HP 6910p reverse polarity issue
  • mpikou
    • Jun 2013
    • 58
    • Greece
    i got a HP 6910p laptop. Client has put an ac adapter with reverse polarity. From then, its dead. I am searching at the board in order to find the diode with must be there in order to protect but i cant locate it.
    Can anyone help or provide a schematic for that board ?
    Thanks in adavanced.
  • atsio
    • Oct 2013
    • 819
    • Greece
    Re: HP 6910p reverse polarity issue
    Try those, one is UMA the other Discrete
    https://cdn.badcaps-static.com/pdfs/...42bb0c2769.pdf
    https://cdn.badcaps-static.com/pdfs/...ac17446eca.pdf
    • mpikou
      • Jun 2013
      • 58
      • Greece
      Thank you VERY much for the schematics and the reply.
      I cant locade the diodes to the board... could you please help me ?
      Here are photos of the board.
      http://imageshack.com/a/img901/6906/BlJKfe.jpg
      http://imageshack.com/a/img540/3535/xOq3Jx.jpg
      http://imageshack.com/a/img538/9500/jFcn3e.jpg
      http://imageshack.com/a/img913/7939/KgJ51M.jpg
      • dj_ricoh
        • 2073
        Did you saw,smell or hear something?
        If not discharge the board and give it one more try.
        • mpikou
          • Jun 2013
          • 58
          • Greece
          Nothing smells, no sound at all and not something burn/wrong with optican observation.
          Fully disharged and issue persists.
          • atsio
            • Oct 2013
            • 819
            • Greece
            What's the current drawn when you plug in lab supply?
            • mpikou
              • Jun 2013
              • 58
              • Greece
              If i have undertand correct what you are asking, its 19V.
              • R_J
                • 9535
                On page 37 of the first diagram, PCN1 is the input jack, the adaptor voltage should go through coil PL1 and be on (VIN) on the next page (38) VIN comes to fet PQ3 & PQ5 etc. I would check parts in that area. Is there voltage on P2 or P4 or B+
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3582
                  • slovakia
                  post photo of area around power connector. both side.
                  • atsio
                    • Oct 2013
                    • 819
                    • Greece
                    Όχι τα αμπέρ που τραβάει από το τροφοδοτικό σου, όταν το κουμπώνεις (χωρίς να ξεκινήσεις το laptop).
                    • mpikou
                      • Jun 2013
                      • 58
                      • Greece
                      PL1 its ok, PQ5 ok, but i cant locate PQ3.
                      Here are the photos.
                      http://imageshack.com/a/img537/4334/jiMNoL.jpg
                      http://imageshack.com/a/img910/5082/Oe3G2k.jpg
                      Ευχαριστώ για την διευκρίνηση.
                      • Dev Goose
                        Help Needed: Reverse Polarity Issue on HP EliteBook 840 G4 – Where Do I Begin?
                        by Dev Goose
                        Hi everyone, I recently acquired an HP EliteBook 840 G4 (6050A2854301-MB-A01) that I'm hoping to bring back to life. I'm fairly new to laptop repairs but eager to learn and willing to put in the effort to understand and fix this. Any advice or guidance would mean a lot!
                        What Happened
                        The issue started when the laptop was accidentally plugged in with reverse polarity. Before this incident, the laptop would show a power/charging light whenever it was plugged in. However, now it's completely unresponsive—no lights, no power, nothing. I've been doing some research and understand
                        12-13-2024, 03:13 AM
                      • Kervin Mathumbu
                        Asus E410 only works on battery after reverse polarity
                        by Kervin Mathumbu
                        Hi everyone. Fixed my AC and despite trying to be extra careful, I reversed polarity and got a notable pop sound. Now the PC will only work on battery. Windows still shows the battery as charging but the count actually goes down until empty (I have two of the same laptops).
                        I have board R3.0 so the schematics on another thread here do not match mine. I have tested the BQ charge IC and my pin 1, 2 and 3 have 3.35v each - instead of 18v or 19v. Could this be a bad BQ IC or capacitor? Any thoughtful advise sould be greatly appreciated.
                        Mobo shows no visible sign of a fried...
                        07-15-2024, 11:26 AM
                      • rounin
                        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                        by rounin
                        🛠 Original Issue
                        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                        04-19-2025, 01:18 AM
                      • ugamazing
                        by ugamazing
                        12-17-2024, 07:05 PM
                      • elmark
                        HP 15-cw1002ua strange keyboard issue
                        by elmark
                        HP Pavilion 15-CW1002UA
                        S/N 5CD0251CBC
                        P/N 7KE54EA
                        Hello guys!
                        I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                        It powers on OK and has no other issues except the following:
                        • CAPS LOCK does not work at all
                        • Fn button toggles Flight Mode
                        • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                        • (with SHIFT pressed: 't%' and 'y^' respectively)
                        I initially thought it was a keyboard malfunction (internal short, etc.),
                        but when I press and hold...
                        06-27-2025, 01:10 AM
