Macbook 13" A1278 2009 (K24) No power
  • sylver
    • Jun 2015
    • 29
    • France
    Hi electronics gurus
    For the first time I'm trying to repair a Macbook logic board
    No green light on charger (just a very low alternative light switching between green and orange), SMC bypass not working. No sign of life whatever I do ! System is also not doing anything when trying to start it from a known good and fully charged battery !
    I got schematics and brd and I started to look for the issue !
    What I've seen when the magsafe power is connected is :
    - Fuse F6905 is OK
    - G3Hot is OK (3,44V)
    - Q7001 pins 1/2/3 are 0V (instead of 16.44v as measured on another board) ! After checking, it appears that it is shorted with ground ... What I've also seen is that U7060 output is 0v (instead of 14.36V as measured on another board).
    - Q7000 almost OK (pins 1/2/3 : 16,97V, pin 4 : 15,44V but pin 5 which is connected to pin 5 of Q7001 is -0.06V instead of 16,97V)
    At this point it is not clear to me where I should check to continue progress ! Could anyone help me to understand what could be the issue ?
    Check page 59 of attached document to find schematics related to my issue
    Thanks !
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: Macbook 13" A1278 2009 (K24) No power
    voltage on u7000 ?
    pin4 of q7000 must be low .... lower then 15volt to open good fets. generally 5-7volt.
    first check u7000. ill focus here my looking.
    • sylver
      • Jun 2015
      • 29
      • France
      thanks for your answer !
      Pin 5 (ACIN) of U7000 is 3,95V not sure if it's OK ?
      I've found that C7020/C7021/C7022/C7023/C7027 capacitors (parallel mounted) are grounded (O ohm to ground) ... Maybe one of them is dead ? I guess that I have to remove them to check them, but before doing that I'd like experts point of view ...
      About pin4 of q7000, I have a working board (a little bit different as it's a late 2008 and not a mid 2009) and when there is no battery plugged (not tested with battery plugged) I have the same voltage on pin4 of Q7000 !
      • sylver
        • Jun 2015
        • 29
        • France
        Ok I removed C7020 that was actually the problem ! At least a part of the problem !
        Now the Macbook is booting from battery but not yet from magsafe (led is now low intensity green)!
        I'll try to find a replacement capacitor and see how it's working once replaced
        Could anyone help me to find the reference of this capacitor ?
        It's one with 22 1E97 written on it, the data sheet gives :
        Code:
        C7020
        22UF
        20%
        25V POLY-TANT CASE-D2-SM
        • BCConnectionLLC
          • May 2015
          • 47
          Check the One wire part. You are either missing 3.42V or ACOK (3.3V) since it wont boot from Charger Id say you have a U7000 issue where ACOK is made.
          • sylver
            • Jun 2015
            • 29
            • France
            Thanks for the advice, I'll check this part of the board for sure ! I received a replacement chip for u7000 so if I need to replace it, it will be done quickly
            Regarding the capacitor I have to replace, I think that it's the package is "EIA 7343-20 (Kemet V, AVX Y) : 7.3 mm x 4.3 mm x 2.0 mm".
            I just have to find some of them online now
            • dellxps15
              • Feb 2014
              • 1598
              • italy
              check again pin 4 of u7000 as it must be 4 volt.
              • sylver
                • Jun 2015
                • 29
                • France
                Ok I checked 1-wire output at U6901 level :
                - IN/A & IN/B (Pin 1&2) are 0V (which are SMC_BC_ACOK signal)
                - VCC (Pin 5) is 3.4V
                - OUT Y (Pin 4) is 0V
                So it confirms that U7000 is KO ?
                dellxps15 : you mean pin 4 of Q7000 I guess, it's still 15.4V (with or without battery plugged) ...
                It's time to change U7000, right ?
                • dellxps15
                  • Feb 2014
                  • 1598
                  • italy
                  post u7000 voltage.
                  • sylver
                    • Jun 2015
                    • 29
                    • France
                    I did quick check for U7000 (Magsafe & battery plugged) :
                    - Pin 1 (AGATE) -> 15.4v
                    - Pin 2 (CHGR_DCIN) -> 0v
                    - Pin 3 (ACIN) -> 3.99v
                    - Pin 4 is NC (VREF)
                    - Pin 5 (ICOMP) -> 0v
                    - Pin 6 (AGND) -> 0v
                    - Pin 7 (VCOMP) -> 0v
                    - Pin 8 (CHGR_VNEG) -> 0v
                    - Pin 12 (VHST) -> 3.40v
                    - Pin 16 (BGATE) -> 4.14v
                    - Pin 19 (VDD) -> 0v
                    - Pin 20 (VDDP) -> 0v
                    • BCConnectionLLC
                      • May 2015
                      • 47
                      Pretty sure CHRG_DCIN should be the voltage that the main power rail coming in reads. Around 16V-18V.
                      • sylver
                        • Jun 2015
                        • 29
                        • France
                        You're right, on a working motherboard I have 16.55V for CHRG_DCIN !
                        VDD & VDDC are supposed to be 4V also ...
                        I measure 96kohms between VDDP & ground on a working board, on the broken board I measure 0 ohm ...
                        • dellxps15
                          • Feb 2014
                          • 1598
                          • italy
                          check if l7000 is shorted.
                          check if q7020 q7021 are shorted.
                          if not remove u7000 and see if pin 2 voltage comes.
                          • sylver
                            • Jun 2015
                            • 29
                            • France
                            Q7021 seems to be shorted (between pins 1/2/3 & 5, I have 42 ohms in both ways)
                            How to check L7000 ? It seems to be 0ohm, but I have the same when checking L9701/L7400/L7401 ... I not sure my multimeter is very precise (I'll test with a better one tomorrow if needed) ...
                            I've ordered a replacement chip for Q7021 (RJK0305DPB), I'll have to wait to receive it to check if it solves all issues ...
                            Thanks a lot for your help
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5072
                              • New Zealand
                              Inductors will show a very low DC resistance normally. If you get no reading, or it is very high, then the inductor is open-circuit or otherwise bad.
                              You have to check actual inductance and\or do a ring test to ensure the inductor has no shorted turns. But likely they are OK.
                              -David VanHorn
                              • sylver
                                • Jun 2015
                                • 29
                                • France
                                Ok thanks for your answer, I did compare with L7000 on a working logic board and it shows the same very low resistance !
                                I'll keep the thread updated when I'll get the Q7021 replacement chip
                                • dellxps15
                                  • Feb 2014
                                  • 1598
                                  • italy
                                  put multimeter in diode mode to measure short, not ohms. if u have a good multimeter, 000 001 is short otherwise not. remove q7021 and check again pins.
                                  remember to check pin 2 of u7000 too. probably both u7000 and q7021 are bad.
                                  • BCConnectionLLC
                                    • May 2015
                                    • 47
                                    Id replace U7000 and go from there.
                                    • sylver
                                      • Jun 2015
                                      • 29
                                      • France
                                      Thanks guys,
                                      I tested q7021 with a good multimeter with diode test mode and it is definitely dead !
                                      So I removed q7021 and now the light of on the magsafe is turning bright green !
                                      I didn't try to turn on the macbook from magsafe or to plug the battery at the same time yet ...
                                      • dellxps15
                                        • Feb 2014
                                        • 1598
                                        • italy
                                        q7021 supply 12.5 volt, so without it pc wont power on.
                                        but green light means pc is almost alive
                                        • Adogabriel100
                                          Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
                                          by Adogabriel100
                                          Hey! This is a A1278 macbook 2011.
                                          Problem: Not turning on / No green light
                                          Im using by3200s charger.
                                          Voltajes:
                                          PPBUS_G3H = 12.26v
                                          SMC_RESET_L = 3.3v
                                          PP3V42_G3H = 3.42v
                                          U7000 =
                                          Pin 1 CHGR_AGATE = 0v
                                          Pin 2 CHRG_DCIN = 19v
                                          Pin 3 CHRG_ACIN = 4.6v
                                          Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
                                          Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
                                          Pin 12 PP3V42_G3H = 3.42v
                                          Pin 13 CHRG_RST_L = 3.3V
                                          Pin 14 SMC_BC_ACOK = 0.8V
                                          Pin 19 PP5V1_CHRG_VDD = 5.05V
                                          Pin 20 PP5V1_CHRG_VDDP = 5.03V...
                                          04-01-2024, 01:02 PM
                                        • Rezendes
                                          Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
                                          by Rezendes
                                          Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
                                          I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
                                          The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
                                          05-10-2024, 02:18 PM
                                        • pcbmaniac
                                          MacBook A1278 (3115) No PPBUS_G3H Issue
                                          by pcbmaniac
                                          Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
                                          I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
                                          1. U7000 Measurements:
                                            • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
                                          2. Resistors:
                                            • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
                                          Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
                                          • If I also decide to replace the SMC, do I need to order it pre-programmed,
                                          12-02-2024, 04:12 PM
                                        • sizar00740
                                          macbook pro 13 inch a1278 820-2879
                                          by sizar00740
                                          please clear me this bios efi macbook macbook pro 13 inch a1278 820-2879...
                                          07-30-2025, 10:21 AM
                                        • envym
                                          MacBook Pro 2018 with Activation Lock
                                          by envym
                                          Hi everyone!
                                          I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                                          I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                                          06-27-2025, 08:54 AM
