Dell PA-3E Dim LED
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Dell PA-3E Dim LED
    I have a Dell PA-3E power brick that the LED light on the laptop plug is dim on. The brick otherwise works (charged and powered a Latitude D630 no sweat).
    Where should I look? Bad cable? Known problem?
    sigpic
    (Insert witty quote here)
  • dj_ricoh
    • 2073
    Re: Dell PA-3E Dim LED
    did you wiggle it?
      • 31013
      do you mean the laptop socket?
      i'v never seen one on the charger plug.
      maybe it's just a failing led if the laptop runs & charges.
      it happens - it's rare, but it used to be pretty common.
      • Alfa is auto
        • May 2013
        • 83
        • Finland
        Also it might be that the caps are going bad in the charger..
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Yup, in the plug. google it.
          sigpic
            • 31013
            then maybe the old "broken cable at the brick" problem?
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Perhaps. Looks like the old hammer and utility knife blade trick is in order.
              sigpic
                Same thing happened to mine, Dell overdrive the LED to make it bright but it last far less time than it should.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  Yup. Cracked it open, minus some lelon-ish caps on the secondary, I didn't see any issues. given that only 3 wires go to the cable, the LED(s) and resistor are internal to the plug.
                  Noted on the overdrive... I may save this to power a port replicator or something. I was going to use it with my E5530 I just bought w/o AC adapter, but I can just one of my shrinking stash of PA-10 bricks.
                  sigpic
                    Dell Latitude D630 Laptop Schematic
                    LA-3302P LA-3301P...
                    10-08-2024, 12:19 PM
                  • Lapsmith
                    Fried capacitor on Dell-5520. Guilty as charged.
                    by Lapsmith
                    While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                    07-06-2025, 11:08 PM
                  • F R 2568
                    Dell Latitude 5420 does not start (no post) need help to find the reason why
                    by F R 2568
                    Hello all,
                    this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                    I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                    If the laptop is only connected to the AC adapter (battery removed):
                    When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                    The power/battery...
                    01-08-2025, 05:45 AM
                  • diamon
                    Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                    by diamon
                    I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                    Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                    Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                    Pictures of these boards:
                    Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                    Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                    Dell...
                    02-28-2024, 12:51 PM
                  • OntarioTL
                    Dell 5410 greyed out BT
                    by OntarioTL
                    Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
                    If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
                    Dell Lattitude 5410
                    Service Tag...
                    07-25-2025, 01:28 PM
