Hp Probook 455 G3 DAX73AMB6E1 blinking charge light, not turning on
  • BlueMidnight
    • Jan 2015
    • 489
    Re: Hp Probook 455 G3 DAX73AMB6E1 blinking charge light, not turning on
    There are a couple other signals we can measure just to make sure. I'll be back later with those.
    • rccrasher65
      • Mar 2014
      • 626
      Ok , Thank you!
      • BlueMidnight
        • Jan 2015
        • 489
        See attached pics #16 and #17. All 3 arrows are pointing to test pads (not components). These are a few of the later signals in the power sequence.
        Expected values:
        SYS_PWRGD = 3.3 V
        APU_PWROK = 1.8 V
        APU_RST# = 1.8 V
        • rccrasher65
          • Mar 2014
          • 626
          Expected values:
          SYS_PWRGD = 3.3 V
          APU_PWROK = 1.8 V
          APU_RST# = 1.8 V
          Will the 2 seconds the fan is spinning be enough to get the voltage measurements. Will get these tonight.
          • BlueMidnight
            • Jan 2015
            • 489
            If it spins and stops, then just turn it on 3 times and measure each signal in turn.
            • rccrasher65
              • Mar 2014
              • 626
              Bump
              • BlueMidnight
                • Jan 2015
                • 489
                Hope you're enjoying the holidays. I'm waiting on those measurements.
                • rccrasher65
                  • Mar 2014
                  • 626
                  Yes holiday got pretty busy this year, will get measurements in the morning. Thank you
                  • rccrasher65
                    • Mar 2014
                    • 626
                    Expected values:
                    SYS_PWRGD = 3.3 V
                    APU_PWROK = 1.8 V
                    APU_RST# = 1.8 V
                    I do get these exact values on the test pads.
                    SYS_PWRGD=3.1V APU_PWROK=1.8V APU_RST#=1.8V What would have to happen next?
                    • BlueMidnight
                      • Jan 2015
                      • 489
                      That means it has decided the power rails are good and has told the processor to start, well... processing.
                      The next steps involve it loading the firmware (BIOS/UEFI) and then running it. The actual firmware chip must be getting power and working to some degree, since the embedded controller (EC) firmware is loaded from the same chip at an earlier point in the power up sequence.
                      This may be the end of the road, as the next troubleshooting steps involve buying and learning to use a chip programmer, or paying to ship the board back and forth to someone. And there's guarantee of success.
                      • rccrasher65
                        • Mar 2014
                        • 626
                        Well I guess that's it. I'm not going to buy a programmer. I can buy a working board for less than a hundred dollars, if someone want to give this a shot, at a reasonable price I'm game. I want to thank you for all your help. I've learned so much try to fix these boards. I couldn't have done it with out you.
                        • BlueMidnight
                          • Jan 2015
                          • 489
                          For future readers, I obviously meant to say *no* guarantee of success before. I just caught that typo. haha
                          But yes, you're welcome. The attempt can be fun even if it can't always end in success. Take care.
                          • rccrasher65
                            • Mar 2014
                            • 626
                            Thank you BlueMidnight! what a thread!
                            • rccrasher65
                              • Mar 2014
                              • 626
                              BlueMidnight I see some firmware, and bios USB chip programmers on Ebay really cheap, if these would work, I would consider trying to reprogram chip. let me know what you think.
                              • rccrasher65
                                • Mar 2014
                                • 626
                                bump
                                  • 22216
                                  Originally posted by rccrasher65
                                  bump
                                  Buy a CH341A it will do the job.
                                  • rccrasher65
                                    • Mar 2014
                                    • 626
                                    Thank you!
                                    • BlueMidnight
                                      • Jan 2015
                                      • 489
                                      It is also important to make sure you have everything you need to connect the firmware chip to the programmer. Chip programmers have a DIP socket with a locking lever that accepts the type of large chip that has two rows of long pins sticking straight down.
                                      On the other hand, the chip you need to read is of the small, surface mount variety. There are a few ways of making the connection.
                                      First, it is sometimes possible to connect to the firmware chip without removing it from the motherboard. There are chip clips that have jaws that open (sort of like a clothes pin), and have ribbon cables that plug into a small circuit board that has the DIP pins that will plug into the programmer.
                                      Second, there are small circuit boards with the DIP pins on the bottom and pads to solder the firmware chip on top. This obviously requires desoldering the chip twice every time you want to flash it and then put it back on the motherboard.
                                      Third, you can get test sockets that the firmware chip will pop into that have DIP pins on the bottom (They look like black cubes with a small PCB underneath them). You still need to desolder the chip from the motherboard, but the test socket requires no soldering.
                                      The chip clips are really great, and do work some of the time. But, make sure you have a way to read a desoldered chip too. For the type of chip you have, look for words like "SOP8" or "SOIC8". For the width, look for "200mil" or "208mil".
                                      • rccrasher65
                                        • Mar 2014
                                        • 626
                                        There is a programmer and all the things you mentioned together, for 13.00 I'm going to order that one.
                                        • rccrasher65
                                          • Mar 2014
                                          • 626
                                          I will be ordering on wed, seller said he would have more by then. There are only a few US sellers. The rest are China, would take better than 18 days from there, and only a week from California. I'll let you know when it arrives.
                                          • ipatch
                                            troubleshooting microsoft surface pro 4 no power no led charge light
                                            by ipatch
                                            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                            10-05-2023, 11:59 AM
                                          • YasaCh
                                            Sony kdl 40p5500 red light keeps blinking 3 times
                                            by YasaCh
                                            Hello...
                                            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                            i opened the back cover no sign of damage on the powery suply or motherboard
                                            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                            07-07-2025, 11:53 AM
                                          • someonenotyou
                                            HP ProBook 445 G7 no POST only on battery
                                            by someonenotyou
                                            Hi.
                                            I have a strange problem with HP ProBook 445 G7 (DA0X9MMB8F0 RevF), that there is no POST while only on battery. The Caps Lock blinks 5 times slowly.
                                            When I attach DC Jack, the laptop will charge the battery and switch on.
                                            And now the strange part:
                                            1. While the Windows is still loading, and I will remove the DC Jack, the screen goes blank and the Caps Lock light will start blinking 5 times slowly.
                                            2. When Windows has been loaded and on desktop, when I unplug DC Jack, it will work normally on battery. While still on battery mode I switch the laptop...
                                            06-30-2025, 01:24 AM
                                          • Jacksoft
                                            HP ProBook 440 G6 infinite orange blinking
                                            by Jacksoft
                                            I have an HP ProBook 440 G6 with DAX8JMB16E0 REV. E motherboard that got BIOS bricked after maaany bootloops caused by Window's BCD. I made a dump of the actual BIOS and written a found one.
                                            The PC worked but it was very slooow to show HP logo in first place.
                                            A friend of mine gave me another BIOS for this series and after the flash it powered on (white led on power button) but after few second shutted down and start blinking orange infinitely on the LED near the AC adapter connector on the side.
                                            The laptop doesn't power on anymore, and the blinking led happens...
                                            08-29-2025, 01:24 AM
                                          • stevenallauca
                                            HP laptop does not charge the battery, the light turns amber and then changes to white.
                                            by stevenallauca
                                            Hello everyone. I have a problem with an HP laptop, when connecting the charger the amber light comes on for 6 seconds, changes to white and does not charge, I have checked all the components with the multimeter and the values seem correct, I was guided by the diagram, I do not know if it is a problem with the BQ24728H charge controller, investigating it seems that the voltages given by the charge controller are correct, I made the measurements connected to the power source and without the battery:
                                            - ACN (BQACN) 19.6v
                                            - ACP (BQACP) 19.6v
                                            - CMSRC (BQCMSRC) 19.6v
                                            - ACDRV...
                                            09-23-2024, 11:30 AM
