Mosfet P2808 Solution
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Dear friends, sharing a shortcut but working solution for P2808 fet. This fet is very hard to get in market and my experience is bad with this particular fet. I ordered it online 2-3 times and none worked. This fet is frequently used on clevo laptops and is invariably burnt.. Here is the solution.
    01. Connect PIN2(VIN) to PIN8(VIN1) with a jumper wire with 20 Ohms resistor placed inbetween the two points.
    02. Connect PIN3(M_BTN#) to PIN6(POWER_SW#) with a jumper wire.
    Leave all other pins unconnected. Works like a charm. Hope it will help others.
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Mosfet P2808 Solution
    • bachir2004
      • Feb 2015
      • 437
      • maroc
      very nice.thanks
      • Romy2018
        • Sep 2018
        • 174
        • japan
        thanks for sharing info like this
        • sparrow2719
          • Oct 2015
          • 69
          • Indonesia
          Thanks for sharing
          • mielta
            • Apr 2015
            • 368
            Thanks a lot
            • ruletero
              • Nov 2018
              • 182
              • Mexico
              Does apply for P2808B?
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                yes
                • nassimhamdi
                  • Feb 2016
                  • 150
                  • algeria
                  not work with me,so any an other idea?
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Your problem lies elsewhere. this solution works 100%.
                    • gatecorpo
                      • Jan 2023
                      • 4
                      • US
                      Nice Work , Is Magic !! thank you
                      • Jane
                        How do you test MOSFET in laptops ?
                        by Jane
                        I tried to use this method:
                        Testing an N-channel MOSFET:
                        Step 1: Discharge the Gate (turn off the MOSFET)
                        Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                        Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                        Step 2: Charge the Gate (turn on the MOSFET)
                        Now, place the red probe on the Gate (G) and the black probe on the
                        09-27-2024, 03:31 AM
                      • Nooy
                        VGA MOSfet permanently shorted and loss of MOSfet pad
                        by Nooy
                        Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                        I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                        02-14-2024, 02:26 AM
                      • mikay786
                        Is this jumper wire correct? macbook board missing pad.
                        by mikay786
                        2015 macbook pro which has no sound.
                        Noticed some corrosion by the Cirrus audio ic. Resister R6324 had corroded off the board, pad indicated in pic is gone.
                        So soldered another 100k resister to the pad closest to the ic and ran a jumper wire as per pic to l6201 for the 3v.
                        Is that correct or should i be jumpuring to somewhere else?...
                        04-13-2023, 09:54 PM
                      • AppleLover123
                        Asus X712EA 3 volts after the first mosfet
                        by AppleLover123
                        Hey guys,
                        i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                        I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                        Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                        I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                        Now i thought something...
                        12-15-2024, 07:49 AM
                      • MicroSMD Lab
                        ASUS ROG Zephyrus GPU Mosfet repeat failure
                        by MicroSMD Lab
                        The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                        I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                        01-10-2024, 06:36 AM
