Asus X551CA no power and no led
  • DS-1
    • Jun 2015
    • 82
    • Italy
    a friend of mine gave me this laptop (it has soldered cpu and RAM).
    No led, no power with a working ac adapter. I've tried to remove the battery, but nothing happens.
    Has anyone experiences with this laptop?
  • DS-1
    • Jun 2015
    • 82
    • Italy
    Re: Asus X551CA no power and no led
    No one can help me?
    I believe it's hard to find schematics and info about this laptop!
    • meritosari
      • Oct 2010
      • 774
      • Indonesia
      Originally posted by DS-1
      No one can help me?
      Photo as reference?
      Let picture speak
      link scan notebook High quality
      https://docs.google.com/spreadsheet/...=sharing#gid=1
      • DS-1
        • Jun 2015
        • 82
        • Italy
        The board is the same one you can see in photo. If you need specific pics, just ask.
        Originally posted by meritosari
        Photo as reference?
        Let picture speak
        • alihomee
          • Dec 2012
          • 1591
          • malaysia
          how the main volts .....battery connector......3v 5v.......
          • dj_ricoh
            • 2073
            • uk
            check the dc jack
            they are notorius for breaking
            • meritosari
              • Oct 2010
              • 774
              • Indonesia
              No one can help me?
              I've got the boardview and share it for this forum
              • pcnetch
                • Aug 2013
                • 125
                • Sri Lanka
                Check power button voltage. if present and after pressing going 0v try re-ball pch.
                • DS-1
                  • Jun 2015
                  • 82
                  • Italy
                  I have 19v on dc jack mainboard solder points, so it's not broken.
                  I have 3v on 2 battery connector pins.
                  I'll check power button voltage, as @pcnetch wrote.
                  • DS-1
                    • Jun 2015
                    • 82
                    • Italy
                    It seems I can't open .fz schematic file with no app (Fritzing says it has the first line corrupted, TSICT seems to work only with .BOM files, PCBRepairTool doesn't show the file, when I put it in FAB folder).
                    • meritosari
                      • Oct 2010
                      • 774
                      • Indonesia
                      Use pcbrepair tool, when open first time you've got error license, open again pcbrepair tool, then use ctrl+f11, direct to folder you have it. Its done.
                      • DS-1
                        • Jun 2015
                        • 82
                        • Italy
                        @meritosari, thanks a lot.
                        I've checked voltages again. I have no volts on power button and I have 2.80v circa on the last two pins of the battery charger socket.
                        I've noticed that when I plug the ac adapter on, something in the area of the picture I've attached become very hot.
                        • meritosari
                          • Oct 2010
                          • 774
                          • Indonesia
                          where? they have name. LOL
                          PQ, PU,PC or PR, please mentioned
                          try touch with finger..I think you've find the culprit.. maybe that component was shorted/broken
                          • DS-1
                            • Jun 2015
                            • 82
                            • Italy
                            ehhh...I know I was too generic, but it's not that easy to understand with fingers which one of those small components is hot!
                            That's why I posted the area: maybe is it a common fault in that area?
                            I'll try to find a way to understand which one is shorted!
                            • meritosari
                              • Oct 2010
                              • 774
                              • Indonesia
                              measure resistance to gnd on some point below without adapter/battery plug in
                              1.pjp8100 (19v rail short or not)
                              2.pjp8102 (3.3v short or not)
                              3.pjp8101 (5v short or not)
                              measure resistance mosfet near area that was hot if shorted (Drain-Source, S-D)
                              use magnifying glass to look if small component (caps) was burn
                              • pcnetch
                                • Aug 2013
                                • 125
                                • Sri Lanka
                                If no Power button voltage, definitely System main power fail. I fixed two x551ca laps in last week. But not this problem. Try search IC number in google will give you IC's datasheet.Then check LDO Voltages.
                                • pcnetch
                                  • Aug 2013
                                  • 125
                                  • Sri Lanka
                                  If heating PCB in normal mode, definitely must be a short. specially cap etc. Do you have DC bench power supply. If you have can check short places easily.
                                  • Blacktek
                                    • Nov 2014
                                    • 250
                                    i have the exact same board with a power issue, plugged in no power whatsoever. first thing i checked was the mosfets near the powerjack, one of them looks suspicious but for the life of me i cannot find the schematic for this board..im like 80% sure that whats causing the issue..why? because it has continuity on all pins(shorted).
                                    Seems like the only place that might have the schematic is ***********? can any of you guys get it for me?
                                    • meritosari
                                      • Oct 2010
                                      • 774
                                      • Indonesia
                                      The best tool for working with asus are the boardview+scan photo, schematic doesn't help cause the board without marking as other vendor.
                                      I don't have access to vinafix, but if you scrool below on link @ktmmotocross the admin say no schematics, just boardview
                                      Sorry for bad english
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        I have had a number of these lately. The issues ranged from bad MOSFETs in the DC in to shorted capacitors and the last one had the KBC shorted.
                                        Be very careful about probing the power button connector or turning it on with tweezers - there is a 19v line right next to pin 1 (3.3v). You don't want to touch those two points together by any chance.
                                        A working TV? How boring!
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • ShadowAi
                                          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                                          by ShadowAi
                                          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                                          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                                          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                                          03-15-2024, 10:46 AM
                                        • meraklinetx
                                          Asus Z97-a power cycle, no boot no cpu voltage
                                          by meraklinetx
                                          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                          05-10-2023, 06:08 AM
