HP 6910p reverse polarity issue
  • mpikou
    • Jun 2013
    • 58
    • Greece
    i got a HP 6910p laptop. Client has put an ac adapter with reverse polarity. From then, its dead. I am searching at the board in order to find the diode with must be there in order to protect but i cant locate it.
    Can anyone help or provide a schematic for that board ?
    Thanks in adavanced.
  • atsio
    • Oct 2013
    • 819
    • Greece
    Re: HP 6910p reverse polarity issue
    Try those, one is UMA the other Discrete
    https://cdn.badcaps-static.com/pdfs/...42bb0c2769.pdf
    https://cdn.badcaps-static.com/pdfs/...ac17446eca.pdf
    • mpikou
      • Jun 2013
      • 58
      • Greece
      Thank you VERY much for the schematics and the reply.
      I cant locade the diodes to the board... could you please help me ?
      Here are photos of the board.
      http://imageshack.com/a/img901/6906/BlJKfe.jpg
      http://imageshack.com/a/img540/3535/xOq3Jx.jpg
      http://imageshack.com/a/img538/9500/jFcn3e.jpg
      http://imageshack.com/a/img913/7939/KgJ51M.jpg
      • dj_ricoh
        • 2073
        • uk
        Did you saw,smell or hear something?
        If not discharge the board and give it one more try.
        • mpikou
          • Jun 2013
          • 58
          • Greece
          Nothing smells, no sound at all and not something burn/wrong with optican observation.
          Fully disharged and issue persists.
          • atsio
            • Oct 2013
            • 819
            • Greece
            What's the current drawn when you plug in lab supply?
            • mpikou
              • Jun 2013
              • 58
              • Greece
              If i have undertand correct what you are asking, its 19V.
              • R_J
                • Jun 2012
                • 9608
                On page 37 of the first diagram, PCN1 is the input jack, the adaptor voltage should go through coil PL1 and be on (VIN) on the next page (38) VIN comes to fet PQ3 & PQ5 etc. I would check parts in that area. Is there voltage on P2 or P4 or B+
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3627
                  • slovakia
                  post photo of area around power connector. both side.
                  • atsio
                    • Oct 2013
                    • 819
                    • Greece
                    Όχι τα αμπέρ που τραβάει από το τροφοδοτικό σου, όταν το κουμπώνεις (χωρίς να ξεκινήσεις το laptop).
                    • mpikou
                      • Jun 2013
                      • 58
                      • Greece
                      PL1 its ok, PQ5 ok, but i cant locate PQ3.
                      Here are the photos.
                      http://imageshack.com/a/img537/4334/jiMNoL.jpg
                      http://imageshack.com/a/img910/5082/Oe3G2k.jpg
                      Ευχαριστώ για την διευκρίνηση.
                      • Dev Goose
                        Help Needed: Reverse Polarity Issue on HP EliteBook 840 G4 – Where Do I Begin?
                        by Dev Goose
                        Hi everyone, I recently acquired an HP EliteBook 840 G4 (6050A2854301-MB-A01) that I'm hoping to bring back to life. I'm fairly new to laptop repairs but eager to learn and willing to put in the effort to understand and fix this. Any advice or guidance would mean a lot!
                        What Happened
                        The issue started when the laptop was accidentally plugged in with reverse polarity. Before this incident, the laptop would show a power/charging light whenever it was plugged in. However, now it's completely unresponsive—no lights, no power, nothing. I've been doing some research and understand
                        12-13-2024, 03:13 AM
                      • Kervin Mathumbu
                        Asus E410 only works on battery after reverse polarity
                        by Kervin Mathumbu
                        Hi everyone. Fixed my AC and despite trying to be extra careful, I reversed polarity and got a notable pop sound. Now the PC will only work on battery. Windows still shows the battery as charging but the count actually goes down until empty (I have two of the same laptops).
                        I have board R3.0 so the schematics on another thread here do not match mine. I have tested the BQ charge IC and my pin 1, 2 and 3 have 3.35v each - instead of 18v or 19v. Could this be a bad BQ IC or capacitor? Any thoughtful advise sould be greatly appreciated.
                        Mobo shows no visible sign of a fried...
                        07-15-2024, 11:26 AM
                      • rounin
                        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                        by rounin
                        I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                        🛠 Original Issue
                        The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                        04-19-2025, 01:18 AM
                      • ugamazing
                        Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                        by ugamazing
                        I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                        We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                        12-17-2024, 07:05 PM
                      • shahnld
                        Lenovo legion 5 pro startup issue
                        by shahnld
                        Good day Experts
                        I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                        A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                        And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                        08-24-2025, 12:31 PM
