hp 250-g2 i3 blink code meaning ????
  • rafik_40150
    • 22
    • algeria
    hello everybody
    i have a problem with a laptop hp 250 g2 i3
    its came to me with caps lock blink white light
    and i make bios & ec flash ( i got the files from another forum and as they said its working and tested )
    after that when i make it on i see that ( f12 ) wifi key blink twice by red then caps lock blink once by white light ...
    i try and change the RAM to 2nd slot and try other 3 RAM but its the same light codes
    the qeustion is whats the light mean cause i search in web and can't find its meaning
    is it worang bios which i use ?
    have anyone a bios for this laptop ?
    motherboard module is ( OSAMU2_CR_HPC MV_MB_V1 )
    and the original BID of bios is ( BID0218B.F11)
    hope that i will find soulition ... thanks a lot
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: hp 250-g2 i3 blink code meaning ????
    if it blink one time it is cpu problem as written on hp support site. check cpu voltages
    if caps lock blink 1 time then off then 1 time then off in loop then it's pch problem.
    • rafik_40150
      • 22
      • algeria
      thanks for replay . do you mean caps lock or wifi key ( f12)
      by me its blink lik this
      (f12) (f12) ( capslock) ,(f12) (f12) ( capslock) , and keep loop lik this
      • Romulo
        • Nov 2016
        • 484
        • Philippines
        Try to reflow pch
        • Francisco.s
          • 686
          • Spain
          Try other dumps before reflow.
          Are the new dump same as original? ( BID0218B.Fxx)
          • dellxps15
            • Feb 2014
            • 1598
            • italy
            if the notebook has never been partition erased, put hard drive in an usb sata reader and explore restore partition for bios files. there will be 1-2 files. ty both of them
            • icareservicezone
              Synology DS918+ blue light blink
              by icareservicezone
              Synology DS918+
              Model name : GDI41L2
              p/N: 08-06GDI4116
              Version: V1.6
              Problem : blue light blink...
              05-24-2025, 11:53 PM
            • djordje
              Philips 55 oled 804/12 red light blink
              by djordje
              Hello all,
              I have Philips Oled 55 (804/12) with black screen and red light blink.
              I have opened TV and tested voltages based on similar oled topics, on power supply board i am getting ps_o/f 3.3v and 5v for t-con_o/f while panel_o/f is 0v. And i get black screen.
              Also i have done self psb test and i am getting on psb +12V_t and also + 24V for panel. (Measurements on dmm are + 12.3V fot t-con and 22.4 for panel)
              When i power only psb and tcon with 4 ribbons for panel i only get black screen.
              My questions is what should i do next...
              01-03-2025, 04:00 PM
            • apostsamking
              latitude 3350 blink 1 white light on
              by apostsamking
              Pls I have latitude 3350 laptop and it stop working. I realize that anytime I press the power button it powers on blink 1 white light on and off. I flash bios but the same problem. I realize that the 3.3v that's on the bios chip is not stable. It goes on and off. But when I remove the bios chip from the board power is stable. I have change the bios chip still the same problem. What should I do.
              05-30-2024, 02:02 AM
            • Acnologia
              Lenovo Ideapad B50-80 (80EW) - LA-B091P - Power Blink Orange light ?
              by Acnologia
              Hello to all,
              New laptop to troubleshoot.
              It power on , fan spin , no image, no light on caps lock.
              Power light is blinking orange .(not an error blink) just orange blinking.
              You press power button again , again it powers up fan spin ,and then cuts off.
              What i tried?
              Removed everything only board, and external monitor left on , and powered with bridge to the power button (in case it was the problem)
              Tried reset RAM ,new RAM , re-flashed bios dump ,from thread that i found here again all the time the same behaviour. With any kind...
              10-12-2022, 02:56 AM
            • hispeck
              Hisense tv model H43B7100 red light blink
              by hispeck
              This hisense tv came with red light blink . What I did was to give the board a separate 12v and it came . Now I know the fault is from the power section. Can someone give a guide how to fix this please . The mainboard no RSAG7.820.8752/ROH...
              03-25-2023, 08:06 AM
