HP 6735s blinking orange light
  • ziouneh
    • Nov 2017
    • 10
    • france
    Re: HP 6735s blinking orange light
    If the problemstill goes on just check the power supply around the GPU.. or just try to replace the GPU from an old motherboard.. the new ones often cause problems.. fake!
    • John_F_L
      • Mar 2017
      • 72
      • Greece
      I tried both putting an RTC battery on the board and changing the IO chip. The same happens.
      And I don't have another BGA chip to test.
      • ziouneh
        • Nov 2017
        • 10
        • france
        what about the IO chip.. It may cause serious problems..Just send me the motherboard details and I will see what I can do to help you
        • John_F_L
          • Mar 2017
          • 72
          • Greece
          motherboard number is 6050A2235601-MB-A03 with AMD Sempron CPU
          216-0674026 GPU and 218S7EBLA12FG chipset
          IO Chip SMSC KBC1091-NU
          • dellxps15
            • Feb 2014
            • 1598
            • italy
            hard disk spin ?
            • John_F_L
              • Mar 2017
              • 72
              • Greece
              #26
              I have not connect the hard disk at all.
              • ziouneh
                • Nov 2017
                • 10
                • france
                #27
                Is that exactly your motherboard?
                What about the reballing process? Was it successful? The description you just told is the sign of a deffective GPU.. (or in your case not very well -reballed)..
                It happened to me once when I reflowed the Gpu of a Gateway with AMD sempron processor. At the beginning, I had the display only through the VGA slot, in an external monitor, but not the embedded screen.. After the reflow process, everything stopped.. I have now only some LEDs lit.. no fan, no cpu or gpu start up..
                another thing I must tell you about is whether all the small components surrounding the GPu are still there.. During the reflow process, some of them may be blown away. and the motherboard stops forever.. Pay attention my friend!
                PS I am sending these pictures ofthe motherboard to check the presence of all the components surrounding the GPU.
                good luck
                • John_F_L
                  • Mar 2017
                  • 72
                  • Greece
                  #28
                  This is my motherboard. The reballing process is not something I did it for first time. I have been able to fix many laptops via reballing or changing VGA chip.
                  All the components around GPU are there, nothing missing. And also I'm using IR instead of hot air, so it is more difficult for parts to get blown away.
                  I'm thinking that the GPU may be defective so I'll have to order another one to check.
                  • piernov
                    • Jan 2016
                    • 4439
                    • France
                    #29
                    Usually reballing doesn't fix permanently the issue. On GPUs, the problem is almost never the balls but rather the chip itself. However heating it up to a sensible temperature can make it work again for a while.
                    • ziouneh
                      • Nov 2017
                      • 10
                      • france
                      #30
                      It's 80% the chip.. So try not to order but get one from an old motherboard. New ones are most ofthe time deffective.. They may simply not work.. because they are not made in the OEM factory, but in other counterfeiting factories.. I heard many people complaining about these chip ordered from amazon or ebay or else.. unless you send them an email to urge them to send an original one..
                      good luck
                      • piernov
                        • Jan 2016
                        • 4439
                        • France
                        #31
                        The "new" chips sold on eBay/Aliexpress are old dead reballed ones. They are often polished then remarked to have newer date codes, or even another model number.
                        • mosfetratus
                          macbook A2918, orange light off when shut off
                          by mosfetratus
                          When i fully shut off mac, orange light goes off and wont react to power button. I have difficult time resetting with combination "shift+control+option and power button", because it rarely works (reason unknown), when i manage to get orange light and then press power button macbook wont turn on and orange light goes off. When i hold combination with power button it turns on, and works fine if put it to sleep mode.
                          Works with battery and charges, but when i shut off i get this problem.
                          It had liquid spill. Board has no corrosion, keyboard is working, power button...
                          05-31-2024, 03:34 AM
                        • YasaCh
                          Sony kdl 40p5500 red light keeps blinking 3 times
                          by YasaCh
                          Hello...
                          my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                          i opened the back cover no sign of damage on the powery suply or motherboard
                          when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                          another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                          07-07-2025, 11:53 AM
                        • Tomylee
                          Nintendo 2DS XL – Orange light, no blue light, signs of overheating
                          by Tomylee
                          Hi everyone, I have a Nintendo 2DS XL that shows the orange charging light when plugged in, but nothing happens when I press the power button — no blue light, no screen, no sound.
                          Here's what I've observed:
                          All ribbon cables are properly connected
                          Battery is present and in good condition
                          No reaction even with screens disconnected
                          There's a visible burn mark / overheating sign on the metal shield, right above the CPU
                          I’m suspecting an issue with the CPU, PMIC, NAND, or a power...
                          06-26-2025, 02:33 PM
                        • Jacksoft
                          HP ProBook 440 G6 infinite orange blinking
                          by Jacksoft
                          I have an HP ProBook 440 G6 with DAX8JMB16E0 REV. E motherboard that got BIOS bricked after maaany bootloops caused by Window's BCD. I made a dump of the actual BIOS and written a found one.
                          The PC worked but it was very slooow to show HP logo in first place.
                          A friend of mine gave me another BIOS for this series and after the flash it powered on (white led on power button) but after few second shutted down and start blinking orange infinitely on the LED near the AC adapter connector on the side.
                          The laptop doesn't power on anymore, and the blinking led happens...
                          08-29-2025, 01:24 AM
                        • jheunne
                          A1466 macbook no boot green to orange light help
                          by jheunne
                          i have macbook a1466 board id 820-00165 with power fan spin green to orange light not booting no image or light i tried to fix its leak chip number U1930 but sad it has been damage due of corrosion here i attach the image of board. possible there is a jumper ways for it can't find parts for it to buy.
                          in first image there is 0v out for lcd
                          https://ibb.co/5XppmpkH
                          in 2nd image U1930 chip is damage is there any jumper solution or parts can be compatible for it
                          https://ibb.co/fdJkbJs8
                          06-10-2025, 10:52 PM
