Lithium 12v tool battery charger... no negative connection?
  • budwich
    • Jul 2015
    • 3097
    I have a drill and battery but no charger so I bought a "universal charger" 120ac in ... 12vdc out (not really universal in lithium world). Anyway it has three contacts, positive, negative and "T" (temperature sensor). I connected those contacts to the contacts on the battery. No charging happened and only the status light is on (green solid) which the label indicates "100% charged".... but the battery isn't near that at around 9v and dying. There doesn't appear to be any difference whether the battery is connected or not. I got suspicious and pulled the thing apart. Started looking for basic stuff like broken contacts, loose components and checking some voltages in (120vac), 165v"DC" after the basic rectifier stage at the input (unfiltered). Then I looked at the output contacts. I could see how the positive and "T" contacts were connected, but for the life of me can't see how the negative contact does anything as there is no connection path on the board to any part of the circuit. Is this some new way of charging lithium batteries... charging thru the temperature sensor (sensor measured ~13Kohms... room temp Click image for larger version
Name:	charger board.jpg
ID:	3595910 Click image for larger version
Name:	charger inside.jpg
ID:	3595911 ) ???
    I can't see how the charger could ever work. Having said that, is there some sort of connection / component that I could add to make it work? Attached is picture of the back side of the board (circuit side) and the component side.
    Anyway help with understanding what the heck is happening with this "design" and how can I "fix" it would be greatly appreciated... and maybe save my tool and battery from the recycle bin.
  • Sam Scarbo
    • Oct 2023
    • 38
    That unconnected contact is not the -ve terminal. The top contact is, which is connected to the -ve lead of the electrolytic cap C3.
      • 31254
      that looks very incomplete.
      can you read the part number on the chip? i think it's just a cheap psu
        • 31254
        btw, for vague stuff charging, look into a clone B6 charger.
        those are good.
        • budwich
          • Jul 2015
          • 3097
          My bad... I should have done more labelling on the picture. There might be confusion on the "flip" between the two pictures. . I am also going by the labelling on the shell which has the negative going to the contact highlighted. I think the "T" contact is the one that you are alluding to. Sorry for the confusion. Click image for larger version
          • budwich
            • Jul 2015
            • 3097
            My guess (very small numbering) is GG1052 and the second number on this small chip is maybe BO7L2435.
            As for "incomplete", what area are you looking at particularly?
              • 31254
              http://en.cokintech.com/product-item-18.html
              that schematic is probably close
              • budwich
                • Jul 2015
                • 3097
                Thanks... I will see if I can follow the "hint". I don't see how the "T sensor" feeds into this. The "RJ0!" looks somewhat suspiciously missing.... but it only connects some traces together but not to the Negative lug / contact. Looking at the RH02, that appears to be some sort of "zero ohm fuse".... maybe?
                ADDED: I think I see how the RJ's are. They are placed for changing which contact is + and -.... basically moving it from RJ02 to RJ01 reverses the polarity.
                • budwich
                  • Jul 2015
                  • 3097
                  After looking the schematic that was linked by Great Sage, now I think I see what you are saying. The charger does not actaully use the "T sensor" connection AND the case is MISLABELLED. The "Tsensor" contact on the charger is actually the negative contact. Hopefully, I have that right. Thanks.
                  • budwich
                    • Jul 2015
                    • 3097
                    I just did a quick test using the "new found epiphany" and the charge light is now in "charge mode". Hopefully, the GG1052 has enough smarts in its internals to keep the thing from over charging. Assuming the charging current is less than ~1amp and voltage is contained (open circuit was 13.4v DC), the battery should be ok?
                    • budwich
                      • Jul 2015
                      • 3097
                      I did one charge cycle. The unit switches to "100% - green led" when done. Not sure if it accomplished the full charge... have to see how long the drill lasts.
                      thanks again for the guidance on this that got my drill back in service.
                        Bauer tool battery pack charging with a HERCULES charger modification
                        The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                        Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                        05-06-2023, 12:17 PM
                      • rex98
                        HP DMI Tool
                        by rex98
                        HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
                        DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
                        The DMI Tool given here are for personal use only.
                        DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
                        You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
                        from it, and that you please credit the author...
                        07-02-2025, 05:51 AM
                        NVDC charger configuration...
                        11-05-2024, 03:28 PM
                      • flat-earther
                        how to prevent a connected charger from draining battery when not charging?
                        by flat-earther
                        I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                        So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                        but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                        So the battery is backfeeding the charger and being drained.
                        How can I prevent...
                        08-07-2025, 01:04 PM
                      • flat-earther
                        ASUS X54H laptop thinks it's always charging even with charger unplugged
                        by flat-earther
                        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                        Windows also shows ''Plugged in'' when charger is not connected.
                        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                        If I let battery run out and say it has 3% Windows will...
                        06-24-2025, 09:32 AM
