HP DV6 Backlight works but no video, ext. monitor shows video.5v resistor burned.
  • Blacktek
    • Nov 2014
    • 250
    This laptop had a resistor on a 5v rail, replaced it with another resistor different value..still only shows backlight.
    im including schematics....Burned resistor was on a 5v rail on CN2(LCD Connector).
    What else should i be looking at?
    There is 5v on both sides of new resistor.
  • Blacktek
    • Nov 2014
    • 250
    Re: HP DV6 Backlight works but no video, ext. monitor shows video.5v resistor burned.
    Please guys.. any input will be appreciated..
    • Blacktek
      • Nov 2014
      • 250
      Bump...Anyone?
      • R_J
        • 9607
        Do you mean R2 ??? It is 75Ω, why would you replace it with a different value? and what value did you use?
        If you measure 5 volts on both sides, that tells me there is no current drawn through it so no voltage drop, so check where it goes in the panel, thats likely where your fault is.
        • Blacktek
          • Nov 2014
          • 250
          THANKS for the input! i replaced it with a 100ohm resistor, but there is 5v on both sides of the resistor, when you say to check where it goes, did you mean the lcd connector side of if or the side where its bringing the voltage.??
          • Blacktek
            • Nov 2014
            • 250
            I've replaced both the resistor R2 and the cap C4 with the right values and still only shows backlight no image, Same voltage on both sides of R2...Could it be the LCD cable?
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3628
              • slovakia
              u think that burned resistor is main reason for no video?
              • Blacktek
                • Nov 2014
                • 250
                Thanks guys for all your support...I FOUND THE CAUSE OF THE PROBLEM..i was just being lazy by not removing the LCD Assembly take a look at what the resistor did...
                • R_J
                  • 9607
                  The resistor did NOTdo that, The ic shorted and blew the resistor, the resistor acts like a fuse in this case.
                  • mikey5791
                    Need help to replace burned resistor in 350w atx psu
                    by mikey5791
                    Hi to all forum members,
                    Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                    The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                    Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                    Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                    12-26-2024, 04:55 AM
                  • keepread
                    Dell monitor PSU vs Dell laptop PSU
                    by keepread
                    Hi there!
                    Someone gave me their old monitor, it's Dell S2715ht.
                    The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                    Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                    10-30-2025, 04:45 PM
                  • RetroComputingGrotto
                    Hanns.G Hi221 Monitor - Works For A Second & Then Blank Display
                    by RetroComputingGrotto
                    I've got a Hanns.G Hi221 Monitor that works for a moment and then the display goes off but the power LED indicator remains on. If you power it off and back on again it does the same thing, it comes on and then the display goes blank. From a cold start it takes 10 seconds or so before the display goes blank but if you turn it off and then back on again after it already being on it goes blank a lot quicker so I'm assuming something is getting hot which is causing the display to go off.
                    I've uploaded a video of it happening on YouTube:
                    I've taken the monitor...
                    01-11-2024, 05:37 AM
                  • deep000
                    Burned Voltage Regulator in Monitor – How to Identify and Repair?
                    by deep000
                    My computer monitor ASUS VP249H stopped working, and smoke came out of it.
                    I opened it and found that a voltage regulator had burned out.
                    The problem is that I can't identify its reference.
                    I searched online for schematics or photos of similar boards that people are selling, but without success (no schematics, bad quality of the board or lack of the reference when it's a good quality 😅).
                    How can I find its reference, and do you think it's repairable?
                    Monitor: Asus VP249H
                    Board reference: 0171 - 2271 - 6083
                    09-08-2024, 01:13 PM
                  • Curious808
                    VisionQuest 24" monitor: works sometimes
                    by Curious808
                    Product name: VQL-24WD
                    Model: 1,050
                    Manufactured: July 2009
                    Problem: Works sometimes. When on, stays on until screen or laptop are turned off. Restarting can take weeks.
                    Background: Bought new around 2010. Used for 2-3 years, then had problems, stopped using. Sat around until a few months ago. Plugged it in to laptop and it worked! Used it for around a month at a time, a couple of times. However, when screen or laptop went to sleep or laptop turned off, then turned on again, monitor was dead. (I kept laptop on and...
                    05-12-2022, 11:02 AM
