MBX-247 No Backlight
    so, the customer changed the display without pulling the battery first.
    result: everything works fine, but no backlight on the display.
    so what should i do, what should i test first?
    thx in advance
    p.s.: im an advanced beginner, so please be patient with me
    Re: MBX-247 No Backlight
    SIO ic.
      where can i find that IC?
        Biggest IC with pins. in your case is the EC NPCE791L/NPCE795L
          come on!
          check voltage on every pin on the LCd connector make a photo and mark pin 1
            But the image comes up?
            As ricoh said post voltage of all pins on LCD connector and carefully check around for burnt components...(best is to use microscope, if you have any)
              should have blown 19v fuse in my opinion near or rear part of lvds connector.
                change fuse Backlight look neighborhood to the connector lcd
                  if u have luck u just blown fuse but mainly u short and blown whole trace of backlight signal from SIO, somust change SIO
