Iphone XR motherboard issue
  • giulio93
    • Aug 2021
    • 258
    • Italy
    Hi everyone, I have an Iphone XR that powers on but it doen't takes any charge and go very hot most likely istantlly. I'm trying to figure out the problem. Ad a first step I think it will be very helpfull having a cable that can be connected to the battery and recharge connector on the mobo and can power it on. But I don't know how to find it on th web. Can anyone help me so i can go further in the rapair and eventually ask here for more help (but with more infos).
  • mon2
    • 14657
    I think you are looking for something like this:
    https://www.diyfixtool.com/products/...01ab8cdb&_ss=r
    * this tool (there are others as well) can power the phone using your power supply - be sure to select the proper series for the connectors (iphone vs Android)
    https://www.diyfixtool.com/products/...21394e9a&_ss=r
    and this tool which can charge the iphone battery (without the iphone):
    https://www.diyfixtool.com/products/...78c71ec8&_ss=r
    • giulio93
      • Aug 2021
      • 258
      • Italy
      Thank you for your answer. What are the differences between the first 2?
      And i see that exist also the power max (not the 2.0). The difference between the 2.0 and the blanck? Thanks again
      • Docus
        Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
        by Docus
        Hi everyone 😀,
        I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
        To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
        Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
        1. I already own the exact same model, but its plastic chassis is badly damaged.
        06-10-2025, 04:24 PM
      • MakNCheese
        ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
        by MakNCheese
        I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
        Symptoms:
        • Severe lag across the system, including BIOS navigation.
        • Slow boot times and unresponsive performance in Windows.
        • Battery charges very slowly (e.g., ~5% in 2–3 hours).
        • No error messages or BSODs, just extreme sluggishness.
        What I've Tried:
        • Replaced
        06-04-2025, 12:48 AM
      • fixme2024
        Intermittent Power Issue with HP DV6 Motherboard Occasional Failure to Turn On
        by fixme2024
        Hello everyone, I have an HP DV6 DAOLX6MB6F2 REV: F motherboard. The issue I'm facing is that sometimes the motherboard doesn't turn on. I've checked the voltages for the power on button panel, and they seem to be okay. Right now, it's working perfectly fine, so I can't pinpoint the exact problem. I have the HP DV6-DV7 Quanta LX6_7 (Liverpool) DAOLX6MB6F2 Rev 1A.pdf schematics, a multimeter, and a 5A power supply. If anyone could guide me on where to start checking first, I would greatly appreciate it. This is my first experience with this. Thank you.
        Here, I have attached a document...
        02-14-2024, 09:24 PM
      • bart64
        ASUS M5A99FX Po Motherboard DIMM Issue , DIMM led keeps flashing after defective DIMM replaced.
        by bart64
        After my ASUS motherboard had random freezes and lockups, i found out that a defective dimm caused the issue, but after change the red indication led on the board keeps flashin with new dimm memory . Reset of the pushbuttion or reset of the cmos does nothing. After the damage one FET near the dimm gets very hot and also some smoke appeared of probably small smd resistors or ic probably. After replacement the FET still takes to much power and burns. When the regulator/ power ic close to the dimms UP1642P is removed the fet keeps cool so I decided to order this and replace it with a new one. But...
        10-18-2025, 05:51 AM
      • wagolla
        Request for Assistance: HP Laptop with LA-G07FP Motherboard Power and Charging Issue
        by wagolla
        HP laptop with the LA-G07FP motherboard has encountered persistent issues with powering on and charging. Here are the details:
        1. The laptop does not power on or charge consistently.
        2. When I remove and then reinsert the battery, the laptop will turn on when connected to the power adapter, and the battery charges normally.
        3. However, after approximately 1-2 days, the issue reoccurs, and the laptop will not power on or charge until I repeat the battery removal process.
        4. I have already updated the drivers and BIOS via the HP support website, but the problem persists.
        Could you assist with...
        10-28-2024, 12:14 AM
