iPhone 12 Reboot Issue
  • Instafixx
    • Jul 2022
    • 374
    • India
    i have an iPhone 12 but it has a weird issue. It restarts whenever plugged on charger via the lightning port.
    Works perfect with the Magsafe Charger, but it will restart as soon as we Plug in the lightning port.
    Have Changed
    The Charging Flex
    The Charging IC
    We thought maybe the lower board is faulty but nah it restarts even if we change the lower board. I am totally in a fix as to what the issue can be.
  • Wasuup
    • Jul 2021
    Re: iPhone 12 Reboot Issue
    What does the panic log say?
    • Stevedb
      Stevedb
      • Feb 2018
      • 624
      • Belgium
      Try disconnect face id flex and front flex
      • giulio93
        Iphone XR motherboard issue
        by giulio93
        Hi everyone, I have an Iphone XR that powers on but it doen't takes any charge and go very hot most likely istantlly. I'm trying to figure out the problem. Ad a first step I think it will be very helpfull having a cable that can be connected to the battery and recharge connector on the mobo and can power it on. But I don't know how to find it on th web. Can anyone help me so i can go further in the rapair and eventually ask here for more help (but with more infos).
        12-28-2024, 08:12 AM
      • alltvrepairs
        Samsung HG49EE690 Hospitality TV reboot issue Mainboard BN94-11086A
        by alltvrepairs
        I have 3 of these TVs for repair with same problem of going to standby after around 10minutes and start again continuously. I have tried a new SPI 25Q40 but fault remains. Am suspecting a CPU problem as it gets a bit hotter than I expect.
        This seems to be a common problem in these models. I am 100% sure it is a mainboard issue as I have fitted a spare from a normal TV from a UE40K5607 and stays on (diplay inverted but I managed to rotate in SM using a different display).
        Any help appreciated!...
        03-14-2024, 03:39 AM
      • rounin
        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
        by rounin
        I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
        🛠 Original Issue
        The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
        04-19-2025, 01:18 AM
      • spice_disc
        Vizio TV M50-C1 reboot cycle and static on screen
        by spice_disc
        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
        09-08-2024, 02:37 PM
      • ugamazing
        Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
        by ugamazing
        I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
        We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
        12-17-2024, 07:05 PM
