First step to do when encountering a dead mobo
  • anthrax0987
    • May 2016
    • 24
    • Empty
    Hello Badcaps members.
    I would like to know especially the members out there with massive experience.
    What is the very first thing to do or first thing to check if I've encountered a totally black out motherboard? I mean a motherboard without indicator.
    With multi meter what is the first thing you always check? Something that is common faulty piece on the motherboard.
  • mehtabbukhari
    Lets help
    • May 2016
    • 26
    • India
    Re: First step to do when encountering a dead mobo
    Step1: Take out Battery
    Step2: Connect only the Adapter after checking its DC OUTPUT with a multi meter
    Step3: On motherboard check for 3.3V & 5V on primary regulator.
    • inflex
      • Aug 2012
      • 544
      First step... look over the board with a magnifying glass, checking everything - look for your clues, water damage, thermal damage, physical damage.
      YouTube Repair Videos - https://www.youtube.com/user/19PLD73
      FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
      • mehtabbukhari
        Lets help
        • May 2016
        • 26
        • India
        Yeah, that is correct, I agree with BRO (Inflex). Physical inspection can save you lot of efforts.
        • inflex
          • Aug 2012
          • 544
          Of course, when nothing shows up... then you start to wonder if it's going to be a nightmare job
          Definitely these days you want the schem and boardview.
          • tablet3rs
            • Aug 2013
            • 57
            • philippines
            i usually start in
            - charger
            - charging port
            - fuse
            - inductor (for short)
            - vreg3/5
            • mikail13
              • Aug 2013
              • 93
              • Turkiye
              everybody is right.
              https://www.badcaps.net/forum/showthread.php?t=56504
              • ChaosLegionnaire
                by ChaosLegionnaire
                09-13-2022, 09:02 AM
              • Acnologia
                Lenovo Thinkpad E15 Gen 2 NM-D011 - No display ? External , yes!
                by Acnologia
                Here is a pretty crazy one.
                Step 1.
                Laptop was brought to me as dead not working. Removed everything , cleared everything.
                Step 2.
                Some liquid damage close to the Type - C connector, and the connector even though it was cleaned wasn't charging the battery . Removed the Type-C port, and replaced it. Now the laptop turns on and charges battery. Shows external screen , not internal.
                Step 3.
                Took out the screen and checked it to a secondary Gen 2 i have, screen works like a charm.
                Step 4.
                Lets ,dive into the board. I see the edp cable on the...
                05-07-2025, 07:16 AM
              • AppleLover123
                Acer aspire e1 572g dead
                by AppleLover123
                Hey Forum,
                I have a dead Acer Laptop from a friend. Find out that its a Mobo fault because Screen is working on other mobo and there are 19V on Power Jack that are going over the two Mosfets into the Mobo. So its actually charging too but no matter what i Do the leds wont come on. So i went over to the 5v and 3v Section and there is nothing at both. The 5v Rail is okay so no short but at the 3v Rail theres a short at PJ401 and on both sides from the Coil PL402 but on the capacitors there is no short. So i found a 19V 3.42Amps Charger (it works) plugged it into the Mobo and the Step...
                12-28-2023, 12:25 PM
              • double_DD
                How can I be sure that my EC chip is dead?
                by double_DD
                As the title suggests, how can I be sure that my EC chip is really dead?
                I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                03-12-2025, 07:47 AM
              • disorder
                ps5 edm-033 dead after hdmi/usb ports destroyed
                by disorder
                hello guys,
                i need help to repair a edm-033 ps2
                history : as always hdmi port and usb ports destroyed after unplugged
                after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                so i changed it
                now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                i don't see any projection of liquid metal on pcb.
                01-14-2025, 12:48 PM
