macbook pro 13 inch a1278 820-2879
  • sizar00740
    • Jun 2022
    • 13
    • ALGERIA
    please clear me this bios efi macbook macbook pro 13 inch a1278 820-2879
  • sizar00740
    • Jun 2022
    • 13
    • ALGERIA
    ITS DONE THANKS
    • shiyab
      • Sep 2023
      • 1608
      • india
      Originally posted by sizar00740
      ITS DONE THANKS
      post snid
      • CG_Dionysos
        MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
        by CG_Dionysos
        I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
        • Model: A1707
        • 15-inch, Mid 2017
        • 3.1 GHz Core i7
        • 16 GB RAM
        • Radeon Pro 560
        • 1 TB SSD
        • Board number: 820-00928-A
        I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
        Thanks in advance!
        Greetings from Germany...
        09-16-2025, 06:43 AM
      • Adogabriel100
        Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
        by Adogabriel100
        Hey! This is a A1278 macbook 2011.
        Problem: Not turning on / No green light
        Im using by3200s charger.
        Voltajes:
        PPBUS_G3H = 12.26v
        SMC_RESET_L = 3.3v
        PP3V42_G3H = 3.42v
        U7000 =
        Pin 1 CHGR_AGATE = 0v
        Pin 2 CHRG_DCIN = 19v
        Pin 3 CHRG_ACIN = 4.6v
        Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
        Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
        Pin 12 PP3V42_G3H = 3.42v
        Pin 13 CHRG_RST_L = 3.3V
        Pin 14 SMC_BC_ACOK = 0.8V
        Pin 19 PP5V1_CHRG_VDD = 5.05V
        Pin 20 PP5V1_CHRG_VDDP = 5.03V...
        04-01-2024, 01:02 PM
      • Rezendes
        Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
        by Rezendes
        Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
        I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
        The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
        05-10-2024, 02:18 PM
      • pcbmaniac
        MacBook A1278 (3115) No PPBUS_G3H Issue
        by pcbmaniac
        Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
        I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
        1. U7000 Measurements:
          • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
        2. Resistors:
          • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
        Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
        • If I also decide to replace the SMC, do I need to order it pre-programmed,
        12-02-2024, 04:12 PM
      • Bmet
        MacBook Pro 13 inch A2238 M2 stuck on 5V
        by Bmet
        I have a MacBook Pro 13 inch A2238 M2 and it was stuck 5V with 0 amps. I measured some important lines and I found a short on PP3V8_AON_MPMU_ISNS_VIN, I tried injecting 1v and I saw heat coming from the mPMU so I removed the pmu thinking that was the problem. I don't know why I didn't check the other side of the border but there it was, a shorted cap. I replaced the cap and the short was gone, so I reballed the PMU and put it on again but voltage was still stuck at 5V and the current was fluctuating between 0 and 0.45 amps. I checked under the thermal camera and I saw the mPM...
        04-02-2025, 05:02 PM
