FX553VE-DM318T(FX553v) not POSTING
  • claws77
    • Apr 2024
    • 103
    • India
    Cpu i7-7700hq Ram - 8gb samsung, 32 gb sk hynix
    Gpu - nvidia geforce 1050ti
    Ssd orion o700
    Hdd hgst721010A9e630
    See images
    What's not working right?
    The system does not even POST, display is black,
    LEDs on - power led, aiplane mode, capslock fpr few seconds in the start(when connected to ac power) only.
    When did the problem happen?
    My laptop had dual boot setup, ubuntu and windows 10.
    It already had a moklist error, that would occur when i tried to boot ubuntu.
    When i upgraded my laptop
    I changed from samsumg 8gb ram ddr4 to sk hynix 32(16x2) ram ddr4.
    I attached one o700 orion ssd.
    The pc did not boot immidiately.
    But after several tries it did.
    Then i used my laptop with 32 gb ram, 1 tb hdd (windows) and 1tb ssd(unintialized) for 15 days min.
    The plan was to protect all personal data in hdd while merging partitions, removing windows and ubuntu and efi, etc partitions. Install windows on ssd.
    To implemet this i thought to
    1. intitialize my ssd transfer my data(that needed to be saved 500gb) from hdd to ssd. Done sucessfully.
    2. Removed ubuntu partition, merged and formatted. Only left partitions are windows, efi, etc. Done succesfully
    3. Created a live usb of puppy linux to boot into and merge remaining partitions and transfer back my data to hdd(merged) and get ready for fresh windwos install to ssd - failed
    a. usb plugged in - done.
    b. Boot menu change - failed. Could not open boot menu.
    c. Boot to Bios - failed. - could not open bios, laptop freezes like the current situation(answer 1)
    d. Reset cmos and removed battery- still failed. Still could not open bios , same reason as c
    e. removed usb, the bios can still not be opened from key press but system boots to windows, normally. Thought it was a grub issue. Removed grub - still cannot boot to bios.
    f. Removed hdd, one 16 gb ram, the bios opens up.
    g. Set bios to boot live usb with ssd only. Success.
    h. Connected hdd to motherboard, still cannot boot, system freezes, black screen no lpgo or stuck at logo.
    i. The bios settings revert back to last saved.
    j. Tried to boot with old ram stick with hdd, only ram and no drives, no ram and no drives.
    Evertime after j, results the same - 3 leds, (power(keyboard), charging and airplane) capslock led flashes in the begining.
    What was being done with the machine at that moment?
    I was trying to upgrade
    Did it start acting up months ago?
    Kinda,
    1. moklist error when dual booting - even after erasing forbidden signatures. The signatures would magically reappear.
    2. First boot/posting issue started when upgrading.
    Was it ever in contact with liquid?
    Never
    Was it ever dropped?
    Never.
    Was it repaired in the past already?
    Never - i once replaced my cmos battery.
  • m1ch43lzm
    • Mar 2019
    • 1116
    • Peru
    I'm not completely sure, but it could be a bad/corrupt BIOS by looking at b, c, h, i, check the voltage on the RTC battery first (2nd picture, with 2 wires)
    In that case, you'll need an external programmer, make a backup of your current BIOS, then make a new thread (or find an existing one for your model) in the BIOS request subforum attaching the required information and your BIOS backup (read the rules there first)
    • claws77
      • Apr 2024
      • 103
      • India
      Thank you so much for taking the time.
      i too think that.
      Today i tried to put everything (disassembled) back together.
      it magically booted to windwos.
      It still has issues booting to bios.
      its probably corrupt.
      I will try to dump my bios.
      And flash it maybe
      ​​is using a usb flash better or a external programmer?
      • claws77
        • Apr 2024
        • 103
        • India
        Here is what the winflash utility shows.
        • m1ch43lzm
          • Mar 2019
          • 1116
          • Peru
          Only if there was a way to enter EZ Flash without entering BIOS setup, as you have to go to Advanced menu to enter EZ Flash (you mentioned issues entering BIOS)
          https://www.asus.com/support/faq/1008859/
          You have to copy the BIOS update onto a USB drive formatted FAT32
          https://www.asus.com/supportonly/fx553ve/helpdesk_bios/
          It's best to update BIOS from the built-in updater in BIOS itself, at least there's an option for it on ASUS laptops, similar to their desktop boards
          For the winflash utility check here
          https://rog-forum.asus.com/t5/rog-ga...sh/td-p/166819
          You have to run winflash.exe /nodate
          If for some reason it fails, you need an external programmer to flash the BIOS, check here
          https://www.badcaps.net/forum/troubl...rces-and-tools
          • claws77
            • Apr 2024
            • 103
            • India
            I have embedded windows key, attached to my bios.
            will flashing delete this key.
            How to make a backup bios and key with winflash?
            • m1ch43lzm
              • Mar 2019
              • 1116
              • Peru
              With the official updater (EZ flash/winflash) it should keep your windows key along with serial/model number
              I haven't found a way to backup current bios version with winflash
              To be 100% sure i suggest to backup the current bios with external programmer before attempting anything
              read the bios chip 3 times, all dumps should be identical compared with a hex editor
              • claws77
                • Apr 2024
                • 103
                • India
                Ok cool, now we wait for the delivery of external progammer.
                How to pick one, i have no idea.
                https://amzn.in/d/i7PSyfl
                What do you use?
                In the meantime, i'll find a friend that will let me use his pc for this.😅
                • m1ch43lzm
                  • Mar 2019
                  • 1116
                  • Peru
                  If you want a cheap programmer there's this version of the CH341A with green or blue PCB
                  https://www.amazon.in/DHRUVPRO-Progr...dp/B0DZJ312CF/
                  Get a SOP8 clip if you want, but sometimes those clips are unreliable, best is to desolder the bios chip from the board, something like the one below
                  https://www.amazon.in/IDUINO-Non-Dis...dp/B0CVNMFK2L/
                  The ones with a black PCB like the one you linked have an issue with wrong voltage levels on the data pins, there's a modification that can be done to fix that,
                  https://wej.k.vu/electronics/ch341a-...rogrammer-fix/
                  Something better, there's the RT809F and the T48, which are more expensive
                  Maybe someone else has some recommendations
                  • claws77
                    • Apr 2024
                    • 103
                    • India
                    Click image for larger version  Name:	image.png Views:	0 Size:	11.8 KB ID:	3641397
                    I tried the WinFlash method, it failed. the BIOS still does not open. but while updating with Winflash, it looked it everything went smoothly. ez flash utility automatically opened.
                    but alas, no success.
                    NOTHING CHANGED
                    guess external prgrammer is the only way!.
                    now i have to worry about backing up my bios too
                    how do i backup my bios? with external programmer only?
                    • claws77
                      • Apr 2024
                      • 103
                      • India
                      regarding this.
                      can it program all kinds of bios ics,
                      i am asking cuz repairing stuff, brings me joy. and right tools make all the difference!
                      thank you so much kind stranger on the internet!!
                      • m1ch43lzm
                        • Mar 2019
                        • 1116
                        • Peru
                        Depends on which type of ICs you're looking to program
                        The CH341 supports only 24xx i2c eeproms and 25xx SPI flash at 3.3v
                        For 1.8v 25xx SPI flash like the ones used on newer motherboards there's a 1.8v adapter available
                        It's cheap but slow, it takes several minutes to program a BIOS like the one on your laptop
                        There's third party software called AsProgrammer and NeoProgrammer with more supported chips than the provided software by the sellers
                        The RT809F also supports 24xx and 25xx and other chips with additional adapters, it needs an additional adapter for 1.8v 25xx flash chips, it has HDMI and VGA ports which are used to program the EEPROM on some TVs and monitors
                        For old EEPROMs and flash chips (29Fxxxx, 39Fxxxx, 49Fxxxx) and other devices up to 40 pins there's also the Xgecu T48, it supports 1.8v 25xx chips
                        There's also the REVELPROG which is more expensive
                        Check the supported chips list for each programmer you're interested in buying
                        Sometimes getting several adapters in a bundle with the programmer is not worth the cost depending on the chips you need to program, the common flash chips used in laptops are SOP8 150mil, SOP8 200mil, WSON8 5x6, WSON8 8x6
                        • claws77
                          • Apr 2024
                          • 103
                          • India
                          Finally bought the rom flashers
                          black and blue ones both(ch341a), test clip.
                          ​​​​​they arrived today.
                          Got everything setup correctly
                          I am using raspberry pi with vnc to flash bios, using flashrom utility.
                          I am getting these errors.
                          i know my chip is w25q64fv. It says so on the ic.
                          what when i use -c W25Q64FV, it does not work.
                          Any guidance....
                          • m1ch43lzm
                            • Mar 2019
                            • 1116
                            • Peru
                            Try -c "W25Q64BV/W25Q64CV/W25Q64FV"
                            Or -c "W25Q64.V"
                            I advise to read the chip 3 times, and compare the dumps if they're identical to each other with a hex editor
                            Otherwise borrow a Windows PC and use AsProgrammer software
                            https://github.com/nofeletru/UsbAsp-flash/releases
                            For Linux I found another software called IMSProg, I haven't tried it
                            https://github.com/bigbigmdm/IMSProg
                            https://www.onetransistor.eu/2023/10...mer-linux.html
                            Maybe there's a build available for the raspberry pi
                            • claws77
                              • Apr 2024
                              • 103
                              • India
                              Got new errors.
                              raspi@raspi-pc:~ $ flashrom -p ch341a_spi -r filename.bin -c "W25Q64BV/W25Q64CV/W25Q64FV" flashrom unknown on Linux 6.12.25+rpt-rpi-v8 (aarch64)
                              flashrom is free software, get the source code at https://flashrom.org
                              Using clock_gettime for delay loops (clk_id: 1, resolution: 1ns).
                              Found Winbond flash chip "W25Q64BV/W25Q64CV/W25Q64FV" (8192 kB, SPI) on ch341a_spi.
                              Reading flash...
                              cb_in: error: LIBUSB_TRANSFER_TIMED_OUT
                              ch341a_spi_spi_send_command: Failed to read 4100 bytes
                              Read operation failed!
                              FAILED.
                              raspi@raspi-pc:~ $ flashrom -p ch341a_spi -r filename.bin -c "W25Q64.V"
                              Error: Unknown chip 'W25Q64.V' specified.
                              Run flashrom -L to view the hardware supported in this flashrom version.
                              raspi@raspi-pc:~ $ flashrom -p ch341a_spi -r filename.bin -c "W25Q64FV"
                              Error: Unknown chip 'W25Q64FV' specified.
                              • m1ch43lzm
                                • Mar 2019
                                • 1116
                                • Peru
                                This one appears to be the correct command
                                Try on another PC
                                • claws77
                                  • Apr 2024
                                  • 103
                                  • India
                                  I tried to install imsprog.
                                  but my raspi freezes in the middle.
                                  I too suspect raspberry pi issue.
                                  Will update after trying on a new pc.
                                  Thanks again
                                  • claws77
                                    • Apr 2024
                                    • 103
                                    • India
                                    yay!
                                    finally read the bios dump 3 times.
                                    i am using asprogrammer
                                    compared the dump files with "fc /b" in cmd
                                    please find attached. everything ok?
                                    i'll post it in bios forum too
                                    • m1ch43lzm
                                      • Mar 2019
                                      • 1116
                                      • Peru
                                      Try again, the files are empty, full of FF FF...
                                      Nothing that looks like the BIOS from Asus website
                                      Sometimes the clip makes a bad connection
                                      • claws77
                                        • Apr 2024
                                        • 103
                                        • India
                                        i installed both of these drivers. Click image for larger version
                                        my device manager shows like this
                                        the asprogrammmer does not detect the programmer automatically, i select everything.
                                        • kenkaniff
                                          HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
                                          by kenkaniff
                                          Product Name: HP Pro x360 Fortis 11-inch G9
                                          System BIOS: U94 Ver.01.08.00 10/06/2023
                                          Serial Number: 5CG31946F5
                                          SKU Number: 85W05EC#AK8
                                          Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
                                          This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
                                          I needed to remove bios password...
                                          10-01-2025, 04:32 AM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • iZakre
                                          HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                                          by iZakre
                                          Hello everybody!
                                          To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                                          The thing is that I had installed TeamViewer and could log into the computer...
                                          02-19-2023, 02:27 PM
                                        • q2v5
                                          Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                                          by q2v5
                                          Lenovo T480s
                                          Model 20L8-S3TE00
                                          Board ET481-U10
                                          Chip MX25L12873F
                                          Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                                          2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                                          The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                                          08-15-2024, 10:40 PM
                                        • Neddsme
                                          Bios partially corrupted somehow and now warm boot doesn't work which is critical
                                          by Neddsme
                                          Hie.
                                          I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
                                          Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
                                          I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
                                          I managed to run Windows troubleshooting and...
                                          02-04-2022, 05:57 AM
