Iphone 5s problem with brightness
  • highpulse
    i hate HP
    • May 2013
    • 1490
    • portugal
    im with a problem with the brightness of a iphone 5s , the strqange things is when i make some pressure on the screen , but specially on top , it fade out the light completely , seems like a bad contact on the sensor light , or could this be a screen problem itself ? i can make it giving good brightness when i give him a few soft spanks on the side ... anyone had this issue before ?
    thk in advance
  • dj_ricoh
    • 2073
    • uk
    Re: Iphone 5s problem with brightness
    did you try another screen?
    • cheap but honest guy
      • Sep 2014
      • united states
      i buy an iphone 4s with water damage, and after finish the work, i notice the same problem, i open it again and i fix it, also, don't use the auto brightness, select the brightness that you want on the settings, my phone was horrible, now is been working really good, i am glad i was able to fix it, is a 4s 32gb unlocked, and almost a year ago i pay 65 bucks for it, the screen has nothing to do with the light issue, is the connectors inside the device, also the dim light, but is hard to fix it, the dim light is a micro solder problem, you can sell the phone on places like ebay, and get the new 6, before the 5 will cost or lost the value
      • highpulse
        i hate HP
        • May 2013
        • 1490
        • portugal
        not mine , its from a client.
        • polytek
          • Dec 2013
          • 496
          • TUNISIA
          look at this, i'm not sure and i don't try this solution but i think it's real
          http://www.youtube.com/watch?v=LFTxFr1fiHI
          • highpulse
            i hate HP
            • May 2013
            • 1490
            • portugal
            well weird making pressure on the screen it remove all brightness , or some spanks make it give clear image .. and btw its a 5S
            does the screeen assembly usually bring the light sensor attached
            • smic717394
              by smic717394
              07-25-2024, 10:16 AM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • mmccomputer
              problem with replacing lcd screen
              by mmccomputer
              I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
              otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
              If anyone has any information on the subject...
              12-15-2024, 03:44 PM
            • jimjoe123
              LCD TV Green/Pink screen problem
              by jimjoe123
              I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
              Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
              Then each time...
              02-23-2020, 01:29 AM
            • Chrissygizmo
              Sony KD-55XG9505 lines on screen problem
              by Chrissygizmo
              Hello again everyone,
              This is my latest mission, to try getting this Sony tv back to normal working order…
              I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
              02-19-2025, 11:31 AM
