Keyboard replacement not working issues with Win 10/11 (2) different laptops
  • SuperAman
    • Dec 2018
    • 121
    I have had an issue that I've never come across in all my years of laptop repairs and it has happened twice in the last couple of weeks. The issue occurred on 2 laptops.
    1. The first laptop a Lenovo Yoga 7 convertible 14 inch 13th gen i7. This laptop came in working, customer wanted to replace the top keyboard assembly for cosmetic reasons so I replaced the keyobard assembly and put their touchpad in it. After booting into windows it would not work, so I assumed I needed to update it or something. Since they didn't give me the Admin account, as it was a company laptop and the local account didn't let me play with it, I told them to reinstall the OS or do an update an it would work. Well they tried everything formatted windows, and came back a couple of weeks later, said it never worked even with Linux. Well I thought, no problem because I had kept their old keyboard. Guess what? After swapping everything back the keyboard will not work even with the original keyboard, same issue now! What is going on, tried reinstalling OS, resetting BIOS, removing CMOS battery, but nothing. Both keyboards work in BIOS but won't work in any windows environment including WINPE or even Windows Setup. I need to fix this as the laptop is back. Anything I'm missing?
    2. The other laptop a An HP x360 convertible laptop came in with the keyboard suddenly not working in windows anymore. I assumed since the laptop is not supported in windows 11 maybe downgrading would fix it, but no. After ordering the new keyboard top assembly and replacing it, issue still remains, keyboard not being recognized. Tried formatting the laptop again and even downgraded to Win 10 S mode (Factory image). When running HP diags both keyboards work and pass all testing. As soon as it boots to windows keyboard and touch pad stop working. I reset BIOS even tried updating BIOS but never worked. Ended up returning laptop to customer unrepaired and RMA the part.
    Just did another HP x360 laptop today with no issues so I am baffled.
    Any ideas what is going on? Thanks.
  • playit
    ps/2 port keyboard dead ? p5ql pro / ethernet cable light
    by playit
    my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
    my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
    few years back ps2 mouse stopped working, but ps2...
    12-23-2024, 06:05 AM
  • unick
    Laptop HP 850 G2 Keyboard error after Windows 11 update
    by unick
    Hello
    i have following problems on HP 850 G2 laptop and 840 G2 laptop. After win11 update 24H2 the keyboard and touchpad stop working. I delete the keyboard from device manager and restart : work. If i shut down the laptop and restart after 5 min the problem apear again: no keyboard and no touchpad active. I have used also hp driver from oficial sit but no luck. I have modified with regedit " i8042prt Start REG_DWORD with 1, but no suscces. Any ideea?
    09-15-2025, 07:47 AM
  • Hondaman
    Laptop external keyboard?
    by Hondaman
    Can I use an external keyboard with a modern (as of this post) laptop from, say, Dell?
    I am worried about durability because I am a cheap, frugal person. I suspect an external keyboard would extend the life of the laptop. I have always been a desktop person, since my AMD 386DX-40, and I really don't know about laptops (though the current Dell products look like they are fanless, which eliminates a big failure point).
    (Also I prefer the "clicking" "Unicomp" keyboard, which is still made an hour or two away from me in Lexington KY, using the same equipment...
    10-30-2023, 12:04 PM
  • RdeveLabs
    MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
    by RdeveLabs
    To all the members here...
    Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
    So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
    05-05-2025, 04:59 AM
  • Zymymenestys
    Asus ROG Strix Scar G533QR keyboard replacement issues
    by Zymymenestys
    Hello Badcaps!
    I recently got a job where the keyboard assembly of an Asus ROG Strix Scar G533QR was replaced from an Arabic keyboard to a nordic layout.
    The original (arabic) part number is 0KNR0-4630AR00 and the replacement part number is 90NR0541-R31ND0.
    The keyboard works well, lights and every button works, except the left shift.
    In nordic keyboards there is a small shift and a < button, instead of a larger shift, which seems to be the only actual difference in the keyboards, except the legend.
    Could this be an issue with the KBC/BIOS...
    10-12-2023, 05:11 AM
