Dell XPS 9315 bios programmer
  • krolikjarek
    • Dec 2019
    • 4
    • scotland
    Hi everyone. That's my first post so please forgive me if I've done something wrong.
    I'm trying to flash the bios on a Dell XPS 9315 but the bios chip w25r512jvl is not supported by asprogrammer and 2 other softwares for the ch341a I've tried the epz2010 but this on the other hand shows a message device not connected even though the driver is installed.
    Can anyone please help?
  • ianbak
    • Apr 2023
    • 55
    Even Google has no results for w25r512jvl. Are you sure that that's the correct chip type?
    • krolikjarek
      • Dec 2019
      • 4
      • scotland
      You are right. Im sorry. the correct chip type is W25R512JVEN
      • Sephir0th
        • Oct 2020
        • 1283
        Try to use a similar IC (Winbond, 256MBit, 3.3V) front the list of supported flash ICs.
        Did you try the "Detect" Button in NeoProgrammer software?
        FairRepair on YouTube
        • m1ch43lzm
          • Mar 2019
          • 757
          • Peru
          There's the W25Q512JV on NeoProgrammer 2.2.0.10, not yet supported on AsProgrammer, it may or may not work
          https://www.onetransistor.eu/2018/11...n-windows.html
          Scroll down until you find a Google drive download link for NeoProgrammer
          • Sephir0th
            • Oct 2020
            • 1283
            Oh yes, meant 512MBit of course and not 256MBit...
            • zlr8r
              looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
              by zlr8r
              looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
              cheers
              Dell Inspiron 17 (7786) Laptop
              Service Tag: 5J0NHT2
              Bios: 1.9.0
              MOBO: RO 15 17 WHL 2GB MB / 18706-2
              Attached;
              1. My saved bios using a programmer
              2. Dells Bios updater .exe (v1.16)
              3. Dells Bios recovery file
              4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
              5. Image of ME...
              12-18-2023, 03:08 PM
            • mikeybass
              by mikeybass
              04-23-2025, 04:30 PM
            • STKR123
              The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
              by STKR123
              Greetings badcaps community,
              I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
              So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
              Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
              I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
              These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
              I learned that desoldering...
              10-29-2024, 06:03 AM
            • Akhlz001
              by Akhlz001
              09-20-2025, 07:15 PM
            • hotcrossedbuns999
              M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
              by hotcrossedbuns999
              My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
              1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
              2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
              3. I could only locate two chips that look like bios chips. Could someone verify this
              01-03-2025, 12:32 PM
