MBX-247 No Backlight
  • munichrepair
    • Nov 2014
    • 11
    so, the customer changed the display without pulling the battery first.
    result: everything works fine, but no backlight on the display.
    so what should i do, what should i test first?
    thx in advance
    p.s.: im an advanced beginner, so please be patient with me
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3582
    • slovakia
    Re: MBX-247 No Backlight
    SIO ic.
    • munichrepair
      • Nov 2014
      • 11
      where can i find that IC?
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3582
        • slovakia
        Biggest IC with pins. in your case is the EC NPCE791L/NPCE795L
        • dj_ricoh
          • 2073
          come on!
          check voltage on every pin on the LCd connector make a photo and mark pin 1
          • loser18
            • Nov 2013
            • 274
            But the image comes up?
            As ricoh said post voltage of all pins on LCD connector and carefully check around for burnt components...(best is to use microscope, if you have any)
            • dspok
              • Jan 2014
              • 553
              • Nepal
              should have blown 19v fuse in my opinion near or rear part of lvds connector.
              • tito78
                • 9
                • italia
                change fuse Backlight look neighborhood to the connector lcd
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3582
                  • slovakia
                  if u have luck u just blown fuse but mainly u short and blown whole trace of backlight signal from SIO, somust change SIO
                  • triplefour
                    by triplefour
                    09-13-2023, 10:43 PM
                  • DanPoka
                    Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                    by DanPoka
                    I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                    Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                    This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                    02-15-2025, 05:05 AM
                  • Comp_Pro
                    No Backlight Macbook A1990 820-01041
                    by Comp_Pro
                    Hello all,
                    Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                    Tests performed:
                    There is no backlight even with a good screen.
                    Backlight IC is receiving the correct support voltages.
                    Fuse F8400 ok
                    Current sense resistor R8400 ok
                    Backlight IC is receiving 3.3V on enable pin.
                    Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                    Backlight IC receiving 5V from PP5V_G3S
                    Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                    I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                    05-06-2024, 10:23 PM
                  • cheebster
                    iPad Pro 12.9 5th Gen Backlight Issue
                    by cheebster
                    Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                    Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                    Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                    The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                    Anyone...
                    05-20-2025, 09:17 AM
                  • canadaboy25
                    LG Flatron 24EN33TA No Backlight When Cold
                    by canadaboy25
                    I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                    I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                    03-07-2023, 12:23 AM
