Lenovo Thinkpad E15 Gen 2 NM-D011 - No display ? External , yes!
  • Acnologia
    • Dec 2016
    • 429
    • Poland
    Originally posted by m1ch43lzm
    https://pcsupport.lenovo.com/id/en/p.../display/model
    According to the full model 20TD00GNUK i get only these options, you can enter the serial number at that web site to get the exact parts used
    Mars1.0INTELFRUCABLEMars1.0IntelEDPCABLEIR
    Part No: 5C10Z23917
    Camera,HD-IR,Front,2MIC,ZIF,Azw
    Part No: 5C20W42992
    Substitutes: 5C20W42993 and 5C20W42994
    Click image for larger version Name:	5C20W42993_A.jpg Views:	0 Size:	36.2 KB ID:	3635821
    And it says exactly what you posted SC20F27116 (for 5C20W42993), so it's an IR webcam, on the regular 720p cameras if i select only 20TD the number on the sticker is completely different
    You can click on the images on the lenovo parts site and check
    The serial number is: PF3JCYGJ (i had written above... ) again it shows 2 camera suitable for that laptop as a replacement .
    Oh my god imagine receiving another cable that it's not compatible with that hahah in 2 weeks haha...
    • m1ch43lzm
      • Mar 2019
      • 1071
      • Peru
      You meant
      Camera,HD-IR,Front,2MIC,ZIF,Bsn Part No: 5C20W42993
      Part No: 5C20W42992
      They're equivalent, both IR, listed as substitutes for each other, the LCD cable is the same 5C10Z23917
      Likely they grab whatever supplier they got cheaper for a given batch
      EDIT: Go figure, I just got an ebay ad on this forum (browsing from my phone) for "EDP Screen Cable+RGB Camera IR Cable DC02C00MF10 for Lenovo ThinkPad E15 Gen2" Coincidence?
      • Acnologia
        • Dec 2016
        • 429
        • Poland
        You meant
        Part No: 5C20W42992
        Indeed.
        I will sell the other one, with the exact details, as we have found out (you basically) on eBay when time will come for someone to buy it ,because that way i 'm just throwing money... 2 weeks left ...
        • Acnologia
          • Dec 2016
          • 429
          • Poland
          Part No: 5C10Z23917
          Part No: 5C20W42992
          Yes , the day has come.
          Yes, the cable arrived , yes i changed it, also i changed the fuse just to be sure, and just to be sure the FPC connector. The laptop doesn't anymore shows signs of ground beeping ,and it can power on with charger connected and ,screen cable connected.
          I cannot believe that the cable was the problem that didn't allow it to turn on.
          But!
          The laptop still shows in external screen but internal screen doesn't . But the new let's say symptom is that the screen flickrs like it tries to show something ,for 0.000001ms it does like a flash from black to backlight black but again still remains the same.
          I did update the BIOS to the latest one to be sure, again same nothing changed....
          I have given up.
          • m1ch43lzm
            • Mar 2019
            • 1071
            • Peru
            Does the screen show an image if you shine a flashlight to it?
            EDIT: Now we have to figure out what prompted your customer to replace the LCD cable in the first place, so I think the original fault is what you have now
            Measure +LCDVDD_CON, BL_ON and PANEL_PWM
            • Acnologia
              • Dec 2016
              • 429
              • Poland
              #26
              No backlight , i tried maybe to see a logo or something as usual to understand 100% the problem , but again nothing.
              The flickr of the image is ... imagine a black color and then if you press the power button for a split mini 0.00001 sec like a spark it shows a change from black to ultra black ... if i can explain it somehow ,the black light up a little.
              Other than that nothing more.
              Where , to check those lines ?
              I still cannot believe, that he tried to change the cable , and did a hole in the FPC connector , and it could happen due to the old cable
              • m1ch43lzm
                • Mar 2019
                • 1071
                • Peru
                #27
                https://www.badcaps.net/forum/troubl...ic#post1718498
                Schematics post #9, board view post #11, the boardview posted by "Lisa Su" you unrar, then rename the extension from GE4B0.fz to .tvw, open with flexbv free
                I think i understand what you mean, on IPS panels when off they look black even when shining a flashlight, when the panel gets energized gets a bit blacker before backlight comes on
                On TN panels when off it's a dark green color, more noticeable with a flashlight, then turn black when powered on
                LCDVDD is pins 18-19 of the LCD connector, you can measure it at CG11, CG24, or at pin 1 of UG1, should be 3.3v
                PANEL_PWM, pin 8 and BL_ON, pin 9 of the LCD connector, those go to the back of the board, the boardview will help identify some resistors where you can probe those signals
Name:	Captura de pantalla 2025-06-05 155024.png
                • Acnologia
                  • Dec 2016
                  • 429
                  • Poland
                  #28
                  Click image for larger version  Name:	Captura de pantalla 2025-06-05 155024.png Views:	0 Size:	160.1 KB ID:	3653107
                  UG1..
                  • Acnologia
                    • Dec 2016
                    • 429
                    • Poland
                    #29
                    Plus i see that the capacitors are not there...CG24 and CG11...
                    Maybe when he tried to fix it he ripped them out ?!
                    • m1ch43lzm
                      • Mar 2019
                      • 1071
                      • Peru
                      #30
                      Measure with laptop powered on, lid open, keyboard facing down on the table to make it easier for you
                      You should also get the enable signal (3.3v) at pin 4 to enable UG1, and the output should be 3.3v
                      Click image for larger version  Name:	ug1.jpg Views:	0 Size:	12.9 KB ID:	3653519
                      • Acnologia
                        • Dec 2016
                        • 429
                        • Poland
                        #31
                        Nice hint i was trying to turn myself around etc.
                        Yes, they are as you show me.
                        3.35 to 4.5 and 1.
                        2 and 3 are 0.00
                        • Acnologia
                          • Dec 2016
                          • 429
                          • Poland
                          #32
                          I should order them i believe....​
                          • m1ch43lzm
                            • Mar 2019
                            • 1071
                            • Peru
                            #33
                            Voltages look fine, the panel is getting power
                            Try doing an LCD self test according to the e15 gen2 hardware maintenance manual
                            LCD Self Test
                            When you turn on the computer and the LCD goes black, run LCD Self Test to help you determine whether the LCD functions normally.
                            To run LCD Self Test:
                            1. Ensure that the computer is connected to ac power. Then, press the power button for about seven seconds to turn off the computer.
                            2. Press Fn, left Ctrl, and the power button at the same time. If the computer displays five solid colors in sequence across the entire screen, it indicates that the LCD functions normally.
                            3. The test lasts for about 20 seconds and then exits automatically. You also can press the power button to exit the test.
                            • Acnologia
                              • Dec 2016
                              • 429
                              • Poland
                              #34
                              nope ,it doesn't.
                              • m1ch43lzm
                                • Mar 2019
                                • 1071
                                • Peru
                                #35
                                Do you still have the working E15 gen2? To check if the LCD self test procedure works there
                                  • 22166
                                  Did you check BL_ON
                                  • Acnologia
                                    • Dec 2016
                                    • 429
                                    • Poland
                                    #37
                                    No ,it was returned.
                                    The screen is 100% working. As it has been tested to a 14" that i have on the side , it works like a charm (it's the original screen of the Lenovo ,as i have teared apart the sticker of the screen) it was never opened.
                                    • Acnologia
                                      • Dec 2016
                                      • 429
                                      • Poland
                                      #38
                                      Originally posted by SMDFlea
                                      Did you check BL_ON
                                      How to check BL_ON ?
                                      • m1ch43lzm
                                        • Mar 2019
                                        • 1071
                                        • Peru
                                        #39
                                        Alternate point for BL_ON is on the back side of the board, get the schematics and board view if you haven't already
                                        R4618, it's either a 0 ohm resistor or a trace, according to schematics it should be "high"
                                        Or at DG13, it could be missing but the pads are there, if it's bypassed by R4618, sometimes the engineers place parts on the schematics that are not used in the final production version...
                                        • Acnologia
                                          • Dec 2016
                                          • 429
                                          • Poland
                                          #40
                                          Did you check BL_ON
                                          Sorry for my late reply , i was away.
                                          Yes, i checked both of R4618 and DG13 and they show the same values.
                                          • Coguar
                                            HP ProOne 23.8 inch G9 ALL-in-One Desktop PC - Working when plugged to an external monitor, no image otherwise
                                            by Coguar
                                            In the device manager there is no built-in display located. The Intel UHD Graphics are displayed and only the external display is visible. The AiO turns on and works but is only showing a black screen on the monitor.
                                            I checked the voltage on the backlight connector and it reads ~20V. I tried reseating the LVDS and Backlight connector, yet the image still does not show.
                                            Does anyone have ideas whether or not this is a BIOS related issue? The only visible log in the BIOS logs is that the firmware was updated around a month ago.
                                            We already tried to fix it by resetting the...
                                            06-23-2025, 07:14 AM
                                          • Madoy104
                                            Macbook Pro A1989 - No image, working fine with external monitor
                                            by Madoy104
                                            I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
                                            08-15-2024, 10:01 AM
                                          • larrysito111
                                            dell alienware m17 r5 LA-L761P liquid damage no image on lcd 2red 7blue runs on external
                                            by larrysito111
                                            got here a liquid damaged alienware
                                            the laptop had damage in the area of the kb9542qf2 all sorted and now laptop working and turns on but i have no display
                                            so if i start and connect usb-c display it works otherwise it is giving me the 2red and 7blue
                                            so with the usb-c external monitor is getting to bios and OS
                                            otherwise not
                                            so if it is in the os and i connect another lcd via onboard hdmi it is working no problem 2 lcds (1 usb-c + 1 hdmi)
                                            but still not the internal monitor
                                            (tested 3V and 5V going to the...
                                            06-12-2025, 04:16 PM
                                          • f-bone
                                            dell la-b843p image only on external
                                            by f-bone
                                            Hi guys,
                                            this one seems to work except that there is no image on LCD, only on external via HDMI. I have flashed the bios with a cleanME one and measured voltages at GPU (0.9V) and LVDS connector (LCDVDD_LCD is 19V and DCBATOUT_LCD is 3.3V). I can see the LCD going black after power on but no image. I shed some light with a torch but there is no image or activity at EDP_TX0/1 using the oscilloscope. I also tried a different panel.
                                            any ideas are welcome.
                                            br,
                                            george
                                            12-19-2022, 06:59 AM
                                            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-12-2024, 02:20 PM
