ATX brown wire sense range
  • harp
    • Jun 2022
    • 642
    • Planet Earth
    I thinking to modify some ATX ver 1 supply, and wonder what if I connect 10k pot on 12v and center tap on brown wire? What range of 3.3v correction can to expect, or something will blow up if I close to rails, leave narrow 3.3v range?
    It is KA7500B ic, but 3v3 sense is connected to TL431, I am not sure there is any connection between.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8340
    How did you get this idea and for what reason? I am just curious as I am drawing a total blank. Lol
      • 31254
      some psu's have an extra wire to the connector for voltdrop sensing.
      i doubt it will tollerate more than a volt before just shutting down.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8340
        I do understand what that wire does. But why fiddling with it?
        • harp
          • Jun 2022
          • 642
          • Planet Earth
          Yes, sorry I not mentioned...
          Idea came from me myself, and with reason to can adjust low voltage for testing purpose (not computer). So you go for 2.5v - 4.0v range?
          Supply have also -5v (white) and come to me without case and wires. It almost begging me to be incorporated somewere
          • temyth
            • Jan 2024
            • 45
            • Brazil
            why dont you place the 10k pot between the feedback rail and the optocoupler that feeds back the primary that way you can fully "simulate" the feedback.
            • harp
              • Jun 2022
              • 642
              • Planet Earth
              I am not sure what you mean, can you sketch some circuit with pot placement?
              • wnlewis
                New wire for my RDE3340 Whirlpool electric range
                by wnlewis
                OK. I got the rocker switch figured out thanks to the good advice on this forum.
                Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                This is a Whirlpool RDE3340 electric range.
                The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                Where may I find parts...
                01-08-2025, 11:21 PM
              • kalemaroni
                Dell DC Brown wire
                by kalemaroni
                There are 3 pins on the back of this DC jack. Centre both left and right edges are the grounds for the black wires and a centre bottom is for the red wire. Where does the brown wire solder to? ...
                08-26-2025, 10:10 AM
              • emeskay
                Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                by emeskay
                We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                08-06-2024, 07:13 AM
              • technicalspecialist
                Vintage fan repair, copper wire question
                by technicalspecialist
                I currently have a customer's vintage fan on the work bench to repair.
                It uses an induction motor with 4 poles. One of the poles is open.
                I couldn't find the break so i cut off the original wire.
                I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                The enamelled copper...
                03-16-2023, 12:54 PM
                Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                12-16-2023, 08:39 PM
