HP G62 AMD problem
  • marioo
    • Sep 2014
    • 8
    • croatia
    HP G62 AMD problem
    Hi
    I have problem with g62, original motherboard have standard second gpu problem ,and i order new from china. Problem with second one is normal start first time but after few minute it freezes and after that on another start only fan works and no boot image.
    They say to try change cpu Phenom N620 what i did and same thing he starts for few minutes and freezes and after that if i try to start only fan works.
    When i put processor on old motherboard (this one work lower gpu) processor don't start only fan works , but if i put him in and out few times it start only on old motherboard
    sorry for my english
    regards Mario
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: HP G62 AMD problem
    Reball the Northbridge. On G62 it is usually the NB not the GPU, even if you're getting no video. If you are getting 1 blink on caps lock on your keyboard, "CPU error", it's 100% the NB.
    If you reball or replace the GPU it may start and work normally for a while since a bit of heat will get to the NB as well, but then it will die again because it wasn't the GPU at fault to begin with.
    A working TV? How boring!
    • marioo
      • Sep 2014
      • 8
      • croatia
      hi
      i try reflow but no result and that the reason i bought new motherboard it cost 65$
      but problem is with new motherboard , they ( Chinese ) say problem is with processor ,and caps lock not blinking
      thanks
      • hazardus
        • Apr 2014
        • 105
        Was that motherboard new or refurbished or used?
        I had couple laptops with the same symptoms and on those the CPU sockets were the problem.
        But first check the caps around the CPU. Is there a big ass cap under the CPU socket at the other side of the motherboard?
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3627
          • slovakia
          dont have post card?
          • marioo
            • Sep 2014
            • 8
            • croatia
            it is refurbished
            • iT0mT0m
              Problem with motherboard Gigabyte X570S Aero G - no detect RAM
              by iT0mT0m
              I have problem with detection RAM on this motherboard. When I install CPU(Ryzen 5 2600, 5 4500 or 5 5600G) DRAM Led is lighting all the time. I tried reflash various verion of bios using Q-Flash method and that not resolve my problem. I tried reflash bios by SVOD 4 but that not resolve problem too. All voltages is correct and I don't see any low resistance on coils and other elements on motherboard. I tried replace memory to other and nothing. I don't know where is a problem(maybe connections between cpu and rams socket?). Actually I have boardview for this motherboard and I have...
              12-23-2023, 12:17 PM
            • rounin
              MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
              by rounin
              🛠 Original Issue
              ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
              04-19-2025, 01:18 AM
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • hopkok
              Legion 5 PRO, 3 boards, same problem, NM-D562 Rev. 3.0 motherboard
              by hopkok
              Hi friends, last week I got 3 same boards for repair (NM-D562 Rev. 3.0), same problem, power button light up, but motherboard wont start.
              3,3V_alw and 5V_alw, 1,8V_alw and 0,75V_alw presented on all 3 boards, no other voltages. 1,2V missing and if I checked schematic right, I need 1,2V and than can be +3VS and +5VS generated after getting SUSP_N signal from KBC? or vise versa?
              I checked for low resistance on coils, no low resistance.
              Anyone with same issue like me?
              Thanks for any help.
              05-24-2025, 04:21 AM
            • toti24
              (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
              by toti24
              dell precision m4600 laptop
              i7 2760qm
              8gb ram 750gb HDD
              intel hd 3000 integraded and nvidia quadro 2000m
              pleasea bear with me english isnt my language and ill try to be as clear as possible
              note i live in mexico in a very small town..
              thank you.
              laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
              the brick happened when i was installing win 10 using usb.
              used rufus and officia microsoft.iso
              it finished copying files from usb...
              03-06-2022, 08:39 PM
