Toshiba L750 not charging/How charger ic check battery charge
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3588
    • slovakia
    Hello, have one toshiba l750 that not charging battery. It have ISL88731 charger ic.
    When i connect battery, it start charging/voltage rise to 12.7V/, but after few seconds it stop charging. I have new replacement battery that is fully charged and it too not getting charged, but when i want to start on battery, it show me led that battery is low charged.
    I think its something bad in checking battery charge. How charger ic detrect battery charge level?
  • lti
    • May 2011
    • 2548
    Re: Toshiba L750 not charging/How charger ic check battery charge
    The schematic has been posted a few times on this forum. Here's one thread with the schematic:
    https://www.badcaps.net/forum/showthread.php?t=41524
    The ISL88731 datasheet can still be downloaded from Intersil:
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3588
      • slovakia
      have it all. but it wont answer my questions
      • Tomas9t1
        • Apr 2015
        • 41
        • Lithuania
        Hey mate, can u upload pictures of motherboard?
        • Tomas9t1
          • Apr 2015
          • 41
          • Lithuania
          try removing this Nec Tokin capacitor with 4 330uF capacitors, be sure to check where's + and -
          • lorins_core
            BlackSmith
            • Dec 2012
            • 551
            • Philippines
            i see mr. tomas9t1 have a 95% point.
            i have also encountered before have same problem of this model
            i try to change nectokin. but i used 6pcs of 220uf tantalum...
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3588
              • slovakia
              do u think that capacitor on cpu rail who dont have voltage on it until start, will have something with charging ic?
              • lti
                • May 2011
                • 2548
                I don't think these laptops are old enough to have bad caps. Even if that cap was bad, there is no way that the CPU VRM filter caps would prevent the battery from charging.
                I didn't look at the datasheet much, so I don't know anything about this charging circuit. Since I have an L750, I should spend some time reading the datasheet to see how it works.
                • Tomas9t1
                  • Apr 2015
                  • 41
                  • Lithuania
                  Well I'm talking from my experience, just try , you might discover something new
                  • lorins_core
                    BlackSmith
                    • Dec 2012
                    • 551
                    • Philippines
                    ok its up to you... based only to my experience before...
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3588
                      • slovakia
                      Try it an nothing changed.
                      • rievax_60
                        • May 2012
                        • 897
                        • australia
                        The battery charge state is usually read by the EC directly from the battery via SMBUS.
                        I cant see anything in the charger IC that allows for remote reading of the battery voltage.
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3588
                          • slovakia
                          i know. thats why i search for some low budget SMBUS reader.
                          gauging for battery charge is build in charger ic so try to replace it.
                          • rievax_60
                            • May 2012
                            • 897
                            • australia
                            Are you certain that the batteries are ok? What does Windows say about the state of the batteries?
                            What does the battery voltage settle back to after the charging turns off?
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3588
                              • slovakia
                              when i insert old battery it show it charge but voltage drop few seconds after rising to 12.4V. with new battery start charging but after few seconds voltage drop. even when new battery is charged, when i try to start on battery it show battery is low
                              • techfreak9356
                                Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                by techfreak9356
                                I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                09-14-2023, 11:10 PM
                              • Klevjetack
                                Charge a L19D3PDA battery externally from the laptop
                                by Klevjetack
                                Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                                03-05-2024, 07:26 AM
                              • YellowJacket
                                Battery charger - STIHL AL 300
                                by YellowJacket
                                Hi friends,
                                I got to fix STIHL AL 300 battery charger, for mower machines, which works fine only when the battery is discharged ( haven't tried it already, since I got only fully charged battery, but that's why I have been told ). When the battery has some % of voltage, the charger doesn't work. In this case, the red LED starts to flash 10 times, and there is no voltage at the output. The customer tried more batteries, and it worked like this with all tried batteries ( so looks like not a battery related issue ).
                                I would try to discharge the battery ( with few 12V...
                                08-02-2023, 06:18 AM
                              • flat-earther
                                ASUS X54H laptop thinks it's always charging even with charger unplugged
                                by flat-earther
                                The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                Windows also shows ''Plugged in'' when charger is not connected.
                                This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                If I let battery run out and say it has 3% Windows will...
                                06-24-2025, 09:32 AM
                              • budwich
                                Lithium 12v tool battery charger... no negative connection?
                                by budwich
                                I have a drill and battery but no charger so I bought a "universal charger" 120ac in ... 12vdc out (not really universal in lithium world). Anyway it has three contacts, positive, negative and "T" (temperature sensor). I connected those contacts to the contacts on the battery. No charging happened and only the status light is on (green solid) which the label indicates "100% charged".... but the battery isn't near that at around 9v and dying. There doesn't appear to be any difference whether the battery is connected or not. I got suspicious and pulled the...
                                03-18-2025, 09:12 AM
