Asus X555LD Rev. 2.0 no screen on internal
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Asus X555LD Rev. 2.0 no screen on internal
    not sure but i think it's you R4504 is not giving BL EN signel to R4504
    just near you have a dioe D4501 pin 3 is BL EN signel pin 1 connect with R4541 you should get BL EN signel hope you can trace it
    • Techtiger
      • Oct 2014
      • 1602
      • france
      can you test D4501 pin 3 BL EN
      pin 1 is connect to R4541 you shoul get BL EN signel there
      test R2538 i think R4530 is bad hope you can trace it
      • Conste
        • Oct 2018
        • 235
        Originally posted by techtiger
        voltage in
        pin 2.3.4.21.27.36.38.39.40
        one of this components short
        C4517 0V on both
        C4512 0V on both
        SL 4504 0V
        R4530 0V on both
        test with out power resistance to gnd multimete
        Pin2: 0V
        Pin3: 0V
        Pin4: 3,26V
        Pin21: 3.26V
        Pin27: 3,26V
        Pin36: 0V
        Pin38: 19,16V
        Pin39: 19,16V
        Pin40: 19,16V
        C4517:
        Pin1 0,8 ohms
        Pin2: 19,2 kohms
        C4512:
        Pin1: 19,2 kohms
        Pin2: 0,8 ohms
        SL4504:
        19,2 kohms
        R4530:
        Pin1: 19,2 kohms
        Pin2: 20,6 kohms
        • Conste
          • Oct 2018
          • 235
          D4501 Pin3 is 0V. I will check R2538 later
          • Techtiger
            • Oct 2014
            • 1602
            • france
            Check voltage U4501 pin 21 3.3V BL EN
            • Conste
              • Oct 2018
              • 235
              0V, is U4501 bad?
              • Techtiger
                • Oct 2014
                • 1602
                • france
                #27
                That is BAD
                • Conste
                  • Oct 2018
                  • 235
                  So put a new DP to LVDS Converter Chip in?
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
                  • FallenOne008
                    Asus G712L No Screen Backlight
                    by FallenOne008
                    Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
                    The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
                    03-31-2025, 08:27 PM
                  • digitalblade
                    ASUS X751LD internal monitor black screen
                    by digitalblade
                    I've a asus laptop with X751LD rev 2.0 MB.
                    The laptop screen remain black but if I attach an external monitor on HDMI port I see the bios screen.
                    I checked power lines on lvds and i found 18.78v also i don't find any obvious problem.. like shorted caps or mosfet on lvds connector area..
                    there is something that I can check to find the problem?
                    thank you
                    03-27-2022, 04:33 AM
                  • reformatt
                    by reformatt
                    07-31-2025, 08:37 PM
                  • krige
                    asus g750js ms1130c (203) turns on nothing on the screen
                    by krige
                    hi all i was wondering if you could help me troubleshoot this laptop. i bought the motherboard off eBay. it is used. i fitted the motherboard into the housing of the gaming casing and turned it on. nothing shows up on the screen. i checked the connectors and no missing connectors. i also removed the graphics card and nothing on the screen. i even reflashed the bios but still nothing on the screen. can it be a corrupt bios? i even used the HDMI port but it also shows nothing on screen. could this be broken screen or a dead ec chip?...
                    03-22-2024, 04:59 AM
