Asus N71VN burned Power Connector
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Hello People,
    This asus X77V as a Burned Power socket, when i connect the charger, the connector gets very hot and the IC near also gets warm.
    Motherboard is N71VN REV 2.1
    Is there a way to know if it's the socket or this IC 4835GM that is faulty ?
    Some tips please.
    • 31113
    Re: Asus N71VN burned Power Connector
    resolder that pin and re-test.
    look into the connector and make sure the pin is not actually burned - or you need to replace the connector - AND the one that plugs into it!
    • passete
      Living=Sharing
      • Jun 2015
      • 487
      • France
      I have removed the power connector and i was having continuity between the + and -, removed the IC and still have continuity, measured some pins and i'm getting 1,2 Ohms.
      I guess that there is a short somewhere ?
        • 31113
        maybe a ceramic cap - there is a member called "ratdude" with the same issue.
        • tibd
          • Oct 2014
          • 189
          • Sweden
          Remove those three filters and see if you still read 1.2 ohms at the drain of the mosfet you removed. is still then its further inside the board, if not then check the little cap probably cause. If not the cap then you might have shorts within the layers because of the burned +ve leg of the power jack
          • khaahk
            • Dec 2013
            • 793
            • Estonia
            Most likely you've got burnt pcb, there was a loose connection on the input pin - temperature went up and burned the pcb inside - clean the black part (it has turned into conductive coal) and open the pcb carefully with scalpel -remove all the black residue inside the pcb. After that try to isolate so that the + an - do not make contact. It is hard to make it a good fix because the input connector gets physical handling all the time.
            • passete
              Living=Sharing
              • Jun 2015
              • 487
              • France
              I also think that this is the cause, i will give a go in cleaning !
              Can i use a fiber glass pen to clean the coal ? or there is something better ?
              Thanks to all for the tips
                • 31113
                pen is good
                • rievax_60
                  • May 2012
                  • 897
                  • australia
                  I had another Asus model do that. The short circuit was deep inside between the PCB layers. I carefully ground away the burnt material with a rotary tool until the short cleared.
                  • passete
                    Living=Sharing
                    • Jun 2015
                    • 487
                    • France
                    Can you explain what is "ground away the burnt material with a rotary tool" ?
                    • tibd
                      • Oct 2014
                      • 189
                      • Sweden
                      Meaning ground "from verb GRIND" away the burnt material.....
                      Rotary tool t.ex dremel!!
                      • passete
                        Living=Sharing
                        • Jun 2015
                        • 487
                        • France
                        Is there any Hope for this guys ?
                        i have lifted the first coper layer, but as you can see there another layer Under.
                        From those that was capable repairing such mess, what are the hints ??
                        • mariushm
                          • May 2011
                          • 3799
                          It looks like that whole copper pad is connected to the hole where the connector lead goes in. If you scrape off the insulating layer above that large copper pad and expose the copper, you could solder a wire on that copper and then solder the wire to the connector pin.
                          Or, you could solder the wire directly over the ends of those three inductors or resistors which are connected in parallel. Liquid flux would help do a proper solder job.
                          Use a nice sharp blade to trim the copper foil that's not stuck to the pcb.
                          If there's a short around that area, you could maybe enlarge the hole, use a bit of heatshrink on the pin to prevent it from touching the edges of the hole but if there's still a short inside the pcb you have to sort that out first.
                          • passete
                            Living=Sharing
                            • Jun 2015
                            • 487
                            • France
                            Thanks for your tips Buddy, but i still have the short, first i need to remove the short, + and - are shorted .
                              • 31113
                              if you desolder the 3 inductors,you may limit the short to the connector-pads.
                              if that is the case, you can bend the pin up on the connector and link it to the other area with a jumper.
                              • mariushm
                                • May 2011
                                • 3799
                                True, removing the three inductors may solve the issue. If it doesn't, the ceramic capacitor at the top (by the H6538 text) may be shorted, check that out as well.
                                • passete
                                  Living=Sharing
                                  • Jun 2015
                                  • 487
                                  • France
                                  Yeah, good idea Pally.
                                  This is my next Step, thank you both.
                                  • passete
                                    Living=Sharing
                                    • Jun 2015
                                    • 487
                                    • France
                                    Ok, No more Short between + and - (i think).
                                    From here, how can i proceed to the next test ?
                                    If Possible please, make a drawing from the photos above.
                                      • 31113
                                      can you bend the socket pin up without it snapping?
                                      • passete
                                        Living=Sharing
                                        • Jun 2015
                                        • 487
                                        • France
                                        Thanks Buddy,
                                        i just measured and still this short (check picture)
                                        I'm gonna remove this smd
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • ShadowAi
                                          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                                          by ShadowAi
                                          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                                          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                                          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                                          03-15-2024, 10:46 AM
                                        • meraklinetx
                                          Asus Z97-a power cycle, no boot no cpu voltage
                                          by meraklinetx
                                          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                          05-10-2023, 06:08 AM
                                        • Duranitron
                                          Asus x512dk rev 2.1 power on problem
                                          by Duranitron
                                          When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                                          Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                                          11-26-2024, 10:22 PM
