Macbook A2442 no display board 820-02098
  • dbuergi
    • Jul 2024
    • 123
    • Deutschland
    Maybe i found my problem. Looks like LP800 is done. Right now i'm looking for a replacement with 2.2 µH, 8 A.
    Any ideas what i can take or if there is anything from another logicboard if not new? I have A2141 and A1932 spares here but didn't find anything with same specs.
    • mon2
      • Dec 2019
      • 14396
      LP800 ? Inductors rarely fail. Can you post pics of the part? Why do you believe that this inductor is defective? Inductors can be replaced by others but you need to match the inductance and peak current rating or exceed it and ideally match the same pcb footprint. So for example, same sized 2.2uH @ 15A is fine to use as a replacement, etc. Bourns is a great company we use in our design and there are many others.
      • dbuergi
        • Jul 2024
        • 123
        • Deutschland
ID:	3681428 It looks bad but maybe i can still use it?
        • mon2
          • Dec 2019
          • 14396
          Measure if the inductor is conducting by placing the meter in resistance mode across the solder pads on this part. What is the resistance? Yes, looks a bit baked but should be ok unless the inductor internal wiring is damaged.
          • dbuergi
            • Jul 2024
            • 123
            • Deutschland
            I get 0,4 Ohm so it should be fine?
            As written before after replacing QP800 and QP802 the board startet but without any display. Strangely i had a short on pad 2 of LP800 after removing it. Replacing QP803 and QP801 fixed it. Maybe this will finally fix my display issues.
            • dbuergi
              • Jul 2024
              • 123
              • Deutschland
              #26
              So looks like i get a picture but without any backlight. I Had the chance a second board with the case but still no backlight.
              So do i have to change the display in this case?
              • ledbylight
                M1 A2337 Macbook - No Display, likely due to logic board
                by ledbylight
                Hi all!
                This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
                I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more , and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
                11-04-2024, 06:36 PM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • veedo
                Macbook A2442 820-02098 boot and display issue
                by veedo
                Hi All
                I have MacBook A2442 which had keyboard replaced and now it doesn't turn on correctly, it have sound chime from time to time and Apple logo shows on the display and there is no backlight on, apple logo appear and stuck on kind of boot loop. But if one of the display flexes is disconnected from the motherboard then MacBook turns of fine with the external monitor and it keeps working fine.
                Without keyboard its still have same issue, I don't have second display to replace it and compare but does display can make issues with boot?
                I found component UD290 ( SF0101-I2C) little...
                04-01-2024, 06:06 AM
              • survivalbloke
                MacBook Pro A2442, board 820-0298-A, no backlight
                by survivalbloke
                I'm working on a MacBook Pro A2442, board 820-0298-A. This device was liquid damaged and had no power. After I repaired the liquid damage, I find the device powers on and works with external video, but backlight is not working.
                Anyway, I really want to improve my fault tracing skills, instead of having to rely on others to always tell me where to look and what to check. In this case, I have a question about navigating schematics. If I wanted to trace the backlight power circuit, how do I find where that circuit begins? If I search for "lcd" in the schamtic, it is listed...
                11-21-2024, 10:46 AM
