Asus G513QE keyboard and backlight not working
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3731
    • slovakia
    • hard-enduro
    Originally posted by SMDFlea
    Is G513QE what was scanned from the QR code
    no that code brings me only to 2021 ROG strix g15 page and in in there i must choose my model
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3731
      • slovakia
      • hard-enduro
      try to use that software but kisk me out because of QE model.
      I replaced IT8252 but still the same.
      Try to flash FW but still get no connection.
      But now i found that fans are not working and they are connected to main KBC
      • m1ch43lzm
        • Mar 2019
        • 2962
        • Peru
        Try the ROG Keyboard Firmware Tool i uploaded here
        https://www.badcaps.net/forum/troubl...16#post3731516
        This version has firmware for: G513IC/G513IE/G513IH/G513IM/G513IR
        G513QC/G513QE/G513QH/G513QM/G513QR/G513QY
        G713IC/G713IE/G713IH/G713IM/G713IR
        G713QC/G713QE/G713QH/G713QM/G713QR/G713QY
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3731
          • slovakia
          • hard-enduro
          I tried V2.7.3.002, main windows say "G513QE skip", update window wants press update button and than window dissappear and nothing happand. only main window.
          How long can take flashing?
          • m1ch43lzm
            • Mar 2019
            • 2962
            • Peru
            2.73.002 only has G513IM firmware, You can extract .exe with WinRAR or 7-zip to check
            2.73.001 has firmware for the models I mentioned
            You can try the suggestion from this Reddit post
            https://www.reddit.com/r/ASUS/commen...mment/mi550gt/
            Extract the .exe then run ROGKBFWUpdateTool.exe from bootable WinPE 10/11 USB such as Hirens or Sergei Strelec
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3731
              • slovakia
              • hard-enduro
              #26
              damn still the same. detect G513QE, skip it
              • m1ch43lzm
                • Mar 2019
                • 2962
                • Peru
                #27
                Maybe there's a way to trick the updater
                I compared FGA00000.G513IH.208 to FGA00000.G513QE.208 with hex editor, the only difference inside is 2 instances of G513IH (G513QE), rest is identical, so the KB firmware is the same for all
                Also checked the file from post 12, it appears to be a newer version 211 for G513IH (or all G513I/Q/G713I/Q), but it doesn't have the header/footer for the updater.
                But 2.73.002 has KB firmware 316 for G513IM,, try this modded updater, I just renamed the file for G513QE and hex edited "QE" instead of "IM" in the firmware update file
                EDIT: for flashing # 12 with EC programmer i think you need the P3V3A_DSW_NKEYPWR supply working
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3731
                  • slovakia
                  • hard-enduro
                  #28
                  Now im not sure if it is really bad second SIO or the first. As i see that fans come from first SIO and fans are not working
                  • m1ch43lzm
                    • Mar 2019
                    • 2962
                    • Peru
                    #29
                    It's going from bad to worse, first no keyboard and now no fans? Unless it's some setting in the Aura/Armory crate or whatever the ASUS software is called to control the fans, check temps to be sure, I'd worry if it gets to 80C idling
                    Also try "Load setup defaults" from BIOS
                    The second KBC looks like it's also connected to an internal USB port, to emulate a USB keyboard I presume, for Nkey support and the RGB stuff
                    Not sure if the first EC firmware is faulty, as the laptop powers on, I extracted main EC firmware from BIOS 331 from ASUS website if you want to try, cut to 192KB (I don't know the size of your main EC, but sure is 192KB or 256KB), backup first of course
                    Get the keyboard fixed first, then check the fans later
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3731
                      • slovakia
                      • hard-enduro
                      #30
                      thank i will try. im worried that if first sio is bad or damaged, if it does not restrict second one to comunicate or run. without functioning fans, laptop is useless
                      • m1ch43lzm
                        • Mar 2019
                        • 2962
                        • Peru
                        #31
                        Does the EC part number end in -128? If yes try, cut to 128KB
                        I may have made a mistake cutting to 192KB, try this instead
                        • amansr12
                          • Sep 2025
                          • 5
                          • italy
                          #32
                          any updates?
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3731
                            • slovakia
                            • hard-enduro
                            #33
                            Originally posted by amansr12
                            any updates?
                            no. owner wont wait, so he took it
                            • Slavol
                              • May 2015
                              • 87
                              • Poland
                              #34
                              Originally posted by khaahk
                              The support has moved mainly to ******** groups.
                              Are you sure it is not software related as SMDFlea suggested?
                              This dump working on G513QM (update via Vertyanov)
                              • amansr12
                                Asus Rog strix G513 keyboard, fans not working, battery not charging, works on ac
                                by amansr12
                                Hi, I recently open my Asus rog strix g1513 laptop to clean the fans and while disconnecting the battery there was a spark near the connector (c6000) and a capacitor (C60050 ) and the keyboard , fans stopped working and the laptop only works when charger plugged in, otherwise no. I removed the burned capacitor and the nearby caps stopped shorting but the problem didn't go away when I turned the motherboard some capacitors ( c8047 c8048 c8049 c8050 c8051 c8053 - connected to pin 25 and 57 of the u8003(ite252e248a) and c8023 c8024 c8046 connected to pin 24 ) are shorting ,,,,pin 26 is ground...
                                11-20-2025, 09:38 AM
                              • user546087
                                Keyboard backlight too bright - Asus Zenbook S16 / UM5606
                                by user546087
                                I have a new Asus Zenbook S16, Model UM5606. Unfortunately, the keyboard backlight is too bright, even on the lowest setting. I have explored several ways now:
                                - kindly ask Asus for an adjustment - they basically told me to STFU and get lost It is not possible, they say. Of course.
                                - tint the keycaps from behind - I have already tried that - it is kind of a last resort
                                - try to find out, how it is done, look at schematics - this is, where we are at.
                                - maybe get the BIOS modified somehow? This would be the best option but I do not know a lot about...
                                02-24-2025, 02:03 AM
                              • kara
                                Asus GX501v keyboard not working - keyboard firmware - solved!
                                by kara
                                Hello, i had a problem with this laptop keyboard. not working even after replacing with new original palmrest.
                                Solution after hours of researching is using a small software found on asus forum !
                                https://rog-forum.asus.com/t5/rog-ga.../701169/page/6
                                Thank you Bogdan Ciulei
                                Finally some good news :
                                I have managed to fix the problem.
                                First,
                                I am not responsible for any damage you might do to your hardware !
                                YOU DO THIS AT YOUR OWN RISK ! I ONLY PROVIDE POINTERS , DO
                                12-09-2025, 02:27 AM
                              • obdcart
                                Asus X415ea Adding a Keyboard with Backlight
                                by obdcart
                                Hello my friends i hope you can help me, i have just replace a keyboard with non backlight on a Asus X415 Laptop and i already install a Keyboard with backlight, the motherboard has the conector and ic's to control the light but i doens't work, i already try with a new installation of Windows and it's the same and injecting 3v/5v to the backlight flex it turns on the light, i think must be disable on Bios or need a jumper configuration.
                                I hope you can give me some help
                                06-28-2024, 02:21 PM
                              • Kambi13
                                Asus N550JV Keyboard not working properly
                                by Kambi13
                                Hi there need some advise. I have an Asus N550JV-CN102H with board N550JV Re2.1 suddendly started to behave weird, with almost no keys working on keyboard, opening random stuff, touchpad also working weird
                                Nothing has been spilled. Tought, well keyboard has gone bad, ordered a replacement one, installed it, and to my surprise the issue remains the same....
                                I'm wondering if the EC has gone Bad. Updated Bios also, but with no avail.... Does anyone knows if ITE IT8585E/FX has to be programmed?
                                11-28-2024, 02:05 PM
