Mack book pro A1707 lcd problem
  • Siddig
    • Jun 2017
    • 264
    • Sudan
    HI
    I have macbook pro A1707 going black screen win I open screen 90° . I don't know what's problem sensor or other thing.
    Can you help me.
    Just it's work on 30° .
    Attach photo.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Mack book pro A1707 lcd problem
    Lvds cable is suspect.
    • Siddig
      • Jun 2017
      • 264
      • Sudan
      Lvds cable it's OK. I think it sensors.
      How I can get it
      • openminded
        • Apr 2017
        • 73
        • home
        the cable is known to be defective on many of those, how would sensors be the cause?
        The lid sensor can probably be tested with software. check if you can find anything for it and better check that cable, because what you describe is exactly that. good luck
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 667
          Hate to break it to you, but all A1706, A1707, and A1708 LCD from 2016-2017 have a very known LCD short cable issue that rips within a year or so because it is a few centimeters to short compared to the issue Apple has fixed in 2018 and up models. I do know how to get that LCD replaced for Free but you will have to have a 2017 model to make this happen.
          sigpic
          MEOWING IN THE IMPOSSIBLE UNIVERSE!
          • waakye
            • Dec 2018
            • 340
            • Electronada
            Hey Stephen, how could I get the LCD to be replaced for free?
            • reformatt
              • Feb 2020
              • 1398
              Apple have (or had) a service program for it, however its confined to 2016 models only. Since they were only manufactured from October 2016, it only covers about 3 months worth. It's the same issue, same model, just Apple won't cover it (officially). Last 2017 A1706 I sent up there they refused to cover it and quoted him AUD $1100 to replace the screen. So I don't know how you would get it replaced, unless you were good mates with someone at Apple or an AASP.
              BTW, I've ordered a replacement screen for one off Aliexpress a while back. Cable was same length, so not worth replacing as same issue will happen again. You can however cut the flex cable and extend it with another flex. These models are total shit anyway, with keyboard, battery and screen issues. Not worth reselling if you ask me as they will likely come back.
              • vinifera
                Vinifera
                • Aug 2018
                • 28
                • Belgium
                Hallo,
                Is this a flexgate problem
                See video
                • reformatt
                  • Feb 2020
                  • 1398
                  Not likely. Flexgate is usually vertical lines or no backlight. This is horizontal, so likely a bad screen (either physical or liquid damage).
                  • Stevedb
                    Stevedb
                    • Feb 2018
                    • 623
                    • Belgium
                    Hi I think this one is dustgate. The ribbon cabeles are damaged from dust and there are lines broken can be fixed but not so easey i got 3 laptops like that and another 2 screens are damaged. I order the screen ribbon cables i will try to replace it but never find and clip youtube somebody do it first. So we will see when the ribbons are coming it xill be succesfull. Search on YouTube dustgate.
                    Regards
                    Steve
                    Good luck
                    • mmccomputer
                      problem with replacing lcd screen
                      by mmccomputer
                      I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
                      otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
                      If anyone has any information on the subject...
                      12-15-2024, 03:44 PM
                    • jimjoe123
                      LCD TV Green/Pink screen problem
                      by jimjoe123
                      I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                      Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                      Then each time...
                      02-23-2020, 01:29 AM
                    • Chrissygizmo
                      Sony KD-55XG9505 lines on screen problem
                      by Chrissygizmo
                      Hello again everyone,
                      This is my latest mission, to try getting this Sony tv back to normal working order…
                      I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                      02-19-2025, 11:31 AM
                      Microsoft Surface Book Surface Book 3 Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                      This specification for the Microsoft Surface Book Surface Book 3 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 boardview and Surface Book 3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-07-2024, 03:40 AM
