MS-14921 (MSI GE40) from dead, to deader. Advice please?
  • VujeDe
    • Sep 2012
    • 21
    Hi all. I've got what once was an MSI GE40 sitting here that has had a hard life. I bought it for the screen (14" 1080p IPS panel, that I haven't been able to test yet...) with a dead Mobo.
    I was curious how "dead" so I plugged it in and the charging LED lit up. Pushing the power button gave a brief flash of the power LED, then nothing.
    • So I removed ram, swapped for known-good, switched slots, tried none. No change.
    • Removed and reseated CPU. No change.
    • Removed battery. No change. Measured PSU with voltmeter = 19.35v
    • Removed all power. Held down power button for 30 seconds. Reconnected power. Power LED lights & fan on full, sits there indefinitely doing that and that only. Power down, and next power up power LED lights for 15 seconds but that is it (no fan), then powers off. And then next power-on, back to the brief flash of the power LED, then shuts off.
    • And then next power on nothing at all, just the charging LED lit. No brief flicker of power LEDs, nothing. So I went back through everything but still no signs of life apart from the charging LED remaining lit.
    • Disassemble. Unplug everything apart from power in and power switch. Charging LED still lit, but no other signs of life.
    • 19.35v getting to 3 left most pins on POWERCONN1 (top left, first photo), 3 pins on right are ground.
    And that's my current abilities exhausted.
    I don't know the history of this laptop but I can see no evidence of spill damage on the mobo, however the power button board looks like it's seen some action before (see image). If it helps I believe these systems can run very hot.
    Please could any one advise on what the next step might be (and maybe how to go about it)? A schematic may help, although I have little experience reading and interpreting them.
    Thank you very much!
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: MS-14921 (MSI GE40) from dead, to deader. Advice please?
    try to turn it on with extrenal display but unplug internal lcd
    Im Back... sort of...
    • tibd
      • Oct 2014
      • 189
      • Sweden
      Before any other trouble shooting I would reflash bios.
      • VujeDe
        • Sep 2012
        • 21
        Thanks for the suggestion but there is no change when trying this.
        My initial thought was a corrupt BIOS but unfortunately I don't have the equipment to remove and reflash the chip.
        Right now, I think I need to get it to respond to the power button, or bypass that and see if the board will go back to powering on and off again. As right now, it does nothing.
        • VujeDe
          • Sep 2012
          • 21
          In reply to my previous post: I've swapped the power board ribbon cable for one from elsewhere in the laptop, and I'm now back to getting the brief flash from the power LED when I push the power button!
          I sort of know what a socketed BIOS chip looks like, but I see nothing that looks like that on this board, so would assume it's surface mount
          Is it likely to be that? What would be the next step?
          Thanks again
          • String2016
            • Nov 2015
            • 2234
            • philippines
            I have attached the image you posted and marked on the bios chip try to flash your bios or read your bios and post it here someone will fix it for you
            • VujeDe
              • Sep 2012
              • 21
              Thank you very much! I'll be back...
              • Joseph cauchi
                jccomputers
                • Jan 2015
                • 89
                • Malta
                I had a problem similar which I bought a new bios programmed ready and replaced more easy and cost me Euro 15.
                I send them the motherboard model so they can program the bios.
                • VujeDe
                  • Sep 2012
                  • 21
                  Thanks Joseph. I've found one on eBay, so maybe this will be an option! Just need to practice my de-soldering technique for SMD components on an old board first.
                  • VujeDe
                    • Sep 2012
                    • 21
                    Here's the latest. Read about blind flashing to recover a dodgy AMIBios. So I created a FAT formatted USB with AMIBOOT.ROM file in root, and plugged in a USB keyboard ready. Switched it on and spammed ctrl+home and BIOS recovery didn't work.
                    Instead it booted straight in to the stock BIOS!
                    So. What the hell happened there then? Is there a "rescue" BIOS that's triggered to load by ctrl+home?
                    I can tell you for a fact it didn't use the BIOS on the USB stick as the actual BIOS on the board is branded PC Specialist, and the BIOS on the USB was MSI.
                    I guess next I'll start plugging things back in and see if it keeps working
                    • zdanek
                      • Aug 2017
                      • 4
                      • Poland
                      Hello.
                      I have also dead MS-14921 ver 2.0 board. It seems that it burned some caps and maybe other devices.
                      Any one have any idea where to get a schematics for it? I've been searching for about two weeks with no luck. Even paid web pages do not have this schematics.
                      Any ideas please?
                      Bartek
                      • balobi
                        • Jan 2015
                        • 88
                        • phillippines
                        Somebody have schematics & board view of MSI GE40 boardcode: MS-14921 VER 2.0 thank you!
                        • boss juben
                          • Oct 2016
                          • 37
                          • philippines
                          need bios for this model of msi
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3588
                            • slovakia
                            when on power button flash of life means there is a short in power switched rails.
                            • alvin_e
                              • Feb 2019
                              Hi there , if anyone will help me find MSI MS-14921 schematics i will appreciate...just share here...and thanks in advance.
                              • PantherDave
                                by PantherDave
                                Hi all!
                                05-29-2024, 02:01 PM
                              • GLISIT
                                by GLISIT
                                01-16-2025, 02:29 PM
                              • Andreas_de
                                Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                by Andreas_de
                                Hello!
                                i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                04-12-2025, 10:38 AM
                                by sam_sam_sam
                                03-31-2024, 02:12 PM
