P2808b0 smd ic
  • DrawdeSoft
    • Jul 2016
    • 19
    • Philippines
    P2808b0 smd ic
    Hi Everyone! I just want to ask if there is any equivalent value for this IC (P2808b0 smd ic) ?
    Thank You in advance
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    Re: P2808b0 smd ic
    there is a solution , quiet simple , remove the component because it will not be easy to find REAL 2808 i ordered from many places and major part sucked totally , so there is a nice solution for it ,
    you will need 2 diode 1N4148 or similar i usually use does glass ones and a pair of bypass shunts.
    so diodes will be easy , solder wires on both edges , and the part of the CATHODE (the | trace side ) will be pointed to pin 8 ( so both cathodes will solder to pin 8 the outher side of the diode you will solder one on pin 1 and the outher diode on pin 2 , NOW the important part :
    once you got diodes soldered ,chek pin 3 it must be never higher that 3.3 v also chek pin 6 if there is no 3.3 volts (then SIO is dead and need replacement) if pin 6 have 3.3 volts , make a bypass shunt between pin 3 and 6 , and try turn on the machine , usually it turn on and works perfectly
    let us know , its something that take around 2 min to do it and saved tons of clevos and outher kind of machines like this
    • teknikbursa
      • Sep 2014
      • 64
      • turkey
      Re: P2808b0 smd ic
      Can you explain the connection on a schema.
      • petehall347
        • Jan 2015
        • 4427
        • United Kingdom
        Re: P2808b0 smd ic
        is this it ?
        http://uk.farnell.com/texas-instrume...rfnonsku=false
        TEXAS INSTRUMENTS UCC2808AD-1 PWM Controller Current Mode, 15V-8.3V supply, 1 MHz, 500mV/100mA out, SOIC-8
        • raajkumar
          • Mar 2015
          • 354
          • Srilanka
          Re: P2808b0 smd ic
          I found following information for this chip. I think this may help.
          • DimitriP
            • Aug 2016
            • 8
            Re: P2808b0 smd ic
            What is this "SIO" you are speaking of?
            • Techtiger
              • Oct 2014
              • 1602
              • france
              Re: P2808b0 smd ic
              super input output, or SIO/ KBC is an integrated circuit CHIP on a computer
              • DimitriP
                • Aug 2016
                • 8
                Re: P2808b0 smd ic
                This must be the 120+ pins nightmare IT8518
                • Techtiger
                  • Oct 2014
                  • 1602
                  • france
                  Re: P2808b0 smd ic
                  Yep what is the Fault
                  • DimitriP
                    • Aug 2016
                    • 8
                    Re: P2808b0 smd ic
                    After a bad storm it died. PU6 (2808) was fried, along with a few resistors on the LAN connector.
                    Also found intersting video about the 2808 here: https://www.youtube.com/watch?v=3dLilTxLVCo
                    • DimitriP
                      • Aug 2016
                      • 8
                      Re: P2808b0 smd ic
                      Replaced PU6...pluged in power and bzzzzt ,magic smoke came out of the replacement as well...
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Re: P2808b0 smd ic
                        "coz there is short in mb. Most probably kbc.
                        • tech_guru
                          • Nov 2018
                          • 38
                          • Greece
                          Re: P2808b0 smd ic
                          Hello everyone! i got a clevo W650SB in my hands that had a blown P2808b0 ic, although it was starting properly if you removed the cmos bat and plug the charger to turn on. the power button did not work from the beginning and it did not have 3.3v on.
                          so i did the trick with highpulse's steps (which by the way exactly the same saved me a couple of times in the past, thank you for that!!) and the power button immediately got 3.3v but does not power on again with the button (button is working, checked with multimeter). is there a chance the Super IO is faulty even if it gives 3.3v to the power button? p.s. laptop still works if unplug cmos and plug charger, it turns on by itself
                          • corrize
                            Best way to solder LVDS connector for beginner (and qfn) ?
                            by corrize
                            Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                            I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                            I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                            See the test :
                            https://youtu.be/bNAzC-EvqHs?t=1767
                            With hot air from bellow the board, that's...
                            03-09-2023, 02:57 AM
                          • asr
                            Finding replacement diode iPad Pro 3rd gen A1701
                            by asr
                            Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                            Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                            07-09-2024, 06:24 PM
                          • unimatrix93
                            TV backlight zener diode
                            by unimatrix93
                            Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                            So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                            Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                            The led strips has 9 6V leds.
                            02-10-2025, 12:13 PM
                          • myth77
                            UV solder mask - high temp resistent, recomendation?
                            by myth77
                            Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                            Is there any solder mask...
                            03-28-2022, 04:04 AM
                          • petemanuk
                            BGA solder balls not connecting - help pls
                            by petemanuk
                            So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                            I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                            I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                            11-16-2022, 05:21 AM
