +5V_PCU (5V) @ PL15
                        +3V_ALW (3.3V)
                        +5V_ALW (5V)
                        LIMIT_SIGNAL
                        How does it react when you press the power button? Lights? Etc.
                        • rccrasher65
                          • Mar 2014
                          • 595
                          Thanks. You too.
                          +VIN (19.5V)
                          +5V_PCU (5V) @ PL15
                          +3V_ALW (3.3V)
                          +5V_ALW (5V)
                          LIMIT_SIGNAL
                          1. Pr 103-19.6V 2. PL12-3.367V 3 .PL15-5.02V Pic#1 +3V ALW-3.36V pic#2 +5V ALW-5.02V Limit signal-5.03V On power jack white light comes on for a sec then goes out, fan starts to spin for a second or two. CPU gets warm also. I have a heat sink under it, while board is energized. I will double check everything Monday evening. Enjoy your Holiday weekend!
                          • rccrasher65
                            • Mar 2014
                            • 595
                            bump
                            • BlueMidnight
                              • Jan 2015
                              • 489
                              Okay, as I understand it, the board responds to the power button, but only comes on for a couple seconds before turning off again.
                              In that case, one possibility is that a power rail somewhere down the line isn't working or has a short. That's probably our best-case scenario, so let's check for that first.
                              Follow the instructions in step 2 of this post for the PLxx inductors/coils. If you've already checked for shorts on those, then the next thing to do is see which ones have the correct voltage during those couple seconds that the light is on and the fan is spinning. We already know some of them must be working. but that still leaves several others to check.
                              • rccrasher65
                                • Mar 2014
                                • 595
                                I do believe that's the first thing I checked was the inductor coils for shorts, I believe there weren't any. I will recheck everything, and post the results Mon evening, heading to the Mountains for the weekend. What are the voltages I should fined on those coils?
                                • rccrasher65
                                  • Mar 2014
                                  • 595
                                  bump
                                  • BlueMidnight
                                    • Jan 2015
                                    • 489
                                    PL1 = 0.95 V
                                    PL6 = 1.5 V
                                    PL11 = +BATCHG
                                    PL12 = 3.3 V
                                    PL15 = 5 V
                                    PL16 = 1.8 V
                                    PL17 = +VCC_CORE
                                    PL18 = +VDDNB_CORE
                                    PL21 = +APU_VDDGFX
                                    PL25 = 0.95 V
                                    PL28 = 1.35 V
                                    Expect nothing for +BATCHG if no main battery connected. The other named ones are related to the CPU and GPU, and should be somewhere in the general vicinity of ~1-1.4 volts. The exact value varies.
                                    • rccrasher65
                                      • Mar 2014
                                      • 595
                                      PL1 = 0.95 V
                                      PL6 = 1.5 V
                                      PL11 = +BATCHG
                                      PL12 = 3.3 V
                                      PL15 = 5 V
                                      PL16 = 1.8 V
                                      PL17 = +VCC_CORE
                                      PL18 = +VDDNB_CORE
                                      PL21 = +APU_VDDGFX
                                      PL25 = 0.95 V
                                      PL28 = 1.35 V
                                      forgot I had a couple of Dr. appts this week. I will need a few more days to get the results. I have a question, will those voltages only be present for the second or two when power is turned on by shorting pins 3-4. Or will they be present when the board is just energized by pluging in the power supply/
                                      • BlueMidnight
                                        • Jan 2015
                                        • 489
                                        The 3V/5V rails are present when it is plugged in. So is +BATCHG (when a battery is connected). Everything else turns on in a sequence. Don't count on anything else being present on any given notebook until the power button is pressed (though some do have a couple additional power rails when off). So, if you don't see it, try pressing the power button and see what it does before it shuts off (does it rise up to a value, fluctuate up and down, etc).
                                        • rccrasher65
                                          • Mar 2014
                                          • 595
                                          BlueMidnight, thanks for your patience, will get at it tonight, and have some results for tues. It will be difficult trying to short pins 3-4 while trying to hold meter probe for readings on the other rails. Any suggestions?
                                          • ipatch
                                            troubleshooting microsoft surface pro 4 no power no led charge light
                                            by ipatch
                                            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                            10-05-2023, 11:59 AM
                                          • someonenotyou
                                            HP ProBook 445 G7 no POST only on battery
                                            by someonenotyou
                                            Hi.
                                            I have a strange problem with HP ProBook 445 G7 (DA0X9MMB8F0 RevF), that there is no POST while only on battery. The Caps Lock blinks 5 times slowly.
                                            When I attach DC Jack, the laptop will charge the battery and switch on.
                                            And now the strange part:
                                            1. While the Windows is still loading, and I will remove the DC Jack, the screen goes blank and the Caps Lock light will start blinking 5 times slowly.
                                            2. When Windows has been loaded and on desktop, when I unplug DC Jack, it will work normally on battery. While still on battery mode I switch the laptop...
                                            Today, 01:24 AM
                                          • stevenallauca
                                            HP laptop does not charge the battery, the light turns amber and then changes to white.
                                            by stevenallauca
                                            Hello everyone. I have a problem with an HP laptop, when connecting the charger the amber light comes on for 6 seconds, changes to white and does not charge, I have checked all the components with the multimeter and the values seem correct, I was guided by the diagram, I do not know if it is a problem with the BQ24728H charge controller, investigating it seems that the voltages given by the charge controller are correct, I made the measurements connected to the power source and without the battery:
                                            - ACN (BQACN) 19.6v
                                            - ACP (BQACP) 19.6v
                                            - CMSRC (BQCMSRC) 19.6v
                                            - ACDRV...
                                            09-23-2024, 11:30 AM
                                            HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 07:12 AM
                                            09-07-2024, 06:40 AM
