Acer 7730ZG power problem
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Hi, i got this notebook and it has blown charger. The DC jack was burned and work only by battery. It wont charge and i have 28ohm between + and -.
    Please advise what to check. On pin 19 of PU11 i have no shorting.
    I do not understand where go "VA" on page 33.
    ...the quieter you become the more you are able to hear...
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: Acer 7730ZG power problem
    i think "va" is voltage adapter, so its 19v. after system protection and stabilizing was ok, become vin as voltage input to dc/dc regulator.
    cmiiw
    • rtstorm
      • Feb 2012
      • 971
      • Croatia
      thank you for that, i think DC/DC (PU13) is ok beacuse laptop work on battery. What i need to check here? I have 28ohm to gnd measuring on DC jack.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4951
        • New Zealand
        Did you replace the jack? If it the jack burned it may have been bad, or a short could have pulled too much current through it - and if that were the case, something on the board should at least look overheated.
        Got photos of the power section and jack?
        -David VanHorn
        • rtstorm
          • Feb 2012
          • 971
          • Croatia
          Yes jack was burned and i replace it. I visualy check all component and i do not se burning damage.
          • Agent24
            I see dead caps
            • Oct 2007
            • 4951
            • New Zealand
            Do you have fuse PF7? Is it blown?
            -David VanHorn
            • rtstorm
              • Feb 2012
              • 971
              • Croatia
              Fuse is ok, i check it
              • rtstorm
                • Feb 2012
                • 971
                • Croatia
                i tnink i isolated the problem, but cannot find the failed component.
                • rtstorm
                  • Feb 2012
                  • 971
                  • Croatia
                  i noticed that continuity test have loop, every 2 sec it stop for 0.5 sec and then continue. This happen when measuring that 38 ohm from picture above.
                  • rtstorm
                    • Feb 2012
                    • 971
                    • Croatia
                    uhh i think i found problem. When the plus pin from DC jack burned it connected the layer inside the board. I try to poke it with wooden stick and it changed resistance to 150kOhm.
                    here is the pic.
                    how can i fix this??
                    • dj_ricoh
                      • 2073
                      yeee!
                      how many times i did that. on many models!
                      jump the wire straight to the fuse! melt some case plastic or some silicon to hold it!
                      • rtstorm
                        • Feb 2012
                        • 971
                        • Croatia
                        Ok but the shorting is in the hole on the board. How to fix that
                        • dj_ricoh
                          • 2073
                          solder wick!
                          and you need a soldering iron so it can fit inside.
                          and try to put it in the whole with the iron!
                          • rtstorm
                            • Feb 2012
                            • 971
                            • Croatia
                            Hmm ok i will try tomorow
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4951
                              • New Zealand
                              This is why photos should come first - it would be obvious from the damage to that hole, that it's the first thing to check
                              Maybe you can clear the hole with a drill? Not usually advisable, but in this case it might be a good idea. Then scrape some soldermask away and solder your wire to the trace, through the hole.
                              -David VanHorn
                              • rtstorm
                                • Feb 2012
                                • 971
                                • Croatia
                                hello, i chean the burned hole and laptop worked for one day and now again burned in that area. Can i bring 19V from DC jack to battery terminal and with that isolate the DC jack part of board??
                                • dellxps15
                                  • Feb 2014
                                  • 1588
                                  • italy
                                  my advice is: fixing layer burn is very very hard and when it burn, the smell is terrible.
                                  i tried to fix a board acer with that problem with a dremel and metallic tip. passed it perfectly alligned and straight and orizontal to the hole to try to make each layer isolate. after that a good amount of solder mask can keep the problem away.
                                  that board was almost all killed ans some component in the back was damaged and for a old pentium m740 a good repair worth its value, plus lcd connector on mainboard got burned too.
                                  http://i62.tinypic.com/sdhd1v.jpg
                                  • rtstorm
                                    • Feb 2012
                                    • 971
                                    • Croatia
                                    Is there any way to bypass the burned area?? So i can connect 19v direct to some component
                                    • rievax_60
                                      • May 2012
                                      • 897
                                      • australia
                                      Yes, you can connect the DC in to anywhere on the left side of the fuse shown in post 8. The wire doesn't have to be thick if it's kept very short. Wire from an IDC HDD cable easily handles 5A.
                                      • Destroyer-Br
                                        [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                                        by Destroyer-Br
                                        I'm working on an Acer Nitro 5 unit with the following specs:
                                        • Motherboard: LA-J871P Rev: 1B
                                        • Model: Acer AN515-55-59MT
                                        • S/N: NHQ7JAL00403906A973400
                                        • SNID: 03902728734
                                        Initial Issue
                                        The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                                        After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                                        04-17-2025, 08:18 PM
                                      • theone111
                                        by theone111
                                        3. Problem: TV shuts down
                                        07-22-2024, 10:36 AM
                                      • Duranitron
                                        Asus x512dk rev 2.1 power on problem
                                        by Duranitron
                                        When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                                        Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                                        11-26-2024, 10:22 PM
                                      • Bonaventure Vigil
                                        ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
                                        by Bonaventure Vigil
                                        Dear All,
                                        Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
                                        At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
                                        12-12-2024, 10:22 AM
                                      • justice171
                                        Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                                        by justice171
                                        I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                                        Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                                        1. Verified that all critical voltages are present:
                                          • 3.3V and 5V are always present if DC is plugged.
                                          • 1.8V on the BIOS chip is present.
                                        2. Checked the power button functionality:
                                          • When pressed, the voltage drops to 0V, indicating the button is functional.
                                        3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                                          • Confirmed connectivity is intact, ruling out issues
                                        11-26-2024, 12:39 AM
