820-3209-a power on only without u7000
    hi
    my macbook is a water damaged one.
    I saw a short circuit in u7000 pin 14 so i removed it and the short was gone.
    Now without it the macbook turns on and it seems ok ( i don't know what u7000 is there for) i deceided to buy another u7000 from aliexpress, but when i place it with air gun, the mac stops turning on again (without any short)
    does someone have some advice to solve this problem?
    Re: 820-3209-a power on only without u7000
    pin14 is ac ok that goes to smc passing trouth a resistor. put u7000 and report all voltages on each pins. (watch out to short pins together)
    probably u have short on one of the mosfet that power 12.5 volt rail or some voltage from ac not ok.
    i suppose u dont have stable green light on ur charger...
      no green or orange lights
      here are all u7000 probes:
      pin 1 0v
      2 15v
      3 4v
      4 3.4v
      5 0
      6 0
      7 0
      8 0
      9 0
      10 3.4
      11 3.4
      12 3.4
      13 0
      14 3.4
      15 0
      16 0
      17 no probe
      18 no probe
      19 5v
      20 5v
      21 0v
      22 gnd
      23 8v
      24 8v
      25 8v
      26 13v
      27 15v
      28 15v
        voltage on fuse near battery? without battery.
        is it a air model ?
          8v with battery and same without it
          yes it is an air model
            check one wire circuit. u7000 is ok.
              where is one wire circuit?
                i dont have schematic for this...
                  you mean pp3v42_g3h right?
                  if yes it is pin 12 of u7000 and the voltage is present yet 3.4 volts...
                    i mean the magsafe dc in pins voltage on mainboard. 1 is gnd, 2 are 16 volt and one should be around 3 volt. i think u dont have that 3 volt and follow schematic to see why u dont have.
                    have u already tried a smc reset ofcourse ?
                      Here are the schematics and boardview+viewer.
                      I would start at page 52
                      schematics and boardview https://www.badcaps.net/forum/troubl...-and-boardview
                        tnx for sharing schematics.
                        for macbook. pin 13 of u7000. check why u dont have voltage here.
                          check page 42 u5010 pin 5 for smc_reset,and do smc to see if that helps
                            pin 5 of u5010 gives 0 volts
                            how i do a smc reset?
                              remove battery and power supply , press and hold power botton 10 seconds.
                              edit: check r5000 if 100k.
                                r5000 is 80k with my multimeter...
                                  voltage on both side of r5000 ?
                                    3.4 on pin 1 and 0 on pin 2
                                      https://www.youtube.com/watch?v=04YpQCXgLyU
                                      same problem as u do have. try replace u5010 or reflow smc.
                                        i have replaced r5000
                                        now it turns on by itself with fan at maximum speed but screen doesn't turn on
                                        i think i'm near target, what can i do now?
