ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
  • MakNCheese
    • Jun 2025
    • 11
    I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
    Symptoms:
    • Severe lag across the system, including BIOS navigation.
    • Slow boot times and unresponsive performance in Windows.
    • Battery charges very slowly (e.g., ~5% in 2–3 hours).
    • No error messages or BSODs, just extreme sluggishness.
    What I've Tried:
    • Replaced the charger – no improvement in lag or charging speed.
    • Replaced the battery – no change in symptoms.
    • Tested running on adapter only (no battery) – same lag issue.
    • Verified charger pin voltage – it's good.
    • Reformatted the system (clean Windows install) – no effect.
    • Tested RAM with MemTest86 – no errors detected.
    • Visually inspected the motherboard – no obvious signs of damage (e.g., burnt components, bulging caps), but I'm not an expert.
  • Sephir0th
    • Oct 2020
    • 1262
    Charging controller is a BQ24780S? If yes, resistances between ACN and ACP pins at the controller?
    FairRepair on YouTube
    • MakNCheese
      • Jun 2025
      • 11
      I am not at home right now. Give me some time then I will try this. This has to be done with the laptop not plugged in, right?
      • Sephir0th
        • Oct 2020
        • 1262
        Correct, no power at all
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Another thing to look for is PROCHOT#
          • MakNCheese
            • Jun 2025
            • 11
            Yes, it is BQ24780S. I tried this using my multiple probes, but they are not thin enough. So, couldn't get a perfect reading. One time it was 80 ohms, and the next time, I tried it was 4.60 k ohms. I have ordered new fine probes and will get readings again
            • MakNCheese
              • Jun 2025
              • 11
              Thanks for the response. Could you please let me know how to do that?
              • Sephir0th
                • Oct 2020
                • 1262
                Share a picture of the charging controller and surrounding circuit please. We will find suitable measurement points.
                • m1ch43lzm
                  • Mar 2019
                  • 389
                  • Peru
                  Ryzen CPU? You can download HWINFO64
                  https://www.hwinfo.com/download/
                  Get the portable version, open it and select "Sensors only"
                  Then scroll down until you get something like this
                  If it shows PROCHOT_EXT as "yes", that's the issue
                  Another thing to look for is the CPU will be stuck at 400MHz
                  It happened to me on a HP laptop, could be anything like a bad pull-up resistor on that line, to an IC pulling down the line for whatever reason
                  • MakNCheese
                    • Jun 2025
                    • 11
                    Do you think that PROCHOT could be the reason? I'm asking because the battery is also not charging properly and very slowly. If prochot is the issue, the battery should charge at normal speed when the pc is off?
                    I formatted the SSD but couldn't install Windows on it because of system running very slow to check prochot I will have to install another SSD on it.
                    • m1ch43lzm
                      • Mar 2019
                      • 389
                      • Peru
                      Schematics for the GA401IH, may be close https://www.badcaps.net/forum/troubl...-ga401iv-br9n6
                      From the schematics the charger IC PU8900 has a connection to PROCHOT#, and there's a circuit for HW throttle on the same page that also goes to PROCHOT#, so yes, it may be related to a fault in the charge circuit
                      SN2867 = BQ24780S
                      • MakNCheese
                        • Jun 2025
                        • 11
                        I measured the resistance between pins ACN and ACP pins it was 0 ohms. Though I am still not sure of the readings. I am attaching pictures of the motherboard and the schematics is attached above.
                        • Sephir0th
                          • Oct 2020
                          • 1262
                          Closer and better quality please
                          • MakNCheese
                            • Jun 2025
                            • 11
                            Will these work?
                            • MakNCheese
                              • Jun 2025
                              • 11
                              Do you see anything that might be causing an issue? It's sunday and I can spend a lot of time on this. Appreciate your help
                              • Sephir0th
                                • Oct 2020
                                • 1262
                                Will these work?
                                It's just needs to be visualized what connects to where. So instead of to measuring between ACN and ACP directly you can measure between these two points.
                                • MakNCheese
                                  • Jun 2025
                                  • 11
                                  Thanks mate. Checked these points and ACP and ACN points directly. The resistance between the two comes out to be 0. Continuity is there too
                                  • Sephir0th
                                    • Oct 2020
                                    • 1262
                                    Okay, let's check voltage of PROCHOT# then. Unfortunately this becomes more complicated since there is no nearby component where we can measure. So either you move carefully and with thin probes to Pin 10 directly or you carefully scrape the mask of the via to make this track better accessible.
                                    The important part here is a) to perform this test with the board powered AND turned on and b) to not slip with the probes...
                                    • code share
                                      Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                                      by code share
                                      I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                                      Here's what I've tried so far:
                                      • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                                      • Booted successfully on AC power only with the battery disconnected
                                      • Visual inspection of the battery — no swelling, burn marks, or connector damage
                                      • Battery
                                      04-21-2025, 12:50 PM
                                    • Tr0ll
                                      by Tr0ll
                                      Original T-con:
                                      First replacement T-con:
                                      10-07-2023, 07:48 PM
                                    • tech_guru
                                      Asus ROG Zephyrus G14 GA401IU-HE103T GPU Nvidia Issue
                                      by tech_guru
                                      Hello all,
                                      I am having an issue with this laptop, on which I repaired the motherboard on other power issues (PMIC, mosfets etc) and it came back to life, but I am having problem with the GPU NVIDIA GTX 1660. It gets error 43 in device manager with exclamation mark and does not work. When I install official asus driver or official nvidia latest, the error goes away until you reboot the laptop, where the error comes back again.
                                      GPU-Z software does not show many information and vbios info is missing (photo attached).
                                      Because the customer sent the laptop to 2 other labs trying...
                                      01-18-2025, 05:45 AM
                                    • rounin
                                      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                      by rounin
                                      🛠 Original Issue
                                      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                      04-19-2025, 01:18 AM
                                    • elmark
                                      HP 15-cw1002ua strange keyboard issue
                                      by elmark
                                      HP Pavilion 15-CW1002UA
                                      S/N 5CD0251CBC
                                      P/N 7KE54EA
                                      Hello guys!
                                      I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                                      It powers on OK and has no other issues except the following:
                                      • CAPS LOCK does not work at all
                                      • Fn button toggles Flight Mode
                                      • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                                      • (with SHIFT pressed: 't%' and 'y^' respectively)
                                      I initially thought it was a keyboard malfunction (internal short, etc.),
                                      but when I press and hold...
                                      06-27-2025, 01:10 AM
