Acer KAV10 short circuit on jack
  • rippergr
    • May 2014
    • 345
    • Ελλάδα
    Hello all,
    I have an acer kav10 netbook REV 1.0 which doesnt power on ,no lights,nothing it's completely dead.
    When I use my bench power it short circuits if the voltage goes over 2,5V.
    If I put 2V I can measure components, in this case I have in VIN (measuring in dc jack + ) 1,20V . In pd13 I have from the side of VIN 1,20V and on the other side 0,85V. Almost everywhere I measure (PQ10,PQ44 etc) Ihave 0,85V .
    In PU5 CSIN I have no voltage.
    There is no visual defection on any component.
    Can someone help me out?
  • tibd
    • Oct 2014
    • 189
    • Sweden
    Re: Acer KAV10 short circuit on jack
    I would start turning up the voltage supply gradually and see if anything heats up. You are safe up to the nominated voltage the original PS provides.
    • rippergr
      • May 2014
      • 345
      • Ελλάδα
      I thought of that but when I increase the voltage over 3v my bench power supply just cut the voltage, increases the ambs a little and light a red LEDs showing that there is a short. So I can't get past 2,8 - 3v
      • rippergr
        • May 2014
        • 345
        • Ελλάδα
        I think the problem is with PQ10 P1403EVG_SO8.
        I tested with multimeter and it gives me short on every pin (multimeter set to beeper)
        Can I inject voltage after the mosfet to some point and what voltage so I can check if is indeed this mosfet?
        • rippergr
          • May 2014
          • 345
          • Ελλάδα
          I changed the mosfet and the short circuit is gone.
          The laptop still doesnt power on and the mosfet is very hot when I give 19V on jack.
          In pins 1,2,3,4 I have 19V and in 5,6,7,8 I have 0,3V so I think it has another defective component.
          Can someone guide me what else should I check?
          • rievax_60
            • May 2012
            • 897
            • australia
            Hopefully a shorted surface mount ceramic capacitor on the B+ rail. Sometimes it's a shorted high side MOSFET usually in the Vcore regulator.
            • rippergr
              • May 2014
              • 345
              • Ελλάδα
              So I should check PC147,PC156 and pc 42,43,44?
              How can I check if a capacitor is bad or short?
              • rievax_60
                • May 2012
                • 897
                • australia
                I went to sleep.
                First check with your meter to confirm that it is an ohmic short, a few ohms or less.
                If you decide to apply power to the B+, apply no more than 1 volt to avoid more damage although this may have already occurred. Look for any shorted High Side MOSFETS that are trying to pass the B+ voltage directly to the low voltage rail that they are supposed to supply, like +CPU_CORE and others.
                If it is a shorted capacitor, I use a method that requires a multimeter that has 10uv resolution. I use it to trace voltage drops on the ground plane. Other members use easier to understand methods.
                • and555
                  • Apr 2016
                  • 36
                  • Indonesia
                  yes, you can inject voltage after the mosfet, as rievax_60 said: apply no more than 1 volt.
                  • 2Stupid4U
                    Acer Nitro 5 An517-51 mainboard short circuit - Boomer needs help
                    by 2Stupid4U
                    Laptop data:
                    NTB Acer An517-51 FHD
                    i7-9750H
                    16GB replaced with RAM Crucial Ballistix SODIMM DDR4-3200 32GB K2 SW
                    1TB SSD
                    RTX2060
                    Bon soir dear online techies, enthusiasts, modest helpers and whomever I might have forgotten!
                    Search gave me no hits so this is my first post.
                    My Acer 5 Nitro mainboard had a short circuit when I tried to plugin a USB device. Some smoke rose from the port and it became super hot a that point of entry/exit. Warranty was of about a month.
                    Since I am on a low budget I cannot afford to buy...
                    08-29-2023, 01:03 AM
                  • konter
                    ACER Nitro 5 AN515-55-774Z ((FH52M LA-J891P REV.1) - GPU memory short circuit
                    by konter
                    Intel Core i7-10750H
                    RTX 2060 6GB GDDR6
                    Turned off during normal operation and never turned on again.
                    After disassembling and connecting to the power supply PLW3 burned out.
                    Resistances on all chokes are within normal limits except PLW1 and PLW2 (about 0.5 ohms) - powering the video memory.
                    I am new to repair( Advise what to do next to find the short circuit and fix it.
                    Or if burned GPU then how to disconnect GPU and use without it.
                    If there is anything else that needs to be measured,...
                    11-24-2023, 10:21 AM
                  • aaronkatrini
                    Help me find the short circuit on this WORKING Nvidia GTX1650
                    by aaronkatrini
                    Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
                    Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
                    04-18-2024, 03:15 PM
                  • Geeker007
                    9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                    by Geeker007
                    Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                    I am new to electronics repair, so my queries could be naive but I am ready to learn.
                    So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                    01-28-2025, 03:31 PM
                  • Tarot Superstars
                    Short Circuit tester
                    by Tarot Superstars
                    Hello.
                    I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                    The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                    Link
                    The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                    https://www.youtube.com/watch?v=0eixDdCpiO4
                    My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                    09-25-2023, 09:11 AM
