820-00293 - No power - Stuck on 5v 0.06A
  • ronaldopdias
    • Jul 2015
    • 93
    • United Kingdon
    Board Model: 820-00923
    Issue: Board takes 5V @ 0.694A on all ports. No signs liquid.
    Customer stated: Died during an update whilst battery was at 10%. Tried plugging in but it died.
    Board takes 5V at 0.06A on all USB-C ports..
    Board is clean with no visible corrosion or liquid damage.
    PP1V8_UPC_TA_LDOA - 1.8V
    PP3V3_UPC_TA_LDO - 3.32V
    PP1V8_UPC_TA_LDOD - 1.8V
    PP1V1_UPC_TA_LDO_BMC - 0V
    PP1V8_UPC_TB_LDOA - 1.8V
    PP1V1_UPC_TB_LDO_BMC - 0V
    PP1V8_UPC_TB_LDOD - 1.8V
    PP3V3_UPC_TB_LDO - 3.28V
    PP3V3_UPC_XB_LDO - 3.1V
    PP1V8_UPC_XB_LDOA - 1.8V
    PP1V8_UPC_XB_LDOD - 3V
    PP1V1_UPC_XB_LDO_BMC - 0V
    PP3V3_UPC_XA_LDO - 3.3V
    PP1V8_UPC_XA_LDOA - 1.8V
    PP1V8_UPC_XA_LDOD - 1.8V
    PP1V1_UPC_XA_LDO_BMC - 0V
    PPBUS_G3H - 0V
    PPDCIN_G3H - 5.16V
    Battery connected doesn't make any difference.
    USB-C current does not change regardless of port used.
    Parts Replaced:
    • U7000
    • U7800
    • CD3215 – replaced all 4 with known-good chips from a donor board.
    • U2890/UB090 (TBT ROM) – replaced from a good known board.
    • SMC chip – replaced with a good one from a donor.
    Appreciate any help, please.
  • mon2
    • 14667
    PPBUS_G3H - 0V
    Remove all power. Meter in resistance mode. What is the exact resistance to ground of PPBUS_G3H?
    • mon2
      • 14667
      None of the _BMC rails are at 1V1 while in use of that port?
      This does not look correct.
      • ronaldopdias
        • Jul 2015
        • 93
        • United Kingdon
        PPBUS_G3H​ - 0.459 in diode mode.
        • mon2
          • 14667
          U7000 is a suspect since 0v output and part was replaced.
          Consuming 60mA or 600mA?
          • ronaldopdias
            • Jul 2015
            • 93
            • United Kingdon
            PP1V8_UPC_XB_LDOD was 3V because I kicked out C3205. After replacing it, it now gets 1.8V.
            Also, I found a short on PPVIN_G3H_P3V3G3H leading to faulty cap C7081. Cap replaced and same results.
            Stuck on 5v @ 0.04A
            • ronaldopdias
              • Jul 2015
              • 93
              • United Kingdon
              U7000 replaced and still the same.
              40mA
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • Destroyer-Br
                [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                by Destroyer-Br
                I'm working on an Acer Nitro 5 unit with the following specs:
                • Motherboard: LA-J871P Rev: 1B
                • Model: Acer AN515-55-59MT
                • S/N: NHQ7JAL00403906A973400
                • SNID: 03902728734
                Initial Issue
                The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                04-17-2025, 08:18 PM
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • duwane
                MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
                by duwane
                Hi All.
                I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
                Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
                After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
                Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
                10-17-2023, 07:48 PM
              • Stephen
                A2991 Logic Board issue, 20volts 0 amps help!
                by Stephen
                Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
                09-10-2025, 03:16 PM
