iPhone 6 Flashlight issue
+ More Options
Posts
  • BremiX
    • Oct 2017
    • 64
    • Latvia
    having this weird issue with flashlight. When you turn it on it doesn't light up white and bright but gives quick orange flicker.
    Any ideas?
    a1586
    820-3486-A
    I couldn't find schematic and boardview for this board.
    Best Regards,
    Raitis
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: iPhone 6 Flashlight issue
    Any ideas?
    a1586
    820-3486-A
    Best Regards,
    Raitis
    this schematic may help you
    [MOD EDIT] Link to schematic - https://www.badcaps.net/forum/showthread.php?t=59442
    • BremiX
      • Oct 2017
      • 64
      • Latvia
      Thanks.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Sounds like the LED is bad.
        • diif
          • Feb 2014
          • 6978
          • England
          There's a few videos on YouTube detailing similar.
          • fichamba
            • Dec 2011
            • 131
            • Spain
            Thank you forthe schematic!.
            • zribit
              • Aug 2023
              • 15
              • France
              thank you for my work
              • giulio93
                Iphone XR motherboard issue
                by giulio93
                Hi everyone, I have an Iphone XR that powers on but it doen't takes any charge and go very hot most likely istantlly. I'm trying to figure out the problem. Ad a first step I think it will be very helpfull having a cable that can be connected to the battery and recharge connector on the mobo and can power it on. But I don't know how to find it on th web. Can anyone help me so i can go further in the rapair and eventually ask here for more help (but with more infos).
                12-28-2024, 08:12 AM
              • Instafixx
                iPhone 12 Reboot Issue
                by Instafixx
                i have an iPhone 12 but it has a weird issue. It restarts whenever plugged on charger via the lightning port.
                Works perfect with the Magsafe Charger, but it will restart as soon as we Plug in the lightning port.
                Have Changed
                The Charging Flex
                The Charging IC
                We thought maybe the lower board is faulty but nah it restarts even if we change the lower board. I am totally in a fix as to what the issue can be.
                01-12-2023, 12:46 AM
              • rounin
                MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                by rounin
                I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                🛠 Original Issue
                The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                04-19-2025, 01:18 AM
              • ugamazing
                Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                by ugamazing
                I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                12-17-2024, 07:05 PM
              • elmark
                HP 15-cw1002ua strange keyboard issue
                by elmark
                HP Pavilion 15-CW1002UA
                S/N 5CD0251CBC
                P/N 7KE54EA
                Hello guys!
                I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                It powers on OK and has no other issues except the following:
                • CAPS LOCK does not work at all
                • Fn button toggles Flight Mode
                • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                • (with SHIFT pressed: 't%' and 'y^' respectively)
                I initially thought it was a keyboard malfunction (internal short, etc.),
                but when I press and hold...
                06-27-2025, 01:10 AM
