Repairing a DDR3 4GB DIMM with bad SPD EEPROM
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    This is just for fun. Please don't tell me that a 4GB DDR3 is not worth this work.
    I received a beeping PC that had a RAM issue: a single Kingston KVR1333D3N9/4G DIMM (part number 99U5471-012.A00LF). I noticed that the board beeped the same way either with this DIMM installed or without it. If I installed a second DIMM, the latter was detected, while the other one was like it didn't exist.
    I replaced memory to fix customer problem, but I kept thinking about that faulty memory module. I considered that it could have a problem with SPD EEPROM and it simply was not detected at all, being otherwise as functional as before.
    Since I have a chinese XGecu TL866II+ EEPROM & Flash programmer, and wanted to play with it, I was curious to see if I could access SPD EEPROM without using SMbus. For this purpose I've cheched which pins of DDR3 DIMM go to SPD EEPROM:
    116 GND
    117 A0
    118 SCL
    119 A2
    236 Vcc
    237 A1
    238 SDA
    239 GND
    So, everything to access SPD is on last 5 pins (both sides). This pinout is different on each DDRx standard, beware! I've desoldered an end of a DDR2 socket from a bad motherboard (impossible to me to desolder the whole socket). Then I've wired socket pins to the programmer, maching the pinout of a standard 24C02 I2C EEPROM. WP pin (Write Protect) is not used because DIMM modules usually hardwire this pin to GND, thus enabling write operations to SPD.
    I've tested this thing by reading a good DIMM, selecting any standard I2C 2Kbit EEPROM in XGecu programmer (a CSI CAT24C02, for instance): success. Checked data with a SPD decoder Perl script: OK.
    Then I try the bad module: as expected, it just outputs 1's, and it fails any write operation. EEPROM is bad.
    I get a good 2Kbit TSSOP I2C EEPROM from an old 512MB DDR DIMM. Replace the one at DDR3 module. Read it successfully and decode data corresponding to the old DDR module. Then it comes the last problem: how to get valid SPD data for this module?
    I search the web for Kingston part number, adding "SPD registers" to the search. This returns several CPU-Z hardware dumps posted in forums by users asking for advice about some issue. I copy the hex dump and convert it to binary, program the EEPROM and DIMM is back to life again!
    • 31258
    Re: Repairing a DDR3 4GB DIMM with bad SPD EEPROM
    the eeprom data has nothing to do with the dimm maker, it has to match the actual ram chip specs.
    get the datasheet for the ramchips as a starting point.
    • Chungalin
      • Jul 2014
      • 423
      • Spain
      But, you should expect that same maker, same model and same part number, imply same chips or, at least, same chip specs. So it's not an illusion that the module is working right now with a cloned SPD from another DIMM.
      First, I searched just Kingston KVR1333D3N9/4G, but then I saw variations in part number (99U5471-012.A00LF), more precisely, in the "-012." part. After that I narrowed my search to just that part number.
        • 31258
        no you shouldnt, they used what they could get at the right price as they needed it.
        • brethin
          • Dec 2008
          • 1907
          Changing SPD data isnt hard and doesnt make bad ram good %99.9 of the time. You got lucky that was the problem on that stick.
            • 31258
            that's not really the issue, the issue is getting a good dump from the same ramchips or getting a datasheet and building a new descriptor table.
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              That is an awesome save Chungalin, nevermind the pessimists here in the thread
              I've done something equally crazy, maybe you will enjoy that read too
              https://www.badcaps.net/forum/showth...738#post543738
              • eccerr0r
                DDR3/DDR4 laptop SODIMM to desktop DIMM adapters
                by eccerr0r
                Anyone have/use these SODIMM to desktop DIMM adapters, well, not to convert signaling types but just change socket types. Are they stable? Do they slow things down and force downclocks?
                I have an unused DDR3 4GB SODIMM and have a need for a 4GB DDR3 DIMM. Wondering if I should:
                - buy a 4GB DIMM (and selling the 4GB SODIMM seems unlikely)
                - get an adapter for the SODIMM?
                - Find a cheap 8GB DIMM somewhere and hope it's not a SODIMM...
                Though DDR3 is my highest technology module out there I suspect I really should be getting 8GB modules especially for a...
                03-02-2022, 01:56 AM
              • bart64
                ASUS M5A99FX Po Motherboard DIMM Issue , DIMM led keeps flashing after defective DIMM replaced.
                by bart64
                After my ASUS motherboard had random freezes and lockups, i found out that a defective dimm caused the issue, but after change the red indication led on the board keeps flashin with new dimm memory . Reset of the pushbuttion or reset of the cmos does nothing. After the damage one FET near the dimm gets very hot and also some smoke appeared of probably small smd resistors or ic probably. After replacement the FET still takes to much power and burns. When the regulator/ power ic close to the dimms UP1642P is removed the fet keeps cool so I decided to order this and replace it with a new one. But...
                10-18-2025, 05:51 AM
              • SidneyCanadas
                93C46 and 93C56 EEPROM
                by SidneyCanadas
                I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                06-14-2023, 01:16 PM
              • dmccul2698
                Pioneer DEX-P99rs "No EEProm " diagnostic code.
                by dmccul2698
                Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
                1). Understand the schematic and check the connections between the EEProm and DSP
                2). Check the functionality of the EEProm
                I don't know if this is the unit's problem but it's a place to start.
                I have little to no electronic experience...
                04-08-2024, 05:32 PM
              • Novgorod
                Asus Strix Z270i Gaming dead DIMM troubleshoot
                by Novgorod
                Hi!
                I have an Asus Z270i mini-ITX board with a dead DIMM slot (the one further from the CPU). The board POSTs with only the other DIMM populated but gets stuck with the DRAM error LED when the bad slot is populated. The test RAM and CPU are known working (confirmed in a different board, both memory channels are fine). The board was working for many years in a watercooled system and had a tiny bit of corrosion in different places (which came off without issues) and no visible component or trace damage.
                What are the steps for DIMM (DDR4) socket troubleshooting? Since the...
                07-13-2024, 02:35 PM
