Minimum ram amount
  • artois7
    • Mar 2011
    • 159
    Minimum ram amount
    Weird one here, got in a HP G6 350 i5 for repair as it would turn on and cut off after 5 seconds.
    Turns out the 4GB ddr3 module had shorted.
    Interestingly, this i5 machine won't recognise any DDR3 under 4GB. I have loads of 2GB modules but no 4's kicking about.
    Anyone encountered this?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: Minimum ram amount
    maye thats because of DDR3L memory
    • artois7
      • Mar 2011
      • 159
      I've been out of this game for ages now and haven't worked on a laptop since DDR2 was mainstream, are DDR3L machines backwards compatible with DDR3 modules?
      • SteveNielsen
        Retired Tech
        • Jun 2012
        • 2327
        The specs for that laptop are for DDR3 RAM.
        • artois7
          • Mar 2011
          • 159
          Any ideas why it requires a 4gb module then? 2 x 2gb won't make it boot.
          • diif
            • Feb 2014
            • 6978
            • England
            Is it 1333MHz ?
            I've seen HPs be a bit picky on memory in the past.
            • artois7
              • Mar 2011
              • 159
              My apologies, this is a hp G1 not G6.
              The 4gb module in there is 12800 and all the ram I have is 10600, so that could be it.
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3627
                • slovakia
                and its ddr3L
                https://cdn.badcaps-static.com/pdfs/...12e2db36a5.pdf
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Yes and as above is DDR3L not DDR3, with DDR3L running at a lower voltage than DDR3.
                  • Choppies007
                    • Aug 2014
                    • South-Africa
                    Honestly these days expect anything from HP and Lenovo
                    • eccerr0r
                      old X58 triple channel board... memtest86 memory speed?
                      by eccerr0r
                      Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                      Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                      Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                      06-28-2025, 09:06 AM
                    • jasko_jacker
                      Ram DDR3 to DDR3L
                      by jasko_jacker
                      I have a lot of asus motherboard with ddr3l ram onboard and various ram stick ddr3 1.5v .
                      I think there should be no problem in replacing the ddr3 chips with the ddr3l ones.
                      What function does the chip have that I see welded on the dual rank ram?
                      For example 34ch1b2dz
                      12-09-2019, 09:59 AM
                    • ongobongo
                      Ram Modules with undderfill - tricks for desoldering
                      by ongobongo
                      I'm working on another Lenovo E14 gen 2 AMD here which has a ton of errors with the factory soldered DDR4 ram chips. I do have a donor board here from which I'd like to use the modules and swap them. Unfortunately, the modules are glued down with underfill, which i have never worked with before.
                      I tried with a lot of heat on the donor board but the modules won't come loose.
                      Are there any hint or tricks when it comes to dealing with underfilled chips/ic that could help here
                      Ongo
                      06-02-2024, 02:18 AM
                    • gabrielA7
                      Zotac GTX 1080 8GB / No video / Error reported on all memory modules!
                      by gabrielA7
                      Hi guys!!
                      I have this video card on my bench, it turns on and the screen goes black!
                      I used MATS but it showed an error in all memory modules, when writing!
                      I once got a 1060 with the same symptom, all modules were defective, I rebaled the GPU and it stayed the same.
                      Remember that I have all the debts ok, 1.35 Vram and such!
                      Could the problem really be in the GPU?
                      Could it be the BIOS?
                      Thank you in advance!​
                      06-05-2025, 09:04 AM
                    • vallllliiii
                      Gigabyte motherboard GA-H110M-S2PH (rev. 1.0) DDR3 | Boot loop and 5 beeps
                      by vallllliiii
                      Hi, last month i bought a broken pc that i tought i can fix for myself but it turned out to be time consuming. The pc turn on and shows no display and beeps 5 times and restarts again and again, i think it s the motherboard because i tested/replaced all the parts except the motherboard. The pc was used mostly for light gaming and i think it wasnt overclocked or something. I tried all the basic fixes(cleaning the ram slots, removing the cmos battery, reseat the GPU/CPU/RAM). I think the last thing to do is to replace or repair the mobo but i prefer to try to repair because i don t want to spent...
                      08-18-2024, 09:21 AM
