HP 15-f010dx NO BACKLIGHT DA0U83MB6E0 rev:E
  • Blacktek
    • Nov 2014
    • 250
    This laptop turns on and external monitor works as well, only issue is backlight?
    any suggestions before i take the lcd apart?
  • Blacktek
    • Nov 2014
    • 250
    Re: HP 15-f010dx NO BACKLIGHT DA0U83MB6E0 rev:E
    never mind guys it was a bad screen
    • dj_ricoh
      • 2073
      • uk
      The screen its fused to.
      If you find and tested you can fix that to.
      Check and see they all fused
      • samalak
        • Nov 2014
        • 5
        • India
        Hi friends,
        I have a dead mbd with part no DA0U83MB6E0 Rev:e. Need the schematic to proceed further.
        Help Me if anybody have the schematic.
        • meritosari
          • Oct 2010
          • 774
          • Indonesia
          • Pascal Komlassan
            • Jan 2017
            • 806
            • TOGO
            Hello please I need the bios dump of this motherboard any help please
            • imranromi
              • Jan 2015
              • 1288
              • Pakistan
              Originally posted by pascal komlassan
              hello please i need the bios dump of this motherboard any help please
              did you know how to check bid?
              • Pascal Komlassan
                • Jan 2017
                • 806
                • TOGO
                no Sir please can you help me ?
                • imranromi
                  • Jan 2015
                  • 1288
                  • Pakistan
                  CHECK AND READ THIS ARTICLES.
                  https://***********/threads/model-laptop-hp-bios.16493/
                  • Pascal Komlassan
                    • Jan 2017
                    • 806
                    • TOGO
                    Any help please 🙏🏼
                    • Pascal Komlassan
                      • Jan 2017
                      • 806
                      • TOGO
                      Any help for this bios please somebody can send me the dump?
                      • triplefour
                        by triplefour
                        09-13-2023, 10:43 PM
                      • DanPoka
                        by DanPoka
                        02-15-2025, 05:05 AM
                      • Comp_Pro
                        No Backlight Macbook A1990 820-01041
                        by Comp_Pro
                        Hello all,
                        Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                        Tests performed:
                        There is no backlight even with a good screen.
                        Backlight IC is receiving the correct support voltages.
                        Fuse F8400 ok
                        Current sense resistor R8400 ok
                        Backlight IC is receiving 3.3V on enable pin.
                        Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                        Backlight IC receiving 5V from PP5V_G3S
                        Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                        I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                        05-06-2024, 10:23 PM
                      • cheebster
                        iPad Pro 12.9 5th Gen Backlight Issue
                        by cheebster
                        Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                        Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                        Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                        The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                        Anyone...
                        05-20-2025, 09:17 AM
                      • canadaboy25
                        LG Flatron 24EN33TA No Backlight When Cold
                        by canadaboy25
                        I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                        I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                        03-07-2023, 12:23 AM
