well k53SV turning on 0.02 amp of consume WTF ?
    well received this one , and im stucked a bit .
    first no schematic ... second i really dont find any clock gen on this board ..
    third , i got 3.3 and 5 volts ok , all outher coils 0 volts .
    made few tests with KBC , it seemd ok , but i replaced even like this ,, still the same .
    replaced HM65 the same , bios replaced the same .
    it simple does turn on when pressing on off , but consume is 0.02 amp .
    replaced cpu as well , still the same ,
    any taughts ?
    gpu could make this ? the only thing i didnt touched .
    but what about the clock gen ??? really there is no QFN for clockgen, any help will be welcome
    Re: well k53SV turning on 0.02 amp of consume WTF ?
    OHH ANOTHER INFO , ALL PINS OF BIOS GOT 3,3 VOLTS , EXCEPT PIN 4 gnd . , ISN'T THAT WEIRD ?
      no ideas :P ?
        Focus on bios chip.
        Not all pins got 3.3v. Some of them are data and got under 1v
          Do you got a scope? See if you got any activity.
            no i dont have , yet exactly , i should have lower voltages on pin 1 2 and 5 and 6 , but all pins are with 3.3 ,,, and that what is killing me and without schematic , pain in the ass , weird is that both things that can make SPI to be inregular is the KBC or PCH both were replaced and still the same issue.
              If you lift up bios same 3.3v on pads?
              Maybe the bios is culprit inside
                sorry ricoh i was out in formation
                well lifted the bios chip , and got 3.3 volts on pin 8 7 3 and 2 , all outher are 0 in this moment without the bios , bether that before , i tryed several bios dumps bnut always the same , replaced bios chip and the same , still , i got here my original dump if someone want to build me a new bios ,
                  well even after reprograming with another bios now , once i solder it , 3.3 volts on all pins except , pin4 .
                  now im thinking spi usually come from PCH , replaced the pch and makes the same as the outher .. got stuck here
                    I know its stupid but i have to say it.
                    Power button its ok? I swear i found a few with power button fubar.
                      u can make led diode bios check like i see somewhere./youtube?/
