DV6-3113ST No +vgacore power
  • ahmetozay
    • Jul 2013
    • 73
    • turkey
    Hello, this unit came as there was no picture on the screen. it takes 1A and stops there, also with debug card it shows DIMM as error. I replaced several rams but still shows DIMM error. Then i checked +vgacore and it was 0v.
    19v comes to PU13 which is vgacore chip
    5v comes to VDD and VDDP
    0v comes to EN/DEM
    Motherboard model is: DA0LX6MB6H1 Rev.H
    Attach is the pdf schematic.
    Any advices welcome. Thanks
  • khaahk
    • Dec 2013
    • 812
    • Estonia
    Re: DV6-3113ST No +vgacore power
    Some boards only the upper memory slot works when one dimm installed. Secondly, bios would be my guess...
    • ahmetozay
      • Jul 2013
      • 73
      • turkey
      Thanks for the reply, i tried both dimm slot with different rams, also i tried working bios from the same model. i flashed both the kbc and main bios.
      all i got it gets 1A and stays there, Debug card shows DIMM error and the board has no +vgacore voltage. Any advices welcome thanks.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3627
        • slovakia
        no EN signal=no power. EN come from PCH
        • dj_ricoh
          • 2073
          • uk
          ATI Mobility Radeon HD 5650 Graphics
          start from there !
          • ahmetozay
            • Jul 2013
            • 73
            • turkey
            start from there !
            Is there something special that you know? If so would you kindly share with us please? Thanks
            • dj_ricoh
              • 2073
              • uk
              my friend you need to start with a good reflow!
              do you remember how was the thermal compound ? hard? did it had thermal sponge on video ?
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                If it doesn't have +vgacore i doubt it's going to be the GPU. The VRM will work even if the GPU chip is removed from the board.
                A working TV? How boring!
                • ibrahim_yas
                  Banned
                  • Nov 2015
                  • 20
                  • 86159159666
                  thanks for sharing
                  • Attif
                    Attif
                    • 49
                    • pakistan
                    thakssssssssssssssssssssssssSSS
                    • lebana
                      • Jan 2015
                      • 81
                      • sudy
                      thank u
                      • sham20
                        • May 2018
                        • syria
                        thanks
                        • victor_quiroga
                          • Dec 2014
                          • 62
                          • argentina
                          Gracias
                          • beal
                            • Jul 2017
                            • 122
                            • IR
                            thanks
                            • sazli05
                              • Mar 2016
                              • 6
                              • tr
                              0v comes to EN/DEM
                              Thank you come easy
                              • bart64
                                ASUS M5A99FX Po Motherboard DIMM Issue , DIMM led keeps flashing after defective DIMM replaced.
                                by bart64
                                After my ASUS motherboard had random freezes and lockups, i found out that a defective dimm caused the issue, but after change the red indication led on the board keeps flashin with new dimm memory . Reset of the pushbuttion or reset of the cmos does nothing. After the damage one FET near the dimm gets very hot and also some smoke appeared of probably small smd resistors or ic probably. After replacement the FET still takes to much power and burns. When the regulator/ power ic close to the dimms UP1642P is removed the fet keeps cool so I decided to order this and replace it with a new one. But...
                                10-18-2025, 05:51 AM
                              • Novgorod
                                Asus Strix Z270i Gaming dead DIMM troubleshoot
                                by Novgorod
                                Hi!
                                I have an Asus Z270i mini-ITX board with a dead DIMM slot (the one further from the CPU). The board POSTs with only the other DIMM populated but gets stuck with the DRAM error LED when the bad slot is populated. The test RAM and CPU are known working (confirmed in a different board, both memory channels are fine). The board was working for many years in a watercooled system and had a tiny bit of corrosion in different places (which came off without issues) and no visible component or trace damage.
                                What are the steps for DIMM (DDR4) socket troubleshooting? Since the...
                                07-13-2024, 02:35 PM
                              • eccerr0r
                                DDR3/DDR4 laptop SODIMM to desktop DIMM adapters
                                by eccerr0r
                                Anyone have/use these SODIMM to desktop DIMM adapters, well, not to convert signaling types but just change socket types. Are they stable? Do they slow things down and force downclocks?
                                I have an unused DDR3 4GB SODIMM and have a need for a 4GB DDR3 DIMM. Wondering if I should:
                                - buy a 4GB DIMM (and selling the 4GB SODIMM seems unlikely)
                                - get an adapter for the SODIMM?
                                - Find a cheap 8GB DIMM somewhere and hope it's not a SODIMM...
                                Though DDR3 is my highest technology module out there I suspect I really should be getting 8GB modules especially for a...
                                03-02-2022, 01:56 AM
                              • mcplslg123
                                HP 2000 Dimm Display
                                by mcplslg123
                                Model:HP2000 series
                                M/B:Newton_CR&HR_HPC MV_MB_V1
                                Problem is dimm display. I can see image when mobile flash light is used. Exact schematic is not available for this m/b and i've linked a reference scheme which is almost similar.
                                Measurement on lvds connector.
                                01. Pin29-30(+VBAT)-19V
                                02.Pin27(LVDS_PWM)-3.3V
                                03.Pin26(BL_Enable)-3.07V
                                04.Pin5(LVDS_DATA)-3.3V
                                05.Pin4(LVDS_CLK)-3.3V
                                06.Pin3-3.3V
                                07.Pin1-2(LCDVCC)-3.3V
                                Not sharing other pin measurements as i think they are not relevant as i can see a dimm...
                                HP Compaq Notebook 431 Schematic 01015FY00-600-G
                                04-03-2025, 11:18 PM
                              • Chungalin
                                Repairing a DDR3 4GB DIMM with bad SPD EEPROM
                                by Chungalin
                                This is just for fun. Please don't tell me that a 4GB DDR3 is not worth this work.
                                I received a beeping PC that had a RAM issue: a single Kingston KVR1333D3N9/4G DIMM (part number 99U5471-012.A00LF). I noticed that the board beeped the same way either with this DIMM installed or without it. If I installed a second DIMM, the latter was detected, while the other one was like it didn't exist.
                                I replaced memory to fix customer problem, but I kept thinking about that faulty memory module. I considered that it could have a problem with SPD EEPROM and it simply was not detected...
                                07-20-2019, 07:37 PM
