gateway powers on with ac no battery charge light
  • blu
    • Sep 2013
    • 11
    • US
    I have a Gateway NS2273
    powers on with the ac adapter but does not show the charging light and os windows/linux reports it as plugged in not charging;the current battery life is at 50%.
    I have tested a known working power adapter and battery and it made no differnce.
    With the battery removed and the ac adaptor plugged in
    the charging pins from left to right report as follows 1 &2 are ground pin3-3.280 pin4-3.280 pin5-3.251 pins 6&7 start anywhere from 3.4 to 3.0 and slowly drop.
    Where should i begin to look for to test on the mobo ? Also does anyone have a schematic?
    Thanks in advance
    edit1-
    with ac adapter plugged in/battery plugged in and laptop powered off the chargins measure at pin 1&2 are ground, pin3-3.274v, pin4-3.274,pin5-0.281 ,pin6-11.41,pin7-11.41
    *note when i first apply my leads to pins 6 and 7 (with the ac adapter in and battery in) before it gives the reading i get the warning symbol on my fluke 115
    Unsafe voltage. Measured input voltage ≥ 30 V, or voltage overload condition (OL).
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: gateway powers on with ac no battery charge light
    is it right?
    • techfreak9356
      Vostro 3400 (LA-K033P) won't charge battery, everything else ok
      by techfreak9356
      09-14-2023, 11:10 PM
    • razenxd
      How can I charge that battery pack?
      by razenxd
      it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
      At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
      Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
      Now, I have noticed a few things.
      The "dead" battery, while connected to charger and NOT Charging will...
      12-05-2024, 06:11 AM
    • Rezendes
      820-3115-B No Orange Light, Won’t charge battery
      by Rezendes
      Hello, I have a MacBook 820-3115-B board that never shows an Orange light and goes straight to a green light and turns itself on when the ac adapter is plugged in. System won’t run off battery and turns off immediately when ac power unplugged. I believe the battery should be ok as it was a replacement not too long ago but it’s possible that’s the issue as most anything is possible I guess. I don’t have any spare batteries or donor boards although I have ordered 2 on the way. I have replaced U7000 and same results. I have also applied flux and reflowed the SMC IC and no change. Nothing...
      06-23-2024, 12:56 PM
    • stevenallauca
      HP laptop does not charge the battery, the light turns amber and then changes to white.
      by stevenallauca
      Hello everyone. I have a problem with an HP laptop, when connecting the charger the amber light comes on for 6 seconds, changes to white and does not charge, I have checked all the components with the multimeter and the values seem correct, I was guided by the diagram, I do not know if it is a problem with the BQ24728H charge controller, investigating it seems that the voltages given by the charge controller are correct, I made the measurements connected to the power source and without the battery:
      - ACN (BQACN) 19.6v
      - ACP (BQACP) 19.6v
      - CMSRC (BQCMSRC) 19.6v
      - ACDRV...
      09-23-2024, 11:30 AM
    • ruletero
      Acer a515-43 low battery charge voltage
      by ruletero
      Hi
      Acer A515-43
      LA-H801P
      Fail: Does not charge battery, has low voltaje on connector.
      Laptop didn't want to turn on, only charge led blinked.
      I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
      I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
      Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
      10-24-2022, 02:31 PM
