MacBook Pro: one USB port "dead", other works (sort of)
  • RandyOo
    • Feb 2017
    • 7
    On a mid-2012 MacBook Pro 15" Unibody (820-3330 logic board):
    This issue seems to have started after using the USB ports to charge R/C aircraft. I've tried SMC and PRAM reset, unplugging the internal battery, but no change.
    The front port (closest to the SD slot) seems to be completely dead, and doesn't supply power to devices at all. Haven't checked with a powered hub yet, but I have a feeling that the data lines probably work fine.
    The rear port (closest to Magsafe) works, but when I try to charge an iPhone, for example, it only works for a few seconds. I think it's requesting higher charge current, and then it cuts off. Other low-power USB devices seem to work fine on the rear port.
    Looking at the schematic, it seems maybe U4600 is responsible for distributing the power to the two ports. I haven't tried any measurements yet, but wondering:
    - is there a common failure point in this circuit? or...
    - do these symptoms point to a specific component?
    - any suggestions on where to start with measurements?
    I have a friend who has equipment to handle surface mount soldering, once I can figure out the component(s) in need of replacement. Thanks in advance for any suggestions!
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Re: MacBook Pro: one USB port "dead", other works (sort of)
    u4600 receive 5v on pin 1 and 2 ?
    • RandyOo
      • Feb 2017
      • 7
      I haven't been able to check yet: I'm traveling at the moment, and the only multimeter I could find has very large probes. I was afraid that I might short something, so I'll wait until I have access to proper tools, then report back.
      • rookieme
        • Oct 2014
        • 397
        • Greece
        I guess you mean pin 2 & 3
        pin 1 is ground
        @RandyOo you can use a needle as a probe
        • RandyOo
          • Feb 2017
          • 7
          pin 1 is ground
          Thanks. Got a chance to check today: 5.0 volts on pins 2 & 3, as expected. Also pins 4 and 5 have the expected 3.3 volts. Pins 9 and 8 match the values I measure at the USB ports: 4.7V on port A, and 2.0V and dropping on port B.
          R4600 and the adjacent cap seem okay. And L4605 has continuity...
          I'm starting to suspect D4600 for my problems with port A, because pin 1 to pin 6 of D4600 is low resistance. (D4700, service port B, showed "overload" when I checked reverse bias)
          Will start with that one, since it's fairly simple. My friend happens to have a "donor board", so we can do some comparison measurements on that one, too.
          • RandyOo
            • Feb 2017
            • 7
            Came back to report that after replacing the TI TPS2561 IC, I got 5V back on both USB ports, and they both work fine.
            (like this guy: https://www.stohn.de/3d/index.php/20...k-pro-13-2012/ )
            • Superja
              • Mar 2019
              • Spain
              Hi. Did you use TPS2561DRCR or TPS2561DRCT? I see a difference in Max static drain-source on state resistance, 50 vs 70 mOhms.
              I have the same problem that you had.
              • RandyOo
                • Feb 2017
                • 7
                I used the TPS2561DRCT, and Mr. Stohn had used the TPS2561DRCR.
                And for what it's worth, those ports continue to work perfectly.
                • Superja
                  • Mar 2019
                  • Spain
                  Nice to hear that!! Then I think I'm gonna use CT as you did, but it seems both are ok. Thanks!!
                  • microkid
                    • Feb 2020
                    • 4
                    Hi - I am about to replace the TPS2561 as well, my Mid 2012 15" MBP (i7) has no USB ports. A local company (I do some work for) manufacture surface mount PCB assemblies and they are happy to do the work, I just need to supply the chip and show them where it goes - and that where I'm stuck I cannot locate it on the PCB assembly, I have looked around the USB ports but cannot see TPS2561. Could it be under the board? Are you able to provide any insight as to where it may be? Any help very much appreciated - thanks!
                    • piernov
                      • Jan 2016
                      • 4435
                      • France
                      Use schematics and boardview to locate it.
                      Note that there can be a lot of different reasons why USB won't work, and it's not because someone else had a problem with this chip that your problem will be exactly the same.
                      • microkid
                        • Feb 2020
                        • 4
                        Yeah appreciate this, but would like to locate chip so I can check voltages around it. Looking at the schematic this chip does appear as the most likley culprit, and if not a good place to start poking about. The schematic I have is just a PDF of schematics, no layout diagrams.
                        • microkid
                          • Feb 2020
                          • 4
                          Where can I find an appropriate schematic / layout file to use in openboardview?
                          • Stephen
                            A1466 MacBook Air 13" 2017 Backlight issue works but then turns off
                            by Stephen
                            Hello, got a weird MacBook Air here
                            board looks fresh and no water damage, backlight works and turns on and stays on when installing OS etc. However, when the os is installed and when the system files are loaded before the login page the backlight goes out. I have wiped it, NVRAM reset, etc and even took some other instances and this blows my mind, never seen this before. Backlight just turns off once the OS is loaded. Anyone come across this and if so what would be the cause? I am certain its a board issue since I tested the LCD on another board and it stays on. Again the backlight works...
                            08-23-2023, 09:12 AM
                          • Ado02
                            MacBook Pro A2159 - No Display / Works on External Screen
                            by Ado02
                            I am working on a MacBook that came in for a screen replacement. The MacBook powers on and works on the external screen. However, the screen stays black. The replacement screen made no difference. On further investigation, I found small amounts of corrosion.
                            Please see the attached image.
                            I ordered a refurbished logicboard, but the problem didn't go away with the old or replacement screen.
                            Can anyone suggest where to go from here?...
                            01-12-2023, 03:35 AM
                          • kino0924
                            Macbook Air A2179 worked before but dead now
                            by kino0924
                            Hi,I purchased a broken macbook air which claims to be not working keyboard/trackpad.
                            I was hoping to be able to fix it by replacing keyboard/trackpad but it got worse.
                            1. Macbook came with Catalina
                            2. Keyboard Backlight was working
                            3. I tried to update to latest OS through software update and it was having error with updating (download was successful and it went reboot).
                            4. Error was stuck on boot loop of where It tries update but complaining boot disk blabla
                            5. So I connected to Apple Configurator 2 to see if I can revive.
                            6....
                            01-08-2023, 08:38 PM
                          • tobeend
                            Bypass mdm macbook m2 ventura
                            by tobeend
                            1. RESET MACOS WITH IPSW
                            a. Power off MacBook, press and hold the power button to enter Recovery
                            b. Open Disk Utility, remove Macintosh HD
                            c. Reboot, connect to the network to Activate Mac.
                            d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                            d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                            e. Release the other keys, but keep holding the Power key for another 10 seconds
                            f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                            05-26-2023, 07:18 AM
                          • mferna14
                            Apple MacBook Air A1466 (820-00165-A) dead
                            by mferna14
                            I am working MacBook Air A1466 (820-00165-A). The problem "DEAD". Inspection under the MS shows NO LIQUID spill & board is clean as ever. I see the green light on the Magesafe jack, but still not turning on. Getting 3.3v but NO 5 Volts. As soon as I remove the Flex cable J9500 & it runs perfectly, 3.3v & 5v perfect, display ok & boots up into OS very well with no sound ofcourse & no magsafe jack lights as the Flex cable is not connected. As soon as I put this Flex cable back in again into J9500, dead again, 5v goes away. I replaced the Magsafe/Audio board/USB board...
                            10-17-2022, 04:29 PM
