Asus G513QE keyboard and backlight not working
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3622
    • slovakia
    Have this Asus G513QE with keyboard, keyboard backlight and Led backlight not working. other works ok.
    i measure all voltages ok on keyboard, KB backlight and Led backlight. looks like a kbc error.
    but as laptop works i think it cannot be bad. maybe its FW. have anybody some hint for this?
  • mon2
    • Dec 2019
    • 14634
    What is the voltage on the KB and LED backlight rails? Was the keyboard replaced? Does the keyboard feature a backlight?
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3622
      • slovakia
      all voltages is ok , was not replaced, have rgb bl
      • m1ch43lzm
        • Mar 2019
        • 792
        • Peru
        According to this boardview,
        https://www.badcaps.net/forum/troubl...-or-board-view
        There's a secondary KBC, U8003, IT8252, for the keyboard and RGB LEDs, could be corrupt secondary KBC firmware, or damaged IC
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3622
          • slovakia
          ooo. that something new. thanks.
          i look at the chip and board and chip looks mint. when started all caps around it have voltages. so maybe firmware. i flash it by bios but nothing changed
            • 21677
            Is your motherboard model number G513-6050A3249301 .
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3622
              • slovakia
              yes
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3622
                • slovakia
                anyone knows if this ic must be programmed or i try to replace it?
                and if it must be programmed than how to program it . i have vertyanov
                ic is
                IT8252E248A
                2106-CXA
                S19EZA
                • khaahk
                  • Dec 2013
                  • 808
                  • Estonia
                  Have you looked at the list? G513 is listed under ITE.
                  G513IH KB_pins=36 CHIP=IT8252E248A LEFT DOWN 08MM PD0=29 PD1=20 PD2=15 PD3=23 PD4=14 PD5=16 PD6=12 PD7=30 BUSY=26 STB=18 AFD=28 INIT=21 SLIN=19 KSI4=22 KSI5=24 FLASH=248
                    • 21677
                    Do you have Armoury Crate & Aura Creator installed.
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3622
                      • slovakia
                      yeah but, where can i get the fw? everywhere are just main bioses
                      • khaahk
                        • Dec 2013
                        • 808
                        • Estonia
                        The support has moved mainly to telegram groups.
                        Are you sure it is not software related as SMDFlea suggested?
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3622
                          • slovakia
                          i sure expext that keyboard must work without any software
                            • 21677
                            Can you scan the QR code near the USB ports and post what it says, or post a good clear picture of it.
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3622
                              • slovakia
                              thanks mate i try
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3622
                                • slovakia
                                try to flash but it gives me no connection. but i think that i get voltages on it after start. must i start board when flashing this ic?
                                or anyone knows what voltagws on pins must have to flash it?
                                • khaahk
                                  • Dec 2013
                                  • 808
                                  • Estonia
                                  Give it a try, yes
                                    • 21677
                                    There is a keyboard firmware update tool for some models. The QR code will have the model number for the bios, scan it , then go to the support page and slect that model and see if the firmware update is there as a Hotfix
                                    Example: G513IH Hotfix, ROG Keyboard Firmware Update tool - https://www.asus.com/me-en/supporton...desk_download/
                                    • ktmmotocross
                                      Boardkiller
                                      • Feb 2014
                                      • 3622
                                      • slovakia
                                      interresting. on asus site they wrote that to udate its firmware i must flash main bios which i did.
                                      i try to locate this update but there is non for this G513QE
                                        • 21677
                                        Is G513QE what was scanned from the QR code
                                        • user546087
                                          Keyboard backlight too bright - Asus Zenbook S16 / UM5606
                                          by user546087
                                          I have a new Asus Zenbook S16, Model UM5606. Unfortunately, the keyboard backlight is too bright, even on the lowest setting. I have explored several ways now:
                                          - kindly ask Asus for an adjustment - they basically told me to STFU and get lost It is not possible, they say. Of course.
                                          - tint the keycaps from behind - I have already tried that - it is kind of a last resort
                                          - try to find out, how it is done, look at schematics - this is, where we are at.
                                          - maybe get the BIOS modified somehow? This would be the best option but I do not know a lot about...
                                          02-24-2025, 02:03 AM
                                        • obdcart
                                          Asus X415ea Adding a Keyboard with Backlight
                                          by obdcart
                                          Hello my friends i hope you can help me, i have just replace a keyboard with non backlight on a Asus X415 Laptop and i already install a Keyboard with backlight, the motherboard has the conector and ic's to control the light but i doens't work, i already try with a new installation of Windows and it's the same and injecting 3v/5v to the backlight flex it turns on the light, i think must be disable on Bios or need a jumper configuration.
                                          I hope you can give me some help
                                          06-28-2024, 02:21 PM
                                        • Kambi13
                                          Asus N550JV Keyboard not working properly
                                          by Kambi13
                                          Hi there need some advise. I have an Asus N550JV-CN102H with board N550JV Re2.1 suddendly started to behave weird, with almost no keys working on keyboard, opening random stuff, touchpad also working weird
                                          Nothing has been spilled. Tought, well keyboard has gone bad, ordered a replacement one, installed it, and to my surprise the issue remains the same....
                                          I'm wondering if the EC has gone Bad. Updated Bios also, but with no avail.... Does anyone knows if ITE IT8585E/FX has to be programmed?
                                          11-28-2024, 02:05 PM
                                        • SuperAman
                                          Keyboard replacement not working issues with Win 10/11 (2) different laptops
                                          by SuperAman
                                          I have had an issue that I've never come across in all my years of laptop repairs and it has happened twice in the last couple of weeks. The issue occurred on 2 laptops.
                                          1. The first laptop a Lenovo Yoga 7 convertible 14 inch 13th gen i7. This laptop came in working, customer wanted to replace the top keyboard assembly for cosmetic reasons so I replaced the keyobard assembly and put their touchpad in it. After booting into windows it would not work, so I assumed I needed to update it or something. Since they didn't give me the Admin account, as it was a company laptop and the...
                                          08-31-2024, 07:30 PM
                                          ASUS ROG GX502GV-ES004T Notebook Zephyrus S Specification for Upgrade or Repair
                                          This specification for the ASUS ROG GX502GV-ES004T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GX502GV-ES004T boardview and GX502GV-ES004T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 09:17 AM
