Dell PA-3E Dim LED
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Dell PA-3E Dim LED
    I have a Dell PA-3E power brick that the LED light on the laptop plug is dim on. The brick otherwise works (charged and powered a Latitude D630 no sweat).
    Where should I look? Bad cable? Known problem?
    sigpic
    (Insert witty quote here)
  • dj_ricoh
    • 2073
    • uk
    Re: Dell PA-3E Dim LED
    did you wiggle it?
      • 31255
      do you mean the laptop socket?
      i'v never seen one on the charger plug.
      maybe it's just a failing led if the laptop runs & charges.
      it happens - it's rare, but it used to be pretty common.
      • Alfa is auto
        • May 2013
        • 83
        • Finland
        Also it might be that the caps are going bad in the charger..
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Yup, in the plug. google it.
          sigpic
            • 31255
            then maybe the old "broken cable at the brick" problem?
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Perhaps. Looks like the old hammer and utility knife blade trick is in order.
              sigpic
                Same thing happened to mine, Dell overdrive the LED to make it bright but it last far less time than it should.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  Yup. Cracked it open, minus some lelon-ish caps on the secondary, I didn't see any issues. given that only 3 wires go to the cable, the LED(s) and resistor are internal to the plug.
                  Noted on the overdrive... I may save this to power a port replicator or something. I was going to use it with my E5530 I just bought w/o AC adapter, but I can just one of my shrinking stash of PA-10 bricks.
                  sigpic
                    Dell Latitude D630 Laptop Schematic
                    LA-3302P LA-3301P...
                    10-08-2024, 12:19 PM
                  • Akhlz001
                    by Akhlz001
                    09-20-2025, 07:15 PM
                  • Lapsmith
                    Fried capacitor on Dell-5520. Guilty as charged.
                    by Lapsmith
                    While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                    07-06-2025, 11:08 PM
                  • master3112
                    by master3112
                    07-29-2025, 01:55 PM
                    Dell Thunderbolt Firmware
                    by SMDFlea
                    Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                    Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                    The SKU is in brackets (****)
                    EDIT: NVM65...
                    01-26-2025, 06:22 AM
