Compal IFL90 turns on, but screen and vga port is dead
  • 49studebaker
    • Aug 2016
    • 7
    I accidentally plugged the connector from "Camera Conn" JP3 header on page 42 into "Inverter Conn" JP37 header on page 18. When I turn on my laptop, the fan spins up, the front panel lights turn on, but my laptop does not boot. I probably fried the KB925QF on page 34, correct? Is the KB925QF a chip that the laptop manufacturer custom programs? There are some KB925QF chips on Ebay. Could I have damaged other other components (resistors, diode, inductors, caps) on page 18?
    Re: KB925QF replacment
    Do you get backlights on the screen to see anything on the screen?
    What does it do if the camera not connected to JP3?
    If you look at the power pins and the GND pins are setup for the JP3 header and the JP37 header, I would think the camera circuit may be damaged, and switched MOSFET for +INV POWER may be damaged.
    The inverter is probably OK and not damaged when plugged into wrong connector JP3 but the power +5V line on pin 1 of the JP3 may have been grounded out.
    You need to check the power pins of both headers. Things get damaged when power and GND pins are connected wrong to the loads.
    • 49studebaker
      • Aug 2016
      • 7
      The screen is completely black. I shined a bright light on the screen, and I did not see an faint image. The problem in the original post still occurs, if the camera is not connected to JP3.
      • 49studebaker
        • Aug 2016
        • 7
        I connected an external monitor to the laptop's VGA port and nothing appeared on the external monitor's display.
        • 49studebaker
          • Aug 2016
          • 7
          JP37
          Power is on:
          19.38v Pin6
          19.38v Pin7
          Power is off:
          Continuity check
          overload Pin 3
          1417 Pin 4
          overload Pin 5
          overload Pin 6
          overload Pin 7
          0 Pin 1
          0 Pin2
          • 49studebaker
            • Aug 2016
            • 7
            Here is another manual.
            I measured the voltage of each pin:
            Inv_pwm 0.13v
            DispOff# 2.62v
            Dac_brig 0.11v
            Inv_pwr 19.38v
            • 49studebaker
              • Aug 2016
              • 7
              Re: Compal IFL90 KB925QF replacment
              Pin 1 on JP14(EC Debug Port) has 3.3v
              • Rav_tangle
                MacBook Pro 2011 turns on with keyboard light , screen dead
                by Rav_tangle
                Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
                I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
                Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
                is this...
                05-31-2024, 04:09 PM
              • smic717394
                by smic717394
                07-25-2024, 10:16 AM
              • frannyjunk
                Hisense 40H4F no backlight but turns off after splash screen
                by frannyjunk
                So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
                TIA.
                09-24-2025, 10:59 AM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • NeilMcG
                Hp Elitebook - Dead Screen
                by NeilMcG
                Hello all,
                First time posting, so please be gentle 😂
                HP Elitebook 850 G2 Win 10 with Intel HD Graphics 5500.
                Screen dead, but booting.
                I connected it to an external monitor via both VGA & Display Port outputs and external monitor works fine, nothing with F4 or detecting another screen in settings.
                Got a replacement panel, still dead & still displayed to external screen as before.
                Removed CMOS & left it. CMOS reconnected, all as before, no panel, external monitor works.
                Got replacement cable...
                12-06-2024, 03:23 AM
