Samsung Np 300 with power issue
  • emmanuelbill1988
    • Mar 2017
    • 100
    • ghana
    please i really need help urgently, I have this Samsung NP 300 laptop when you press the power bottom the display comes and goes in few seconds,but with out the memory the laptop does not go off when power bottom is pressed,I have never come across a problem like this before so i really need help to know what to do,this is the board number SCALA3-15/17CRV REV:1.2 and i have tried different memory's and power supplies but still,tnx
  • techman1025
    • Jun 2014
    • 497
    Re: Samsung Np 300 with power issue
    Hi
    With adapter plugged in to you have your voltages: like alwon 3/5V after power button press core voltage there. If you plug a external keyboard or mouse in does it light up or if press cap lock does it light up . If not you are missing secondary voltage start with flashing bios.
    Techman1025
    • emmanuelbill1988
      • Mar 2017
      • 100
      • ghana
      tnx very much and please can i have the board view and schematic for this mobo
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Very Likely bios issue. Try flashing bios
        • emmanuelbill1988
          • Mar 2017
          • 100
          • ghana
          pls can someone help me with the bios dump Samsung NP 300?tnx in advance
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Post Your Ba-XXXX number on the motherboard without which no one can help you.
            • techman1025
              • Jun 2014
              • 497
              Hi
              Always if you need a dump you need to upload original file even is bad.
              Techman1025
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
              • Cookybaby
                Samsung UN60ES6500FXZA Power Supply Issue
                by Cookybaby
                Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                Make: Samsung
                Model: UN60ES6500FXZA
                Power Supply P/N: BN44-00525A
                Symptoms: The TV was...
                08-20-2023, 12:26 PM
              • Drewwol11
                Samsung QN49Q70RAFXZA Power Cycling Issue
                by Drewwol11
                My Samsung TV display recently stopped working while I was playing PS4 (no storm or anything to indicate a power surge). I could still hear audio through the PS4 but no display. The TV kept trying to turn on but would turn off after a second or two.
                I tried the obvious troubleshooting steps like unplugging, replugging, trying different outlets and power cords with no luck. Someone on another forum suggested that it may be a power supply issue so I purchased a replacement power supply board but that did not help. I then disconnected the main board from the...
                08-31-2021, 09:32 AM
              • lp20th
                Samsung Plasma TV Power Supply Issue
                by lp20th
                I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                11-28-2023, 10:28 AM
              • justice171
                Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                by justice171
                I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                1. Verified that all critical voltages are present:
                  • 3.3V and 5V are always present if DC is plugged.
                  • 1.8V on the BIOS chip is present.
                2. Checked the power button functionality:
                  • When pressed, the voltage drops to 0V, indicating the button is functional.
                3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                  • Confirmed connectivity is intact, ruling out issues
                11-26-2024, 12:39 AM
